Washing machine jumping
I just plumbed a new machine and fitted an integrated door. The machine has very little clearance at the top but the worktop height is standard. The people using the machine say that it did 2 washes without problem but on the third it jumped and moved a lot. Have I erred or is it for some other reason? The machine is on a tiled floor, on concrete and is level.
  • jabbathehut Mar 11, 2008
    Helpful thanks but I did remove them at installation
    Thanks. Will do. Lock nuts could be cause as 1 might not be tight and the wash may have been too heavy. I will report back at a later time. Thanks again
    President:
  • 1,314 Answers
If its a new machine did you remove the shipping braces
Posted on Mar 11, 2008
  • robert samples Mar 11, 2008
    ok make sure you tightend the lock nuts on the leveling legs and ask them what they were washing at the time of the malfunction as they may have been the cause of the un balance also brand and model would help
SOURCE:
Can I use my Triciry Bendix dishwasher DH101 if I remove the top. It needs more clearance below the worktop. When I remove the top there is a material, not a solid top.
Listen to hear if dishes are rattling against each other. Cups should be loaded only in the top and care to keep each cup separated from other. Chipping usually will occur when dishes are close together and in contact. The racks are rubberized and would be very unlikely the source.
If the feet are adjusted so the machine will not rock it would be unlikely that the top on or off would have any effect.
The upper shelf is adjustable up or down. Suggest locating upper shelf to the up position.
TRICITY BENDIX Dishwasher
Hope this helps?
Dec 06, 2016 | Dishwashers
Integrated Worktops
Usually screwed internally within the door edge of the oven it is rare but may be lugs on the top edge within the oven facia panel.
Jan 09, 2012 | Ovens
Could I "stack" a front
i would not recommend stacking one machine directly on top of another. there are various issues with weight, and movement due to vibration.
what you can do is built a solid "workbench" that you can fit one machine under, and then put the other machine on top of the "bench"
personally i would overbuild the bench, using 2" by 1" wood for the frame, braced and bolted to the wall for stability, and use a 1"thick worktop forv the top of the unit. on the top surface, i would also put a 3/8" wooden beading strip about 1/2" fron the outside edges of the worktop to stop the machine moving with vibration and falling off.
i have done this a number of times when space is limited, although i find it much easier to put tehr dryer on the top as it is the lightest of the 2 units.
hope this helps
Apr 01, 2011 | Washing Machines
Connecting a indesit iwdc6125
you can fit it you have to trim the continuous plinth either side of cabinet . also check your new washer will fit under the worktop freestanding appliances are 85cm high integrated are 82cm.
Jul 16, 2010 | Washing Machines
Having a new floor in the kitchen and my faithfull
Buy a machine that will is the first thought , otherwise get the kitchen fitter to raise the worktops above the washer
You could try taking off the top lid and removing the feet underneath which will give you some room
Make sure that you place a sheet of plastic over the top of the machine from side to side and tape it in place if you do remove the top
That is in case you spill anything on the worktop which then drips inside the machine
Sep 16, 2009 | Zanussi FLE1416W Front Load Washer
Ariston Washing Machine Model AF 883 T
this is general instruction for door boots - allo much the same
undo clamp that holds boot to cabinet and peel away clear of the cabinet.
take worktop off.
locate clamp that holds boot to tub. undo clamp (usually like a giant wire jubillee clip) and boot can be pulled off tub.
lubricate slot in boot that goes onto tub with washing up fluid
starting at top, push slot in boot onto lip of tub. working in both directions, continue forcing slot onto lip. this is a knack and it may take a few attempts.
when full fitted, refit clamp and tighten
refit door boot to cabinet (this is easy) and refit outer clamp.
test for leaks on rinse cycle as water level is higher. water will be foamy from washing up fluid till washed away.
turn of at mains while doing this job
Sep 17, 2008 | Washing Machines
I NEED TO CHANGE THE DOOR SEAL ON A HOTPOINT WF 250 WASHING MACHINE. I HAVE THE SEAL BUT JUST NEED SOME DIRECTION THANKYOU
turn off at mains
undo clamp that holds seal to cabinet and peel seal away from cabinet.
take worktop off
undo clamp that holds seal to tub and seal will then come away
on new seal, lubricate the slot in the seal that goes onto lip of tub with washing up fluid
starting at top, insert slot in seal onto lip of tub and work you way round in both directions till seal is entirely on tub.
replace clamp
fit seal to cabinet (this is easy) and refit outer clamp.
test on rinse cycle as water level is higher. water will foam till washing up fluid is washed away
Sep 09, 2008 | Washing Machines
WMA46 Door Seal
turn off at mains
remove clamp that holds door seal to cabinet. peel door seal off cabinet.
remove worktop
undo clamp that holds seal to tub. pull seal away from tub.
to refit
lubricate slot in seal that goes on tub rim with washing up fluid
starting at top, fit groove in seal onto rim and work your way round in both directions pushing seal on to tub rim - requires patience and you amy not suceed first time round.
refit inner clamp
fit seal rond cabinet -0 this part is easy
refit outer clamp.
test for leaks on rinse as the water level is higher
Sep 07, 2008 | Hotpoint WMA46 Front Load Washer
AEG Dishwasher 35080VI inbuilt - door pops open
usual door closure is onto a hook coming out of the top of ther cabinet just under the worktop. this needs adjusting to come out a little
Sep 02, 2008 | AEG Dishwashers
Washing Machines Logo
120 people viewed this question
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
Marvin
Marvin
