Question about Acer Aspire 5610 Notebook
Acer launch tool
Hi how do i disable the acer launch tool on my laptop?
  • jake Mar 11, 2008
    thanks i can do that, but there is this window in the way of me seeing the system config window and it shows on top ov everything, how do i close that window as it doesnt have any of the buttons on the top right hand corner and wont show up on the task manager
    thanks
  • 652 Answers
Hmmm you can do.
Navigate the following:
1). Start -> Control Panel
2). double Click on Administrative Tools icon
it will open Administrative Tools window
3). Double Click on System Configuration
it will open System Configuration window
4). click on startup tab
search the program you want to stop (in your case acer launcher) make it disable
Thanks
Iqbal
Posted on Mar 11, 2008
Launch manager dritek
check to see if was disabled at start up...also you can in services to if it was disabled as well....if all else fails....re install it
Nov 13, 2013 | Acer Aspire Computers & Internet
RESET HARD DISK DRIVE LOCK FOR ACER ASPIRE
Step 1:
Which model of acer laptop ? there are many
The BIOS (Basic Input Output System) is designed to check the integrity of the computer hardware and launch the operating system. The BIOS also has basic security features that prevent unauthorized access to the computer by locking the hard drive with a password. The password is required in order to launch the operating system. That option can be disable without an changes to the operating system.
Turn your computer on. Press "Esc," "Del," "F2" or "F8" to access the BIOS. Use the arrow keys to go to the "Security" tab. Press "Enter." Highlight "HDD Lock," Boot Password" or "Hard Drive password" using the arrow keys. Press "+" until "Disable" appears. Go to the "Exit" tab, highlight "Save and Exit" and press "Enter." Press "Y" when prompted to reboot your computer without the hard drive password.
Feb 19, 2013 | Acer Aspire Computers & Internet
Hi my acer aspire 5315 e button at the top dose not work so do you now who to fix this
Hello reeceman1,
The Acer Launch Manager needs to be running for the 'e' key to work. To run the Acer Launch manager, do these 3 steps:
* Click the windows start button (bottom left-hand corner) * Click All Programs * Click 'Launch Manager'
When the Launch manager window displays on the screen, click OK. Now Press the 'e' button and it will launch the Acer Empowering Technology
If this solution is helpful please click a thumbs-up rating.
Have a great day, martyshaw152
Apr 09, 2011 | Acer Aspire 5315 Notebook
Touchpad for wlan/bluetooth and backup manager is
i also have the same problem with you, try to disable the" launch manager",,
Jan 17, 2010 | Acer Aspire 3935-6504 Notebook
My leptop acer 4720zg physical dumping error
1) Examine the “System” and “Application” logs in Event Viewer for other recent errors that might give further clues. To do this, launch > Eventvwr.msc from a Run box; or open “Administrative Tools” in the Control Panel then launch Event Viewer.
2) If you’ve recently added new hardware, remove it and retest.
3) Run hardware diagnostics supplied by the manufacturer.
4) Make sure device drivers and system BIOS are up-to-date.
5) However, if you’ve installed new drivers just before the problem appeared, try rolling them back to the older ones.
6) Open the box and make sure all hardware is correctly installed, well seated, and solidly connected.
7)Confirm that all of your hardware is on the Hardware Compatibility List.
8)Check for viruses.
9)Investigate recently added software.
10)Examine (and try disabling) BIOS memory options such as caching or shadowing.
Jan 03, 2010 | Acer Aspire 4720 Notebook
ACER LAUNCH WILL NOT CLOSE
for that when u close the program ... click on start> run> and type msconfig > on the top there is a tab called startup > on the startup tab find the program which u do not want to start when u start the system uncheck it and than click on ok and it will ask to restart the system and so go ahead and do it and when the system restarts again it will come up with a popup and it will have a chk box which says do not show this msg again and put a chk there and click ok and that is done ... :)
May 07, 2009 | Acer Aspire 5050-3242 Notebook
Installing acer launch tools in aspire 5920g model laptop
you need new installer windows and you need manual install you're recovery programs is corrupted..try to use new installer...
Thank You
Apr 03, 2009 | Acer Aspire 5920-6335 Laptop
Acer aspire 3680
The acer program is turned off or not installed.
You need to enable the program or install it if not installed.
you can get the program from acer at this address
http://support.acer-euro.com/drivers/notebook/as_3680.html
I beleave its the launch manager
Jun 01, 2008 | Acer Aspire 3680 Laptop
Cant find my wireless card in device manager in acer travel mate 2300
In some Acer models, there is a software switch in Start/All Programs/Acer Launch Manager. If this is missing, you need to reinstall since even with the WiFi hard switch activated, this application is required. This is so especially if a new/clean/OEM install of the OS has been done on the laptop.
In some models, there is a hard switch either at the front or at the side to activate the internal wifi (and bluetooth). Still in other, there is button on the leading edge of the computer which also serves as an indicator lamp,
Some models also have WiFI enable/disable in the BIOS/CMOS setup.
Still others have a button along with the Easy-launch strip (top) together with the those for email , bluetooth , Acer Arcade & others.
As shown above, depending on the specific model/region version of your laptop, the WifI activation can be varied.
Hope this be of help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards.
Jan 19, 2008 | Acer TravelMate 2300 Notebook
Acer Aspire 5610 Notebook Logo
1,954 people viewed this question
Brian Sullivan
Brian Sullivan
Mohammed Ebrahim M
Mohammed Ebrahim M
