Back to:
Tags:
Samsung DLP HL-P4663W 46 in. Rear Projection HDTV-Ready Television
Samsung dlp tv HL-r5067W (by 2 users)
posted by kennydorado on Mar 11, 2008
I have had my tv for about three years, the picture started to pulse dark then light dark red,, and no more. I read that it must be the bulb. I put
in the bulb and there is a loud humming noise from within the tv, it is not
the fan,, and the bulb will not light. I checked all of the connections and they are not disconnected,, the front three lights are lite and when i fire up the tv, (i am holding down the blue switch) the lamp light comes on and the humming sound starts. I thought it might be a wire hitting the exhaust fan
but it is not... is this a ballast? or something else?
samsung was no help..
I have the same problem Post a new problem
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
1 Other User Has The Same Problem
Comment by amatech, posted on Sep 06, 2008
I am . also having the same humming sound coming from the tv. I have had my TV for about three years now. I need some help
Best Solution
posted on Mar 12, 2008
FixYa! (100)
pkaiser74
Rank:Guru Guru
Rating: 87%, 94 votes
its your color wheel
Was this solution helpful? Show your Appreciation by rating it:
Thank You!
Was the solution helpful?
Show your appreciation by commenting on samsung dlp tv HL-r5067W:
I don't want to Accept this solution
Can you Help with these Projection Televisions problems?
Samsung DLP HL-P4663W 46 in. Rear...
2 white dots suddenly appeared on my 2 year old Sumsung...
my son used a cleaner (windex i think) to clean my samsung...
My set is 2-1/2 yrs. old. It suddenly (at start-up)...
Need info for color wheel replacment and Menu access info...
In Hurricane Ike, tv went off with light again. stayed off...
Loading problems.
Repair Service
Find Projection TV Repair Service Provider Near You:
Browse the Repair Service Directory
Repair Service Providers, Get Listed FREE
Prescreened Contractors
Get Matched to Prescreened Home Media Professionals
Category
Zip code
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
