Question about Acer Aspire 7720 Notebook
Acer asspire 7720 RAM upgrade
How do I access the RAM chips through removing the keyboard?
  • bootit25 May 30, 2008
    When the screws are removed, the cover is still tight. How do you remove the cover without breaking it?
    Genius:
  • 3,587 Answers
Under the bottom panel
Posted on Mar 11, 2008
    Problem Solver:
  • 4 Answers
For the 7720 do NOT remove the keyboard! It is not neccesary.
Open the bottom cover by removing 4 screws. Insert a screw driver in the provide notch being very careful not to stick it into the elctronics and gently pry upwards. The cover will release from the center, the tabs are much shorter there. Carefully release the old memory by pressing outward on the silver tabs that hold the memory in. Be sure that the new memory is seated properly before pushing down on the opposite edge.
Posted on Jun 07, 2008
Is there a 'how to upgrade memory acer AOD255E-13405' download somewhere?
If you are talking about increasing the RAM, there usually a little panel on the underside of the laptop accessed by two screws, remove these and replace the chip. Make sure the laptop is off and batter out.
Mar 01, 2011 | Acer Computers & Internet
Cant find ram chips in a Toshiba Satellite A45-S151
The memory is under the keyboard on this laptop. You should be able to pry up the keyboard with a small screwdriver between the keyboard bezel and the keyboard itself.
Be very careful not to break the wires connecting the keyboard to the internals of the computer.
I hope this helps.
Feb 22, 2010 | Toshiba Satellite A45-S151 Notebook
The Numeric keypad on my Acer Aspire 7720 doesn't work. When I press Num Lock key the indicator light doesn't come on. The main keyboard works fine. I am using Vista.
try to access command prompt outside of windows using the operating system disc. (by booting to cd and go to repair your computer options then select command prompt) if the keyboard works fine on command prompt, there's no issue with the hardware. but if it still doesnt work, you will need to replace the keyboard.
Dec 03, 2009 | Acer Aspire 7720 Notebook
Acer Travelmate 270 Memory Upgrade
Acer TravelMate 270 upgrades:
The official upgrade slot is located on the bottom of the laptop and is easy to find. Just unscrew the small cover and there it is.
The other slot requires you to unscrew the two screen bracket screws. Once you have done this, between ESC and F1, F4 and F5 and F12 and PrtSc there are small plastic rings. Put a biro nib into these and pull down. They will pop down. You can now remove the plastic cover.
Unscrew the two screws marked "L9" on the bottom of the laptop which are located at the top of the memory cover. Now you can remove the keyboard. Underneath the keyboard is the second RAM slot. The SiS 650 chipset supports a max of 1GB per memory slot and since this laptop has two slots that means 2GB of RAM. I've used Kingston DDR400 PC 3200 SODIMMS.
You can also upgrade the CPU - the fastest CPU available is the Pentium-M 2.6GHz. Nothing faster will work - trust me on this. It must be a Pentium 4 Northwood architecture CPU with a 400MHz FSB. Standard P4 Northwood CPUs with the metal shim won't fit - unless you know a way of removing the shim without destroying the CPU. Best to stick with a Pentium mobile (Pentium 4 M) chip. Look on Ebay for these.
Of course the hard disk can also be upgraded - a 200GB 7200RPM 2.5" drive works a treat. Non SATA of course.
You can add wireless and USB 2.0 using PCMCIA carbus cards. I use a StarTech 54mbps wireless card with the RAlink chipset and a NEC USB 2.0 card with 4 USB ports. Both cards fit in at the same time.
The laptop absolutely flies with these upgrades.
Mar 20, 2009 | Acer TravelMate 273XV PC Notebook
Need instruction on how to install memory upgrade
First you have to determine whether this model can support 4Gb or memory.
All laptops use the same memory. SODIMM (Small Outline Dual Inline Memory Module) chips are readily available. It's actually quite easy to upgrade. First remove the small piece of the casing that covers the top part of the keyboard. This should just snap off. Then you should find some screws holding the top of the keyboard to the case. Once you remove these, the keyboard will easily pop out. Carefully disconnect the ribbon cable connector leading to the keyboard. Then you should have access to the RAM chips.
Therefore, the only tool you really need is a small phillips screwdriver. Be careful when handling the chips.
Sep 06, 2008 | Acer Aspire 4315 Notebook
Averatec 3700 R1 Notebook - more RAM
Check out this website:
http://www.larwe.com/technical/av3715-open.html
It has complete instructions for the Averatec 3700, with pictures. I used it to upgrade my RAM.
Aug 07, 2008 | Computers & Internet
Mar 22, 2008 | Acer TravelMate 2702WLMi Notebook
Help Access and Insall RAM to Acer Asspire 7720 Laptop
no its not easy to access original one but you can add addition RAM to your lap.
on bottom of your lap you can find screws for a small rectangle area. just open it and there is the place where you can put additional RAM
thanks
iqbal
Mar 11, 2008 | Acer Aspire 7720 Notebook
Ram Install access upgrade
Below the Notebook There will be access flap to put the ram. May even you need to Keyboard for few models.
Acer Aspire 7720 Notebook Logo
970 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
