Home | Toshiba | MW20FM1 20 in. Combo | Toshiba MW20FM1 DVD sec...
Toshiba MW20FM1 20 in. Combo
Problem for Toshiba MW20FM1 20 in. Combo
Toshiba MW20FM1 DVD section quits
By StanFW on Mar 11, 2008
The DVD player quits at random intervals-powers itself down.No indication on screen,though TV stays on-just black.Disc will not eject.Cycle power on set,disc plays again-usually for no more than a few minutes.I am a tech.Have checked the power supply for the DVD-it is being shut down.The main power light stays on.All other TV/VCR functions are OK.
Comments:
Sep 02, 2008
- I took the DVD chassis apart completely to get a P/N and looked for bad solder joints,etc.Found none,but after I reinstalled the board (and applying a no-residue cleaner to all connectors) the DVD played fine! have not had a call back from the owner-though she knows that an aftermarket player can be used with the TV's external input jacks if needed.
Same Problem
Feb 17, 2009
-   I acquired an MW20fm1 for use during a hospital stay but there are no remotes that work with it and the DVD is useless.
The picture is better than any I have seen and want to keep it around the house for a spare but alas, what to do?
-   mygooddog
Solution #1
posted on Aug 31, 2008
Somewhat Helpful)
Guest
Rank: Apprentice
Rating: 0%, 0 votes
am toshiba authorized servicer-have same model in shop for same problem-dvd board is defective-new board is about 290 from toshiba america parts-tv is actually made by orion with toshiba name stuck on outside-orion is junk-cost more than new set to fix-junk it and buy a panasonic-so far they still make their oun stuff
Solution #2
posted on Jun 10, 2009
Not Rated)
johnmackall
Rank: Apprentice
Rating: 0%, 0 votes
I too cleaned all DVD connections, reinstalled everything, and boom! Fixed!!
Comments:
Jun 10, 2009
- My DVD portion on this set was totally dead. The VHS and TV worked fine. I too, removed the DVD section on this set, scrubbed the board with alcohol and a toothbrush, put it all back together, and BOOM!! Fixed!!!
Was this helpful?
Yes
No
Popular Solutions for Toshiba MW20FM1 20 in. Combo
Questions and Unsolved Problems for Toshiba MW20FM1 20 in. Combo
Do you recommend Toshiba MW20FM1 20 in. Combo?
Answer
Answer
Hooked up external Toshiba DVD player to Toshiba MW20FP1 TV/DVD/VCR combo. Red,yellow and white... (More)
Answer
The remote censor does not work. Is there a way to access the menu function manually?
Answer
I have a Toshiba MW20FM1 when I turn on the power light comes on but no picture or sound
Answer
I need the programing codes for the remote so I can program the remote that came with my cable box... (More)
Describe your problem:
Select a Category:
Sponsored Links
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For Toshiba MW20FM1 20 in. Combo:
Top TV Combo Experts
Rank: Guru Guru
Solutions: 1494
Experience: I run a Full-time Appliance Service Co.with HVAC/Auto Air Conditioning and Small Engine Service.
Ask Me
Find more TV Combo Experts
Top TV Repair
(859) 609-2887
SERVICE/REPAIR OF TELEVISION AND ELECTRONIC...
(316) 283-8873
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
