Question about SanDisk Sansa e250 MP3 Player
My sansa e250R not working
When i turn the device on all the screen shows is rahpsody and the screen fades way
  • 2 more comments
  • pilato Mar 11, 2008
    currently my pc is attempting to read it
    ok done installing driver, now the cable is connected, what is next
    it is currently in recovery mode what should i do next
    pauldonpI have completed the steps above, what should I do next? the screen is in recovery mode and connected to my pc,
 i put a song from ma notebook onto the my device and when i tried playing a song and the screen went of and when i tried switching it on the screen shows the rahpsody and the sreen fades away
Posted on Feb 17, 2009
  • 4,102 Answers
Hi try this for me and let me know if you can put it in recovery mode if it does go into recovery mode dont do anything just let me know then ill tell you what you need to do next ok
1. with it switched off put key lock on
2. hold down rec button on left hand side
3. whilst still holding rec switch it on still holding down rec
4 it should now say recovery mode
let me know when you get this far ok
Posted on Mar 11, 2008
  • paul proctor Mar 12, 2008
    hi really sorry but my internet connection was down in my area really really sorry but not my fault.
    Right what you need to do now is goto sandisk website and download the latest firmware to update your device let me know how you get on ok sorry mate
SOURCE:
E250r+sd only shows about half of songs from both
Having received no response in over a month, I assume this is no longer a problem.
Jun 08, 2010 | SanDisk Sansa e250 MP3 Player
Refreshing database
User guide for Sansa e200R:
http://mp3support.sandisk.com/downloads/um/e200r_userguide_en.pdf
Check this link for Sansa e200 "freezing in refreshing database",
2 steps to follow up:
http://kb.sandisk.com/app/answers/detail/a_id/34/kw/e200r%20freeze/r_id/101834
1. Reset the device as described on the site of Sandisk.
http://kb.sandisk.com/app/answers/detail/a_id/189
If resetting didn't solve your problem
2. Update the firmware.
http://kb.sandisk.com/app/answers/detail/a_id/306
2.1 Use the Sansa Firmware Updater for a download of your device
with the next link:
http://mp3support.sandisk.com/sansa/Application/SansaUpdaterInstall.exe
2.2 Follow the instructions "update the firmware" for sansa e200 series:
http://kb.sandisk.com/app/answers/detail/a_id/306/kw/e200r%20freeze/r_id/101834
Sep 20, 2009 | SanDisk Sansa e250 MP3 Player
I have a Sansa E250R MP3 player. I had the unit
some where on the device it should hve a reset button that you have to press with a pin or somthing try that
Jul 13, 2009 | SanDisk Sansa e250 MP3 Player
Sansa e250R - Will pwr up but only freezes on screen that says..."Sansa Rhapsody"
You can try to reset the device by pressing the power button for about 15 to 20 seconds..if that doesnt work I would recommend you to go to the sandisk site to update the firmware on your device or you can contact sandisk to they can help you with updating the firmware on your device..Please follow the link below to get the firmware
http://www.sandisk.com/Retail/Default.aspx?CatID=1376
The number for sandisk is 1-866-726-3475
Please rate accordingly
Thank you
Computerrep
Jul 28, 2008 | SanDisk Sansa e250 MP3 Player
SANSA e250r ??
my sandisk 250will not change songs it is stuck o #1 icannot move it up or down
May 03, 2008 | SanDisk Sansa e250 MP3 Player
Sansa c140 is not turning on
my brother had the same problem with the e250r after dropping it (do not know if u did) i opened it and fiddled with the wires and it popped to life just fiddle with the guts ans it should come rite back to life if ur looking for a quick fix.
Jan 11, 2008 | SanDisk Sansa c140 MP3 Player
My Sandisk Sansa e250r keeps freezing up....
I called sansa and got this info on how to format the sansa and restore it back to default
This helped me to detect the device and be able to put songs on it.
Turn off device
put hold key on
press and hold mic key while pluggin in the device to pc
open sansa icon in my computer
Up on top of my computer window click tools then folder options and click view tab then uncheck hide extension for known file types.
Now click file new and choose text document then change the name from New Text Document.txt to sansa.fmt and click enter. It will ask you if you want to change the extention and you need to click yes.
Now unplug your sansa from the pc and this will format your whole mp3 player.
You will lose all your date but your sansa will be detected and working.
Once it is done then turn off your device and plug it in while its off.
It should show up in my documents now. The first drive is your hd on the device and the second one is for the extra micro disk.
Oh and another tip is to click show hidden files so that you can see the music folder.
This way you can just drag and drop without having to use windows media player or Rhapsody.
Jan 09, 2008 | SanDisk Sansa e250 MP3 Player
4 GB micro sd and the Sandisk Sansa e250R...
If the 4gb micro SD is a high capacity SD (it will say micro SDHC on it) your player may not be able to read SDHC cards, my sansa can't because it's the 'older version' it will read 2gb and below micro SD cards though (it sucked when I found out because I had just bought a 6gb micro SDHC)
Nov 22, 2007 | SanDisk Sansa e250 MP3 Player
Switching USB modes to get to micro sd slot...
You have the newest version, indicated by a V2 on the back of the unit. You do not have the MODE option on your device.
The memory card shows up as part of the total memory, you cannot access it separately.
If you mean on the PC, it does not show up in Windows Media Player 10, but it does in WMP 11. If you are using Rhapsody, it does not show. It also shows up in My Computer as a Sansa e250R, right next to the device.
Best of Luck.
Please RATE my solution BELOW.
Nov 21, 2007 | SanDisk Sansa e250 MP3 Player
Device not connected
The Sansa Media Converter will only detect the device in MSC mode, or Plays For Sure (e250R) mode.
Change the mode in the Settings>MODE or USB MODE on the device and re-connect.
Best of Luck,
Nov 15, 2007 | SanDisk Sansa e250 MP3 Player
SanDisk Sansa e250 MP3 Player Logo
44 people viewed this question
Top SanDisk Audio Players & Recorders Experts
Joe Negus
Joe Negus
Ekse
 Ben
Ben
Level 1 Expert
Are you a SanDisk Audio Player and Recorder Expert? Answer questions, earn points and help others
