Washing Machines Logo
Posted on Mar 21, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Whirlpool #907026 filled with water and wont
Whirlpool #907026 filled with water and wont drain,
Anonymous
Level 2:
Novelist:
  • Expert 185 Answers
  • Posted on Mar 21, 2010
Anonymous
Expert
Level 2:
Novelist:
Answers
185
Questions
Helped
62611
Points
408
It is most likely that there maybe something blocking the drain. Check the pump and make sure there is nothing inside it preventing the water from draining properly
Whirlpool stylemaster 4217141 water won't stop filling the machine and it wont start agitating
drain machine and check the water level pressure switch air pipe
that's connected to it ,it's posably blocked stopping the switch from operating. safety disconnect from mains electrical supply before removing any covers.
My washing machine wont agitate and the fill light wont come off
whirlpool has manuals and service books for its machines which have a trouble shooting section, try to get one of these. if you have a sears service center nearby you can usually order these service manuals from them pretty cheap
Whirlpool Top Load WTW4800XQ wont agitate but will drain
Check the plastic/rubber motor to gearbox coupling hasn't broken.
1helpful
My whirlpool thin twin washer wont agitate it just makes loud sound but will fill up with water
Your washer most likely has a broken drive coupling. If broken the washer will fill with water and drain, but the motor spins without driving the transmission (no agitate or spin). The part is common to all whirlpool washers made in the last 20 years and is readily available at all major appliance part stores. It is possible to change this part yourself but much less hassle to get it changed by a pro
1485646-1-s-jpg.jpgSee Part # 13
Search all parts
in this section
USE WPL 285753 (Direct Drive Motor Coupling)Part Number: PS1485646
This coupling kit is used between the motor and the transmission on direct drive washers with no belt. This is the newer version and is made with new metal sleeves for added strength.
CAD$12.81
6helpful
Washing machine wont hold water on any setting
raise the main drain hose to the top of the back control head. there may be a problem with the main hose being to low and the water is gravity siphoning out of the washer.make sure the washer is off when you lift the hose up but do not remove it from the wall,you should here water drain out once it has stopped draining restart you machine and it should fill to the proper level and quit then go into your wash cycle
Whirlpool washer - tub drains while it fills.
Your drain is to low. Make sure that the drain that your discharge hose is going into is at least as high as the washer. If not the water will drain out as fast as you can fill it.
Whirpool washer wont work
The lid switch, get something to hold it down to make machine work. Turn machine on and push down on lid.
Whirlpool washer fills, begins to agitate, then drains
Water siphoning out the drain line
If the water is continues to fill and water is draining while it is filling or agitating, Check the height of the stand pipe. It should be about 36" above the floor. If the height is correct it may need to have an anti-siphoning valve installed into the drain line.
moz-screenshot.jpgThe washer fills and drains at the same time only on the rinse cycle.
Shut the machine off with timer during this period and raise the drain hose. If the water continues to drain, you will need to install an anti-siphon kit.
Please leave a solved rating before you sign out
Whirlpool Quiet Partner 2
More likely: the solenoid which directs the water to either the drain or the spray arm is clogged/jammed. Located underneath near the drain line.
Mike Cairns
Mike Cairns
ZJ Limited
ZJ Limited
