Back to:
Tags:
Sony SDM-HS75P/S  17
Monitor Goes Black or wont turn on
posted by iman1981 on Mar 11, 2008
Hi all
i have 2 sony hs75p one of them when you turn it on after a while it goes black or sometimes wont turn on at all. the lamp and inverter board is good because i switch the inverner board on my monitors and it works but the same monitor goes black after a while (it works for a while ) i'm thinking about the power board because it has two seprate board for power and inverter any body has any experiance with power board or how can i check it? i look at the board to see if there is any bad capaciator or bad join but it looks fine.
I have the same problem Post a new problem
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
Best Solution
posted on Mar 13, 2008
Thanks for Trying (70)
tantong
Rank:Guru Guru
Rating: 86%, 128 votes
So, the problem is not from inverter board. I used to repair LCD flat screen from Dell. I found that it is a broken lamp. It is not big but very small crack. You might double check it again.
Thank you,
Was this solution helpful? Show your Appreciation by rating it:
Thank You!
Was the solution helpful?
Show your appreciation by commenting on Monitor Goes Black or wont turn on:
I don't want to Accept this solution
Can you Help with these Monitors problems?
Monitors
When I turn on my new Dell computer, it just says that my...
Monitors
I have 17in studio display monitor_ It was working fine...
Sony SDM-HS75P/S (Silver) 17" LCD Monitor
I have a Sony SDMHS75P LCD monitor and some reason when i...
Backlight went out just after three year warranty. This...
My sony sdm-hs75p only goes black on occassion, never when...
Loading problems.
Repair Service
Prescreened Contractors
Get Matched to Prescreened Computer Professionals
Category
Zip code
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
