Remove your needle and then dissassemble your bobbin case and clean with a brush. Make sure that your machine is not plugged in.
Is your needle position high enough that you can remove the needle, and then maybe use a straight pin or tweezers to pull out the thread?
If needle is down try loosening the screw that holds it in and see if you can push it down into the casing enough to clear it for removal. good luck
