Pixma ip 5500 has stoped working.8c cyan records as faulty but still ok for ink [visual].red light is out when lid is lifted but is lit when cart is returned.when I start to print I start the computer the same message appears on screen faulty cart .open the printer lid no light on 8c.I replaced the 8c with a new 8pc no light at start or finish .I cannot use maitenance mode.
    Sergeant:
  • 319 Answers
Http://free.grisoft.com/
Posted on Mar 11, 2008
SOURCE:
Canon pro9000 mrk2 printer wont recognise yellow cart cli8 but if I lift out the cyan cart it will recognise the yellow until i fully seat the cyan back in the holder again
you do get this with a lot of canon printers its nor-manly the black, make shore you have the prober canon cart because some of the copy,s don't match the pin,s on the printer also clean the pin,s on the printer, that the cart fit,s back to with a cue tip but be care full not to hard as this my damage the pin,s which my be the cause. I would swap any way to a chip epson the ink,s cheaper
Nov 01, 2011 | Canon PIXMA Pro9000 Printer
* After refile ink yellow color does not print at all.(ip 2772) * How to setup CIS system for canon Pixma ip 2772. which contains PG810/CL811 cartridges ?
I refilled Canon cartridge CL-811. I filled all 3 colors. Magenta Cyan Yelloware flowing well,. Even if I wipe the cart on paper tissue, 3 colors are coming out (pink magenta and Yellow).but while printing yellow colour isnot printing,. Any idea how I can fix the problem?
Jan 20, 2011 | Canon PIXMA iP1800 InkJet Photo Printer
Error code U150 The following ink tank cannot be recognized
First, make sure you have the right ink cartridges. Here are the right codes: CLI-8BK and PGI-5BK for black, Yellow - CLI-8Y, Magenta - CLI-8M, Cyan - CLI-8C.
If the ink lamp is off then an ink tank error has occurred. Try to remove the ink tank and re-seat it. Make sure you removed the plastic cover on the ink tank. If nothing helped, you need to replace the faulty ink tank.
Dec 29, 2010 | Canon PIXMA MP600 all-In-One InkJet...
Ink tank not recongnized
Unfortunately you have a bad cartridge.
Whichever carts are NOT lit red are the culprit(s).
Take them back to the store where purchased.
Aug 14, 2009 | Canon PIXMA MP610 InkJet Printer
Replaced a new cyan cartridge for Epson 1400. Printer ignored it.
Ye of course it could be faulty and Epsons are sometimes very fussy about using third party carts. Get it replaced at your store, try a different brand or buy a genuine Epson cart if you can afford it.
Jul 04, 2009 | Epson Stylus 1400 InkJet Photo Printer
Canon Pixma IP5000 wont print cyan or magenta
Think you need to clean the sponge that the ink cartridges sit on in the head tray they are probably blocked with dry ink. You can remove the print head and tray by lifting the lever and gently lifting it out..... go here http://www.inkjethelper.com/
to see how to carefully clean it with compressed air. I had to do this too.
Apr 09, 2009 | Canon PIXMA iP5000 InkJet Photo Printer
More than one ink tank of the following color is installed
Other forums report this problem as a faulty ink cartridge that cannot be recognized or gets recognized as the wrong color. Calling canon tech support will usually result in a free replacement from Canon. If not, try purchasing a new cart before ditching the printer.
Jan 23, 2008 | Canon Pixma MP500 All-In-One InkJet...
MP530- Printer issue
Install recommended ink tanks in the correct order MP500 / MP530 / MP800 / MP800R / MP830
Ink Tank Order Install ink tanks in the correct order (from left to right) CLI-8BK (Black) PG-5BK (Pigment Black) CLI-8Y (Yellow) CLI-8M (Magenta) CLI-8C (Cyan) mp500_inktankorder.gif 05sj00141_08_en.gif
Jan 01, 2008 | Canon PIXMA MP530 All-In-One InkJet...
I don't know how to change the ink in Canon mp600
Switch on the printer. Open the front output tray. Lift the lid and the glass platen. The ink cartridges will slide into view and be lit up in red. Any ink needing changing will be flashing.
Press the white handle to release the cartridge. It will stop flashing.
Tilt it up and pull towards you to remove. Remember how you do this as the new one needs to go back in the same way.
For the new cartridge: -
Open the packet and peel off the orange protective film.
Carefully remove (twist off) the orange protective cap.
Do not touch the electrical contacts on the cartridge.
Do not shake the cartridge.
Insert the new cartridge in reverse to how you took the old one out.
Push it down to lock it in place, it will light up when correctly inserted.
Close all the covers and dispose of the old cartridge safely and responsibly.
Dec 06, 2007 | Canon PIXMA MP210 InkJet Printer
Open Questions:
Computers & Internet Logo
138 people viewed this question
Ekse
Alun Cox
