Question about GE Profile Spectra JGBP90 Gas Kitchen Range
Glass door panel
I have a GE Range JGBS23DEW3WH. The glass panel on the front of the door has come off. There is a metal bracket bent, I found on a part site, part #266336. I do not know if there are any additional clips required to hold that panel in.
    President:
  • 1,314 Answers
No that should do it
Posted on Mar 11, 2008
1997 mercury grand Marquis driverside rear window motor works but window won't go up. Inner door panel off. Metal cable with a black foam cover and pink plastic clip off. Can't figure what it fits to.
usually this means you need a new window regulator.
Section 01-11: Glass, Frames and Mechanisms 1997 Crown Victoria, Grand Marquis Workshop Manual
REMOVAL AND INSTALLATION Window Regulator, Power Front Door
Removal
  1. If front door window glass (21410) is in the down position and is inoperable, the following steps must be taken; if front door window glass is operational, go to Step 2.
    1. Remove front door trim panel (23942) and front door trim shield (237A04). Refer to Section 01-05 .
    2. Disconnect battery ground cable (14301). Refer to Section 14-01 .
    3. Disconnect window regulator electric drive harness connector.
    4. sva~us~en~file=ani_caut.gif~gen~ref.gif CAUTION: Be careful not to strike or scratch front door window glass because it can break.
      Remove window regulator electric drive retaining screws through holes.
    5. Remove window regulator electric drive (23394) from front door power window regulator.
    6. Raise front door window glass to full up position by hand and secure with tape.
    7. Go to Step 5.
  2. Remove front door trim panel and front door trim shield. Refer to Section 01-05 .
  3. Remove front door window glass as described.
  4. Disconnect window regulator electric drive harness connector.
  5. NOTE: Use care not to enlarge sheet metal holes in the door inner panel.
    Remove two 1/4-inch rivets retaining lower bracket of front door power window regulator to inner panel. Use drift punch to knock out center pins for each rivet. Using a 1/4-inch diameter drill, drill out remainder of rivet.
  6. Remove three window regulator electric drive retaining screws from inside door to remove window regulator electric drive from front door power window regulator.
  7. Remove two window regulator retaining nuts.
  8. Remove front door power window regulator from front door (20124).
Installation
  1. Lubricate regulator mechanism with Teflon® Lubricant E7FZ-19590-A or equivalent meeting Ford specification ESB-M1C111-A.
  1. Install front door power window regulator minus motor (23208) into access hole in inner panel.
  1. Position front door power window regulator using upper studs and tabs on window regulator electric drive mounting bracket.
  1. Install rivets retaining front door power window regulator to door inner panel (1/4-20 x 1/2 inch screw and 1/4-20 nut and washer assemblies or equivalent metric fasteners may be used).
  1. Install two upper front door power window regulator retaining nuts.
  1. Install window regulator electric drive with three screws. Do not overtighten screws.
  1. Connect the window regulator electric drive harness connector.
  1. Install front door window glass.
  1. Adjust front door window glass as described.
  1. Install front door trim shield and front door trim panel. Refer to Section 01-05 snorkelbobby_38.gif
Feb 14, 2011 | 1997 Mercury Grand Marquis
Need to replace broke window on 93 ford tempo.Pass. side
Door Glass, Front Removal
  1. Remove door trim panel and watershield. Refer to Section 01-05. ani_caut.gif CAUTION: Prior to removing center pins from the rivet, it is recommended that a suitable block support be inserted between door outer panel and glass bracket to stabilize glass during rivet removal. Remove center pin from each rivet with a drift punch. Using a 1/4-inch diameter drill, drill out remaining rivets as damage to plastic glass retainer and spacer could result.
  1. Remove two rivets attaching glass to run and bracket assembly.
  1. Remove glass.
  1. Remove drillings and pins from bottom of door.
Installation
  1. Snap plastic retainer and spacer into two glass retainer holes. Make certain that metal washer in the retainer assembly is on outboard side of glass.
  1. Insert glass into door.
  1. Position glass to glass bracket. Install two rivets to secure glass to glass bracket. NOTE: Two 1/4-inch-20 x 1-inch bolts and two 1/4-inch-20 nut and washer assemblies may be used as alternates for glass retention. However, torque must not exceed 4-7 Nm (36-61 lb-in). Equivalent metric retainers (6mm) may be used.
  1. Install door trim panel and watershield. Refer to Section 01-05.
2-Door Vehicles
4-Door Vehicles
May 29, 2009 | 1993 Ford Tempo
Front right door window will not go up or down, it is electric. it works, some times, and some times not. it is in the down position. Would like to move to up position. I live in Arizona, I need it up for...
does it act the same whether you use the driver door switch or the passenger door switch? Please rate as fixya if this helps. thanks
here's repair procedure
Window Regulator, Front Door, Explorer Removal
srk~us~en~file=ani_caut.gif~gen~ref.gif WARNING: IF THE REGULATOR COUNTERBALANCE SPRING MUST BE REMOVED OR REPLACED FOR ANY REASON, MAKE SURE THAT THE REGULATOR ARMS ARE IN A FIXED POSITION PRIOR TO REMOVAL TO PREVENT POSSIBLE INJURY DURING C-SPRING UNWIND.
  1. Remove front door trim panel and front door trim shield . Refer to Section 01-05B .
Trim Panel, Front Door, Explorer Hi-Series, Two-Door and Four-Door Removal and Installation
  1. Remove the two screws retaining the front door trim panel (23942) located above the window regulator handle (23342) . Also remove one screw in the upper front portion of front door trim panel .
  1. Remove inside door handle cup (22634) at the window regulator handle using a screwdriver or sharp object. Retention nibs will flex for easy removal.
  1. To remove window regulator control switch (14529) and outside rear view mirror control (17B676) , use notch located at lower end of outside rear view mirror control using a screwdriver to lift and remove.
  1. Remove outside rear view mirror control from front door trim panel pulling wire harness from inside of front door trim panel .
  1. From bottom of outside rear view mirror control, remove two screws and disconnect connector from switches. NOTE: Do not pull on the front door trim panel to remove clips from the inner panel holes.
  1. At each plastic clip location, pry the front door trim panel away from the door inner panel using the front door trim panel removing tool from Rotunda Moulding Trim Kit 107-00401 or equivalent. NOTE: Pay special attention to the cut-out in the door trim panel for the door handle, so that it clears the handle during removal without breakage.
  1. When wiring and disengagement of trim clips is completed, it is recommended that to remove panel, lift slightly to remove flange at the top of door trim panel from trough in the glass weatherstrip.
  1. Disconnect socket and bulb from illuminated interior lamp (13776) before total removal of front door trim panel. For installation, follow removal procedures in reverse order. Replace any bent, damaged or missing plastic clips on the front door trim panel to the front door trim panel , firmly loading clips into slots provided on front door trim panel .
    Trim Panel, Front Door, Explorer Hi-Series Four-Door
  1. Remove inside door belt weatherstrip and glass stabilizer.
  1. Remove front door window glass as described in this section.
  1. Remove two nut and washer assemblies attaching the equalizer bracket.
  1. Remove three rivets (manual) or four rivets (power) attaching the regulator base plate to front door trim panel finish panel (23712) .
  1. Remove window regulator electric drive and front door window channel bracket from vehicle.
  1. Working on a bench, carefully bend tab flat to remove arm slides from front door window channel bracket .
  1. Install new window regulator electric drive arm plastic guides into front door window channel bracket and bend tab back to 90 degrees. Use care not to break tab; if tab is cracked or broken, replace front door window channel bracket . Make sure rubber bumper is installed properly on new front door window channel bracket , if replacement is made.
Installation
NOTE: The front door window channel bracket and window regulator electric drive are installed into the vehicle as one assembly. The front door window channel bracket may be disassembled from the window regulator electric drive as described in Steps 7 and 8 of Window Regulator, Removal.
  1. Install front door trim panel finish panel with preassembled glass bracket into vehicle. Set the regulator base plate to window regulator electric drive using base plate locator tab as a guide.
  1. Install three (manual) or four (power) rivets (385189-S100) to attach regulator to front door trim panel finish panel . Two 1/4-20 x 1-inch bolts and two 1/4-20 nut and washer assemblies may be used as alternates for glass retention. However, torque must not exceed 4-7 Nm (3-5 ft-lb). Equivalent metric retainers may be used.
  1. Install equalizer bracket.
  1. Install inside door belt weatherstrip and glass stabilizer.
  1. Lower regulator arms to access holes in front door trim panel finish panel . Install front door window glass as outlined.
  1. Adjust glass to ensure proper alignment with glass run. Cycle glass for smooth operation.
  1. Install front door trim panel and front door trim shield . Refer to Section 01-05B .
Apr 20, 2009 | 1994 Ford Explorer Limited
Power window problem. engauges then disenguages
Section 01-11: Glass, Frames and Mechanisms 1997 Windstar Workshop Manual REMOVAL AND INSTALLATION Door Glass and Regulator, Power Windows Removal
svw~us~en~file=ani_caut.gif~gen~ref.gif WARNING: IF THE REGULATOR COUNTERBALANCE SPRING MUST BE REMOVED OR REPLACED FOR ANY REASON, MAKE SURE THAT THE REGULATOR ARMS ARE IN A FIXED POSITION PRIOR TO REMOVAL TO PREVENT POSSIBLE INJURY DURING C-SPRING UNWIND.
  1. Remove front door trim panel (23942) and front door inside panel sound insulator (20394). Refer to Section 01-05 .
  1. Remove inside door belt weatherstrip.
  1. Remove front door window glass (21410) as described in this section.
  1. Remove two nut and washer assemblies attaching the window regulator equalizer arm bracket (23230).
  1. Remove four rivets retaining the front door window regulator base plate to door inner panel.
  1. Remove front door window regulator (23200) and front door window channel bracket (23288) from vehicle.
  1. Working on a bench, carefully bend tab flat to remove front door window regulator arm slides from front door window channel bracket.
  1. NOTE: Use care not to break tab; if tab is cracked or broken, replace front door window channel bracket. Make sure rubber bumper is installed properly on new front door window channel bracket, if replacement is made.
    Install new front door window regulator arm plastic guides into front door window channel bracket and bend tab back to 90 degrees.
Installation
NOTE: The front door window channel bracket and window regulator electric drive (23394) are installed into the vehicle as one assembly. The front door window channel bracket may be disassembled from the window regulator electric drive as described in Door Glass and Regulator, Power Windows .
  1. Install window regulator electric drive with preassembled front door window channel bracket into vehicle. Set the regulator base plate to door inner panel using base plate locator tab as a guide.
  1. NOTE: Two 1/4-20 x 1 inch bolts and two 1/4-20 nut and washer assemblies may be used as alternates for glass retention. However, torque must not exceed 4-7 Nm (35-44 lb-in). Equivalent metric retainers may be used.
    Install four rivets to retain front door window regulator to door inner panel.
  1. Install window regulator equalizer arm bracket.
  1. Lower front door window regulator arms to access holes in door inner panel. Install front door window glass as outlined.
  1. Install inside door belt weatherstrip.
  1. Adjust front door window glass to make sure it is properly aligned with glass run. Check window for smooth operation.
  1. Install front door trim panel and front door inside panel sound insulator. Refer to Section 01-05 .
Item Part Number Description 1 21410 Front Door Window Glass 2 23288 Front Door Window Channel Bracket 3 23394 Window Regulator Electric Drive 4 23230 Window Regulator Equalizer Arm Bracket 5 222A00 Front Door Glass Run Latch Side Retainer 6 N621906-S36 Nut and Washer 7 N800510-S36 Screw 8 23200 Front Door Window Regulator 9 W525172-S Rivet 10 W525175-S Rivet 11 — Wire Connector (Part of 14630 Wire Assembly) A — Tighten to 7-10 Nm (62-89 Lb-In)
Apr 13, 2009 | 1997 Ford Windstar
Replace a window regulator in a 1994 ford explorer
wow, a lot of work to do.
Installation
Apr 11, 2009 | 1994 Ford Explorer Limited
Can't put door glass back in Whirlpool RF396LXE2 range
The answer is not as hard as it seems. I just tried for 10 minutes unsuccessfully to put the glass back in the two side tracks. Well the glass actually goes in front of them, the top holds the glass in place.
Apr 05, 2009 | Whirlpool RBS275PD Electric Single Oven
Is the glass surface on my GE Spectra solid surface glued to the heat element frame ?
The exterior panel (stainless in my case) is "glued" by adhesive to a lower metal piece which attaches to the door. I know this because my front panel came unglued and there is no other means of support. I am buying a very expensive new front panel.
Oct 19, 2008 | GE Spectra JBP78 Electric Kitchen Range
Front Glass Door Panel on Jenn-Air JDB1270AWF Dishwasher
Hi Fairhill,
I'm Harvey the Master Plumber.
Your question is: It appears that the black rubber-like adhesive that is (was) between the glass panel and the small brackets (flanges) has let go. You don't need the metal brackets; you need the black adhesive to reapply the glass panel to the brackets. Can you help identify what the black adhesive is so that we can order it?
Any good adhesive will work. If you're never going to remove the glass panel then use liquiod nails allowing 24 hrs for drying time. If you might want to remove at a later date then any adhesive that remains plyable will work.
Feel free contact me again!
Please give me a rating here at fixya.com before you sign off
Thank you,
Harvey your Master Plumber
Sep 27, 2008 | Jenn-Air Dishwashers
Inner door seal
You need to disassemble the door and reassemble with the inner glass well in place, no need for a new door.
If the glass is damaged, call manufacturer and replace glass.
If some other part on the frame has bent, replace the faulty part.
The whole door is expensive.
To replace or refit the door glass you can do the following:
0 Check if there is a hinge stop bracket located at the hinge point of entry on the oven, in that case remove it.
1 remove the oven door by pulling it up and removing from the the hinges. If glass is broken , then secure glass with tape. Have a table with a cloth on top ready to lay the door.
2 Remove the outer screws , starting from lower side of the panel.
3Removethe inner screws. Keep all set of screws ordered, and take note of theorder you remove them. You will follow reverse order in reassembly.
4 the frame will be free now,
5 Remove the external glass panel and leave it in a safe place.
6 Replace the inner glass.
7 Clean outer glass and metal door, re-assemble it and mount it back
See diagrams below as an example, I do not have Tecnik diagrams:
, click on picture to enlarge:
Contact Tecnik at the number listed on the owner manual to get diagrams for your model.
Apr 09, 2008 | Tecnik TKC1426 Electric Kitchen Range
Cleaning Inside Glass Oven Door of KitchenAid KEMC308KSSO
To dismantle the kitchenaid pro line oven door: there is a lever over the hinges that attach a door to the oven. The lever is right on top of the hinge. Pull the lever up. When that lever is in the up position, you can pull the door out.
Jan 10, 2008 | KitchenAid Architect Series KEMC308KSS...
GE Profile Spectra JGBP90 Gas Kitchen Range Logo
97 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Ismael Rodriguez...
 Fix Your Board
Fix Your Board
Are you a Kitchen Range Expert? Answer questions, earn points and help others
