Question about Maytag Washing Machines
Maytag 3000 F32 error - Maytag Washing Machines
WHAT IS THE REASON OR CAUSE POSSIBLE FOR WHICH IS IN CODE F32
I did a "GOOGLE SEARCH" on 'KONICA MINOLTA 1312 ERROR CODE F32" and this was the results. Hope this helps!
F32-01, -02, -03, -04, -05, -06, 07Fan motor problem, AC board or ADU stand drive board
Apr 21, 2013 | Konica Minolta 1312 Black Toner Cartridge
What is a F32 error code on a maytag 3000 series
Error Code F3 E2 is a temp system error. This error is displayed if the water temperature sensor value is out of range (23°F to 217°F [-5°C to 103°C]). Correct ohm reading should be 500-100K ?.
Jan 28, 2012 | Maytag Washing Machines
What is an F32 error code
F32 means the pressure switch may be bad. Take the top off the washer by removing the 3 screws along the back. Next, locate the pressure switch, it is the part in the back left of the machine with the small plastic tube attached. Pull the tube off and blow down it in order to clear any lint in the tube. Make sure all the tiny wires are not stripped and are properly connected into the pressure switch. Check to see that the cables running from the switch to the washer are properly connected. Try running an empty load of wash to see if the switch malfunctions again. If you are still having the same problem replace the pressure switch.
I’m happy to help further over the phone at https://www.6ya.com/expert/jeremy_69f3cc28d95bf514
Feb 27, 2011 | Maytag Washing Machines
WFW9200SQA12 f32 error
The "F32" error code is indicating that there is no electrical supply to the Pressure Switch from the Central Control Unit (CCU) or if the Pressure Switch contacts are not making, then "F32" is displayed.
Possible Causes/Procedures:
  • Pressure switch failure
  • Check the Pressure Switch wiring harness for continuity.
  • Check the Pressure Switch for correct operation with a Digital volt/ohm meter.
  • To manually check the function of the Pressure Switch, remove hose from switch and apply air to switch. Audible clicks will be heard from the switch.
Jan 15, 2011 | Whirlpool GHW9400 Front Load Washer
Frontload Maytag HE 3000 sig flashing F-32 door locked
Nov 03, 2010 | Maytag Washing Machines
F32 error on Duet washer
f32 is pressure switch error. Disconnect the tubing and blow out the moisture and retry.
If no-go... replace the pressure switch.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for helping with your FREE question
Sep 02, 2010 | Whirlpool Washing Machines
There is an error code comming up it is f32
The F32 error code is a pressure switch failure error code, this error could be caused by several different reasons.
More than likely the pressure switch has malfunctioned. Be sure you are using H.E.(high efficiency)detergent. Select STOP twice to cancel the cycle. Select DRAIN & SPIN if there is excessive water in the washer. Re-select cycle and press START. If the problem remains you will need to call for service. This type of repair will require accessing the inside of the cabinet area to make some checks. This will require a service technician to diagnose & repair.
Jan 10, 2009 | Kenmore Elite 45986 Front Load Washer
F32 error code
remove bottom apnel on right side? is tech sheet with codes think f32 is pressure switch
Jul 15, 2008 | Kenmore 3.8 cu. ft. HE3 Front Load Washer
Washing Machines Logo
308 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
