Reseting the lamp timer
How do you reset the lamp timer on an hitachi cp 5225 lcd projector many thanks
  • 2,337 Answers
Check page # 36 of the link provided. Is not the same projector model, but you can give a try.
Good Luck.
Posted on Mar 11, 2008
SOURCE:
To replace a bulb in the Hitachi CP-S235 LCD Projector, do I just unscrew the two screws under the plate underneath the machine? Are there any precautions I should take, like not handling the bulb? I have...
Yes to replace the lamp you need to remove the 2 screws. You can touch the lamp but I try not to. After the lamp is in you need to reset the hr timer for the lamp. to do this you need to look in manual on page 34.
If you do not have the manual you can get it here at link below.
http://www.aboutprojectors.com/pdf/hitachi-cp-s235-manual.pdf
Good luck
Oct 05, 2009 | Hitachi CP-S235 Multimedia Projector
Hitachi cp-rs55 not working,tic.tic.... noise coming from project
make sure you reset the lamp timer. Manual has the steps. Hitachi Performa CP RS55 3 LCD Projector
if the timer is reset, try cleaning the color wheel. Optoma HD20 Projector Cleaning this video is for an optoma but the color wheel is cleaned the same way in most DLP projectors. Dirty or dusty color wheel sensors cause the projector to shut down and act like its the lamp.
Feb 02, 2018 | Hitachi Performa CP-RS55 Multimedia...
Can't reset lamp timer
Turn on the projector, and reset the lamp timer.
(1) While the projector running, press the MENU button to open the menu.
(2) Choose the “OPTION” on the menu using the / button, then press the
button or ENTER button.
(3) Choose the “LAMP TIME” using the / button, then press and hold the
RESET button for 3 seconds.
(4) Choose the “RESET” using the button.
memo When the lamp has been replaced after
Dec 11, 2008 | Hitachi CP-X1200 Multimedia Projector
Lcd projector beeps every minute
Hi Jenrowe
Try resetting the lamp and filter timer , if this still occurs reset the whole mashine.
Apr 24, 2008 | Hitachi CP-X275 Multimedia Projector
Resetting the air filter timer
If you do not have a remote here is how to reset the filter time. Use the "Menu" bottun to get the "easy menu" to display. Push the down arrow until you get to "Filter Time," then push and hold the RIGHT arrow to reset the filter time. DO NOT try to reset using the "Reset" option on the easy menu, it will not work.
Apr 22, 2008 | Hitachi CP-S335 Multimedia Projector
Reset lamp timer
found a solution... hold the reset and left arrow untill message appears on bottom of the screen then release then use arrow button to return timer to 0
Apr 12, 2008 | Hitachi CP-S860 Multimedia Projector
Hitachi CP-X960 Shutting Down
Hi Jason
This is normally a faulty Ballast ( lamp's powersupply )
It will need replacement unfortunatelly
Apr 02, 2008 | Hitachi CP-X960 Multimedia Projector
Hitachi CP R555 Multimedia LCD Projector
Hi there
In your Menu options there is a subfolder where it either reads lamp or lamp timer.
Scroll down to it and hold down you right or left arrow key on the Projector for a couple of seconds.
Mar 23, 2008 | Hitachi Performa CP-RS55 Multimedia...
Hitachi CP-X250 LCD Projector
clean filter and reset the filter timer by advanced options filter timer and hold reset till menu shows then arrow up and it will zero out.
Oct 19, 2007 | Hitachi CP-X250 Multimedia Projector
Televison & Video Logo
193 people viewed this question
Top Televison & Video Experts
Ekse
