Re:Azimuth tape head adjust
Thanks for your input. I was wondering if you could be a bit more specific on which ***** it is. You said on that as your looking in at head from front of deck? There
is two springloaded screws facing you as you look at front so I'm guessing its on the left or right side of the head as your facing it? any additional help would be appreciated. Thank you.
  • 49 Answers
If you post a picture or email it to me, I'll tell you which is the azimuth.
Posted on Mar 25, 2008
Can't Get Onstream to Load Tape
HI, This is normally a sign of a dirty drive head. If have any or if you can buy them, get yourself a cleaning tape to clean the head. Also check the tape itself is clear of dirt and nothing is broken/loose. M
Aug 29, 2007 | OnStream DP30 (DP30-01) ADR Tape Drive
Audio Adjustment
Look for azimuth adjustment online to get instructions.
Oct 24, 2013 | Mitsubishi HS-U530 VHS VCR
I try to use my old Sony CCD-V5 video camera recoder to play some old V8 tapes but the the frames are not steady. There are horizontal bars on the screean. Could you let me know how to fix it?
try to clean head-drum with a cleaning tape, if it does not help the head is worn or some tape azimuth problem exists.
Thanks for using FixYa - a 4 THUMBS UP rating is appreciated for answering your FREE question.
Feb 20, 2011 | Sony Televison & Video
Only one channel is playing, i heard some music in stereo. Do heads need adjusting?
clean the head with alcohol.if the head surface is not smooth,it could be worn
.there is a small screw on the side of the head for changing the azimuth.
most front load tape decks have a small hole in the front of the door, when the outer part of the door is taken off.
the best way to align the heads with with a 10khz alignment tape and an oscilloscope.
the screw is adjusted for maximum high frequency performance.
a qualified shop should be able to do a complete service and align for around 50 dollars
Aug 18, 2009 | Audio Players & Recorders
No Picture, just sound. Would a head adjustment help? where is the head adjustment made?
NO!! Do not adjust any of the azimuth settings on the guide arms or control head this will only cause more problems. It sounds as if you just have dirty heads, either try a head cleaner tape, or better try to clean them by hand. Remove the cabinet cover & the head drum is the round silver drum sitting in the centre. Either use isopropal alcahol or something similar & very GENTLY use something non-fabric ( a piece of clean card will do) put a small amount of the fluid on the card & wipe the side of the drum, put very Light pressure on the drum you can damage the haeds if you are too rough, this should clean the heads.
Jul 06, 2009 | Panasonic Televison & Video
Quiet right channel when playing pre-recorded tape.
With the deck in play mode put your finger on the imput of the channel that is low. If it buzzers the same as the other then you may have a faulty head. If it does not there is something wrong in the amp stages of the deck. You can also reverse the leads from the head and if the sound goes down on the other channel it is the head. Try doing it where the leads join with the PC Board, it will be less messing than at the head itself.
Jan 28, 2009 | Audio Players & Recorders
Azimuth Head adjust
Feb 23, 2008 | Audio Players & Recorders
Azimuth Adjustment on Tascam 122MKIII Cassette Deck
the screws are sometimes locked with Loctite or similer and the screw slot may be blocked up also. wetting the screw head with acetone will help to allow for the blocked screw head to soften. BE CAREFUL WITH ACETONE. it will damage plastic!!
Nov 29, 2007 | Tascam 122MKIII Single Dual Cassette Deck
111 people viewed this question
