Question about Brother MFC-5840CN All-In-One InkJet Printer
Unable to print message on the LCD
I'm having a problem with your suggestion. Your first line reads "press menu then start bk copy then fourtimes arrow-up button (tel. index) quick after another"
When the unit starts up the fax button is lit up and the error message is on the LCD. I pressed the menu button and the LCD screen reads 1. general setup. I have no idea what you mean by "start bk copy" and I have tried pressing the copy button first and then the menu and then the black start button but that does nothing.
Can you explain the proceedure a little more clearly for those of us that don't understand.
Thanks
dfcdbe@hotmail.com
  • 832 Answers
Press MENU then the blue copy button (b/w) then fourtimes the arrow up button quite quickly after another.
Machine should switch to maintenance mode and all lights will flash.
Posted on Mar 14, 2008
Brother Model DCP-117C Printer - Display Reads 'unable to clean see troubleshooting and maintenance chapter in user's guide'
you need a new ink absorber box which you can buy from a brother service dealer near your home (see brother homepage of your country). when done so open printer:
http://www.hstt.net/refill-faq/inside.html#Brother_mfc215c
(use google translation german)
you have to rest the eeprom parameter, too
press menu then start bk-copy then fourtimes arrow-up quickly after another. machine will switch to maintenance mode. press by help of arrow up and set : 8 - 0. press start bk-copy til PURGE 64xx appears. press the sequence of 2 -7 -6 -3 (arrow up and set). PURGE will reset to 0000. press 9 - 9 to leave maintenance.
Apr 23, 2008 | Office Equipment & Supplies
I Have a Brother MFC-640CW all-in-one Inkjet Printer. I changed the ink cartridges and I can get them all working except the yellow, when I do a Test print all the other colors come out perfect except for...
press menu then start bk copy then fourtimes arrow-up quickly after another. machine will be in maintenance mode (all lights will flash).
press 7-6-4 and OK (or start-bk-copy).
Machine will do some refreshing of ink and some special cleaning.
When finished press 7-6-3 start-bk copy
machine will do a power purge.
leave maintenance mode by pressing 9-9.
do run a test print.
DO USE ORIGINAL BROTHER INK or skyhorse generic ink only due to the fact that other generic ink will defenetly do damage to the printer!
I keep getting a paper jam and am unable to print
press menu then start bk copy then fourtimes arrow up. what error code do you receive?
Apr 14, 2008 | Brother MFC-3240C All-In-One InkJet...
Unable to print mcf-215
plz press menu then start-bk-copy then fourtimes arrow up quickly after another. machine turns to maintanence mode. press start bk copy: what two digit error code does the machine display?
If it starts with a 4 you do need a new printhead!
Mar 28, 2008 | Brother Multi-Function Center® MFC-215C...
Unable to print message on Printer LCD
please press menu then start bk-copy (blue-button) then fourtimes arrow-up quickly one after another. machine will be in maintnenace press start bk copy again. What two digit error code does the machine display? Post again here.
(There are more than 20 diffrent errors for unable to print behind ;-))
Mar 14, 2008 | Brother MFC-5840CN All-In-One InkJet...
Unknown error message UNABLE TO INIT. printer just stopped working
press menu then start bk-copy then fourtimes arrow up. machine switches to maintenance mode. press start bk copy. what two digit error code does the display show off? Post here again
Mar 13, 2008 | Brother MFC-620CN All-In-One InkJet...
UNABLE TO PRINT
press menu then start bk copy then fourtimes arrow-up button (tel.index) quick after another.
machine will be in maintenance mode and lights will flash.
press start bk copy in case machine wont directly display the error code.
Error starting with 4 means defective print head.
Error starting with 5 menas defective purge station or cycle problems.
both error series means: you need a new printer...
Feb 13, 2008 | Brother MFC-5840CN All-In-One InkJet...
Error message on my Brother MFC-420CN
press menu then start bk copy then fourtimes arrow-up button. Machine will switch to maintaenance mode. You may have to press start bk-copy. The machine will display an error code.
Error code starting with 4 is always a defective print head which needs replacing (except error 46: new waist ink tank needed).
In case it is another error code plz post here again.
Jan 28, 2008 | Brother MFC 420CN All-In-One InkJet...
Unable to print Black
Do you use generic ink? If yes it can be that the bk channel within the print head is clogged due to wrong ink consistence.
What you can try is this:
1. Make sure that the cart is placed well and the hook secures the cart.
2. press menu then start bk copy then fourtimes arrow-up. machine will be in maintenance mode. press 7 then 6 then 4 then start bk copy. machine will refresh ink in tubes and ph and run some special cleaning procedure. when finished press 7 then 6 then 3 then start bk copy. machine will run a power purge. leave maintenance mode afterwards by pressing 9 then 9. run a test print. if you still cant see bk the ph is clogged and cant be fixed anymore!
Jan 07, 2008 | Brother MFC-425CN Multi-Function Center...
Brother MFC-5840CN All-In-One InkJet Printer Logo
49 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Victorman
Victorman
