Hello.We were given a grundig tv. ws70/3020. We cannot find the information,regarding the pin cusion. The picture seems to bevell all the time.Would you be kind enough to let us know how to fix this problem. Thanking you Marilyn Haq 55 Garfield Street Glasgow.G31 1DS
    Scholar:
  • 135 Answers
Hi there!
My guess on this is that you have an East West fault on the set and therefor you have the Pin Cusion or bowing on the sides. The settings are usually only available in the service mode. I do not have the info on hand but I will check wether I have for this model. Regards, Jus004
Posted on Mar 11, 2008
Grundig t55-549 forgot pin code
Try 0345 563 582 515 098 584 219 104 233 223 065 471
Grundig
FT70-700 822DOOFA MW82- 500IRDT ST63725 ST63755 TF55-302 GT210S. MW822699 CVC2030ST ST70-875
563
Grundig
T70-1021, T70-1022
065
Grundig
MW82701 ST55/730 MW70/2700
582
Grundig
GT1401
515
Grundig
T55-1120 T55-1020 WF703020
471
Grundig
32WF100 W82-2030
584
Apr 21, 2014 | Televison & Video
Forgot pin code for grundig gud300hd freeview hd box
Ok this info does not seem to be anywhere so here goes.....
Grundig gud300hd and others of same build alba ect...... set top box pin reset
UNLOCK CODE1. Press MENU and go to Settings and press OK.
2. Go to Parental Control and press OK. The 'Enter the PIN Code' menu will be displayed.
3. Press i (information) button once then enter 4000.
4. Go to Change PIN Code and press OK.
5. Press i (information) button once then enter 4000.
6. When it prompts for New PIN enter the desired PIN number using 0~9 keys. Enter it again to confirm.
hope it helps
Nov 24, 2012 | Grundig Televison & Video
When I turn on my Gundig TV the sound is there, but the picture does not come for about 15 minutes. It starts off blue then slowly changes colour and eventually comes on. The TV is only 16 months old....
Hello
It may be due to the fault of its picutre tube base socket. Some of them may show this type of fault eventhough it is a new one. Picture tube base socket is located at the picture tube bas card itself. It is directly soldered to the base card, throu which the connections are going into the picture tube via its pins. You just open the tv, and pull it out [not make any shakes while pulling it, as that may bed the picture tube pins, or iven break the picture tube neck. Just pull it straight out, and refit it at the same way as you pulled it out, for two or three times. Sometimes this will retify the fault, as this process will remove any loose contact between bascard socket and picture tube pins.
If this doesn't hlep, desolder it out from the picture tube base card, go for a similar type and pin confuguation. Replacing it will solve the problem. As you replacing the base socket, look into the base card for any loose soderings are there too. OK.
Nov 08, 2010 | Grundig 21" TV
Grundig Televition (P37 830 Text) shows only one channel with an
hello, I had thesame problem. I tried everything, after 14 days, where was TV off a tried itagain...an the same problem: text " ATS... OK " So a tried hold 3seconds on Grundig driver button "OK" and then the started automatictunnig. After it - averything is function! :)
May 03, 2010 | Grundig GF70-600 TV
Tv won't stay on
Hello ! this problem can come about if the video card has faults ie processor lickage or an i tem is burnt , processor over heating .
I recomend u change the video card
good luck
Sep 08, 2009 | Televison & Video
NO PICTURE AND AUDIO IS DISPLAYING POWER LIGHT ONLY GLOWING
Hi
Rajesh, Now grundig tv,s Service Not Avail In India But It s
Not a Big Problem U can Call Good TV service Engrs. He Will
Solve Ur Problem
No_2........ Option Is U go for old grundig TV Dealer Or Retalers
Thay Can Help U
Regards
Manmohan Mohapatra
Nov 21, 2007 | Televison & Video
Grundig Xentia - sound but no picture
in your tv is malfunctioning high voltage, the audio is generated without the help of high voltage sistem how happens commonly in many other tv
Aug 07, 2007 | Grundig GF70-600 TV
Televison & Video Logo
54 people viewed this question
Top Televison & Video Experts
Marvin
Marvin
