Back to:
Tags:
Kitchen Ranges
Generic problem for all Kitchen Ranges
Jenn Air range model SVE47600 Beeping (by 2 users)
posted by klg47 on Mar 11, 2008
Stove began beeping and flashing F7. Repairman diagnosed problem as needing new "control panel" with a repair charge of over $800 which we declined. Husband purchased part #WP71001799 for $168 and installed it. Stove still beeping. Can anyone help ?
I have the same problem Post a new problem
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
1 Other User Has The Same Problem
Comment by jgeorg, posted on Jun 17, 2008
I have the same problem. How do I know it's one or the other. It'll cost me $400 in parts to replace both rather than $200 for the 1 correct part.
Solution #1
posted on Mar 11, 2008
Not Rated (0)
tech17
Rank:Guru Guru
Rating: 88%, 1134 votes
f7 is the code for a shorted keypad or membrane have your husband disconnect the mylar ribbion from the range and gently clean the end with a pencil eraser then reconnect and try again if that doesnt work replace the touch pad
Was this solution helpful? Show your Appreciation by rating it:
Thank You!
Was the solution helpful?
Show your appreciation by commenting on Jenn Air range model SVE47600 Beeping:
I don't want to Accept this solution
Can you Help with these Kitchen Ranges problems?
Dacor Epicure ERD30 Dual Fuel (Electric and...
The ignitor seems to work (it glows orange a few seconds...
Kitchen Ranges
the pilot ignition doesn't light
Kitchen Ranges
2 large electric hot plate are always on high, the name on...
Kenmore 79012 / 79014 / 79019 Gas Kitchen...
range was operated on natural gas till we got it changed...
Jenn-Air SCE30600 Slide-In Electric Kitchen...
Hi, grill element overheated and burned up. Since it just...
Loading problems.
Repair Service
Find Kitchen Range Repair Service Provider Near You:
Browse the Repair Service Directory
Repair Service Providers, Get Listed FREE
Prescreened Contractors
Get Matched to Prescreened Appliance Services
Category
Zip code
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
