Question about Samsung SyncMaster 17 in. LCD Television
Monitor not working
Hi. I am working on a Samsungh SyncMaster 170MP. The green light flashes only and the screen never comes to life. I've tested power and signal, with no results. Any thoughts?
  • 3 more comments
  • Scooter7671 Mar 18, 2008
    I am working on a Samsung SyncMaster 170MP. When plugged in the green on/off power button light flashes continuously and the screen never comes to life. I've tested the power brick and the outputs (14V @ 3.5A) are good, I also made sure that the PCs' video cable output is good and it works fine when plugged into another monitor. I had a similar problem with a Dell 1702FP and had to have (2) capacitors replaced on the power supply board. (10uf - 16V).
  • LukeMcCain Apr 18, 2008
    I just received the monitor from a user who discovered it did not work and bought a new LCD monitor.
    The power brick seems okay; all LEDs and buttons on the front seem to work.
    I plugged in an audio cable and sound is working okay.
    Tried 15pin PC input and Video input and the screen stays completely black.
  • 8Bitnut Jun 10, 2008
    samsung syncmaster green lite will flash but turn on 20 minites later by its self.
  • miller312 Dec 08, 2008
    I have a samsung 170mp the power lights blinks and the screen doesn't come on
  • spydar18j Dec 23, 2008
    which diodes did you replace?
    Welcome Back:
    Visited the website for 2 consecutive days.
  • 6 Answers
The inverter board has probably failed. Mine turned out to be the clamping diodes on the inverter. It would act like it was firing up but shut down just as the screen would normally come up. I replaced the diodes and it fired right up and has been working great since.
Posted on Jul 26, 2008
My Samsung syncmaster 730a monitor wont come on. the green light is solid but screen is black. could i have done something or might it have gone bad?
Hi friend,
You need you check your display cable. it should be connected in your CPU. sometime cable lose in CPU..then monitor not given any display ...
Dec 20, 2009 | Samsung SyncMaster 753S 17" CRT Monitor
Green light just flashes on and off and there is no displ
try to check your screen resolution maybe not compatible to your System. if green flashing there no signal from cpu to VGA cable monitor.
Jun 07, 2009 | Samsung Syncmaster 730B 17" Flat Panel LCD...
Monitor will not turn on and the green light just flashes
There's an internal hardware electronic part/s of your samsung syncmaster 930 that is cold soldered / defective. I suggest to bring the unit to an authorized service center to fix the problem. regards
May 29, 2009 | Samsung SyncMaster 930B 19" LCD Flat Panel...
Syncmaster 941bw coming up blank
Hummm. Try to unplug everything, reconnect, than restart. If not working, try to plug your monitor on a different computer to diagnose what is wrong, the computer or monitor. It could also be your graphic adapter, verify that it is firmly attached to the motherboard.
Lastly, replace the defective part.
Mar 27, 2009 | Samsung 941BW LCD Monitor
I am working on a Samsung SyncMaster 170MP. When plugged in the green on/off power button light flashes continuously and the screen never comes to life. I've tested the power brick and the outputs (14V @...
It sounds like it since you have the 14v going to the inverter. Repairing inverter boards even on lcd's is 50/50 shot, so let's give it a go. If you have a dvm check the ohms on the inverter xformers ( if more than one) they should be identical in resistance. Check or replace all electrolytic caps on the board. That's about all you can do outside of replacing it, Oh, see if you have a 5v source going to in inv. bd also, check that.
Feb 21, 2009 | Samsung SyncMaster 17 in. LCD Television
Samsung SyncMaster 17 in. LCD Television Logo
341 people viewed this question
Jerry Greenberg
Jerry Greenberg
