Dos My computer is in dos mode how do I get windows 98 back up?
    Sergeant:
  • 319 Answers
Call tech support! That's why these people get paid. Sites like this wouldn't need to exist if they did their jobs correctly!
Posted on Mar 11, 2008
SOURCE:
Win 98 in dos mode i get this message " no cd rom or msdex.exe is not loaded " when trying to acces game disk in cd rom
1) Does it say MSDEX.EXE or MSCDEX.EXE?
2) Have you ever used that CD successfully on that computer before? (DVD's don't work well in MS-DOS).
3) Verify its trying to run from the correct drive. D:, E:, etc...
That aside, I'd recommend a glance at the following support page. It sounds like your driver isn't supported or your game is referring to a specific drive that doesn't exist.
MSCDEX Help
(make a back-up copy your autoexec.bat, and rename it autoexec.bat.orig just in case)
Get an older compatible driver for your CD-Rom that is windows 98 compatible, so something around the year 2000 is probably ideal.
Uninstall your current driver and reboot. Scan for Hardware changes and install the new drivers for your CD-ROM. Then check your config.sys and verify the driver. If its not correct, open the autoexec.bat in an editor. in the portion of the autoexec.bat that has MSCDEX..exe program you'll put in the following. (replace DRIVERNAME with the driver name, typically MSCD001)
LH C:\WINDOWS\COMMAND\MSCDEX.EXE /D:DRIVERNAME
Save, reboot. Let me know how it goes!
Feb 08, 2013 | Computers & Internet
Why cant i add files or remove from my transcend mp3 player?? computer is hanging if i connect it. and.. it is not getting formatted. files present are not displayed in the player.
It has a virus, could be, try reformatting the mp3 in dos, or better yet windows 98, simply the file system of you mp3 player is corrupted. after reformatting it in DOS mode, you can now reformat it in windows and then load songs.
Jun 27, 2010 | Transcend T.sonic 610 MP3 Player
Stuck in Boot up MS Dos Mode
Win 98 is the cd that most vendors use to format your harddrive if you are having problems it could be the cd is curpt and needs to be replaced .this mite resolve your problem . at start up of your computer press F8 and a startup menu will apper press last good know and it will restat the computer before any problems started ,but if your harddrive has crashed you will have to reformat the drive because all your info is lost .most restore disk are just for lost operating system and you willnot recover any of your files or programs .soo i recomend safe mode at startup .but you can only use last good known one time after that it will erase all info. Good luck
Mar 25, 2009 | Computers & Internet
Install Xp From Dos
If XP will not install from the CD or if you have a new drive with no operating system onit yet try these:
Install Windows XP from the hard drive with Windows 98 already installed:
Boot Windows 98
Insert the XP CD into your CD reader
Explore Windows XP through My Computer
Copy i386 folder to C:\
Go into C:\i386 folder and double click on winnt32.exe to launch the setup from the hard drive
Install Windows XP from DOS (ie. no OS on a new hard drive):
Boot with a Windows 98 Start Up disk
Insert the Windows 98 CD into the CD reader
Run smartdrv.exe from the Win98 directory on the windows 98 CD (file caching)
Type cd.. to back up to the root directory
Insert Windows XP CD into the CD reader
Copy the i386 folder to C:\
Go into C:\i386 folder on C: and type winnt.exe to launch the setup from the hard drive.
Oct 20, 2008 | Computers & Internet
I deleted windows 95 from my other computer and i have the full version of windows 98 i would like to install , but i don't know how to install using DOS
hi
when you in dos mode go to your cd drive and write setup and pres enter
or try boot your pc from cd with windows 98
Oct 07, 2008 | Computers & Internet
MS-Dos prompt in Windows 2000 & Xp
u can just press alt + enter when u r running ms dos prompt in xp or 2000, it will show u full screen and u once again press alt + enter it will back to normal mode when u come out u just type exit from the command prompt
Mar 16, 2008 | Computers & Internet
How do I get my old computer to go back when in dos
u can try a repair by a CD. In Dos type sfc /scannow after inserting ur 98 CD
Jan 24, 2008 | Computers & Internet
Unable to load
How to get to a MS-DOS prompt.
Reason: If Windows or the computer is not operating properly, it may be necessary to get to a MS-DOS prompt to diagnose and to perform additional troubleshooting on the computer.
Solution: MS-DOS users
Windows 3.x users
Windows 95, 98 and ME users
Windows NT, 2000 and XP users
Windows Vista users
Other PC Operating System users
MS-DOS users If you are running MS-DOS with no other operating systems, the computer should be booting into a MS-DOS prompt automatically unless you have a shell or other program loading automatically. If the computer is not getting you to a MS-DOS prompt, reboot the computer and as the computer is booting, press the F5 key when you see the message "Starting MS-DOS" or the MS-DOS version. This will load the default standard MS-DOS. If you successfully get to a MS-DOS prompt and would like to prevent the computer from loading the program that is preventing you from getting to a MS-DOS prompt, or if you would like to fix possible error messages you may be receiving when booting the computer, edit the autoexec.bat and/or the config.sys files.
Windows 95, 98, and ME users If you are able to get into Windows 95, 98 or ME, you can get to a MS-DOS prompt by following the below steps.
  1. Click Start
  2. Click Run
  3. Type "command" and press enter.
This will open a MS-DOS shell. However, if you are attempting to troubleshoot an issue with the computer and are using Microsoft Windows 95 or Windows 98we suggest you restart the computer into MS-DOS. To do this follow the below steps.
  1. Click Start
  2. Click Shutdown
  3. Choose the option to restart the computer into a MS-DOS prompt.
If you are unable to get into Windows 95 or Windows 98 to get into a MS-DOS prompt, follow the below instructions (Windows ME does not have this option).
  1. Reboot the computer
  2. As the computer is booting, press the F8 key when you hear a beep or when you see "Starting Windows 95" or "Starting Windows 98". Windows 98 users sometimes may find it easier to press and hold the left CTRL key as the computer is booting.
  3. If done properly the user should get to a screen similar to the below screen.
Microsoft Windows 95 Startup Menu
============================= 1. Normal
2. Logged (\BOOTLOG.TXT)
3. Safe mode
4. Step-by-step confirmation
5. Command prompt only
6. Safe mode command prompt only
Enter a choice: 1
F5=Safe Mode Shift+F5=Command prompt Shift+F8= Step-by-step confirmation [N]
4. Select the option for Safe mode command prompt only.
Windows NT, 2000, XP, and Vista users If you're running Windows NT, 2000, or Windows XP and need to get to MS-DOS prompt follow the below steps.
  1. Click Start
  2. Click Run or click in the "Start Search" field if you're running Vista
  3. Type "cmd" or "command" and press enter.
Additional information about the difference between "cmd" and "command" can be found on document CH000395. If you're attempting to get into a MS-DOS prompt to troubleshoot the computer boot the computer into safe mode. Additional information about how to get into safe mode can be found on document CHSAFE. Windows 2000, XP, and Vista users who are unable to boot the computer into Normal Windows mode or Safe mode can also enter the recovery console to manage their computer from a prompt. Additional information about how to do this can be found on document CH000627. Finally, if you are experiencing issues getting into Windows NT, 2000, or XP, it may be necessary to run troubleshooting steps from a MS-DOS prompt. It is recommended that the Network Administrator get into the MS-DOS prompt by using either a standard MS-DOS boot diskette (note: will not be able to access data using a standard MS-DOS bootable diskette) or the ERD diskettes created after the installation of Windows NT, or boot from the Windows XP CD.
Index
Category:
MS-DOS Q&A
Companies:
Microsoft
Related Pages:
MS-DOS
Safe Mode
Resolved
Were you able to locate the answer to your questions?
Dec 06, 2007 | Microsoft Windows XP Home Edition
Open Questions:
avast tech support pHoNe {@}{+1888-499-552o] nUmBeR AB USA avast TECH SUPPORT Numberavast tech support pHoNe {@}{+1888-499-552o] nUmBeR AB USA avast TECH SUPPORT Numberavast tech support pHoNe {@}{+1888-499-552o] nUmBeR AB USA avast TECH SUPPORT Numberavast tech support pHoNe {@}{+1888-499-552o] nUmBeR AB USA avast TECH SUPPORT Numberavast tech support pHoNe {@}{+1888-499-552o] nUmBeR AB USA avast TECH SUPPORT Numberavast tech support pHoNe {@}{+1888-499-552o] nUmBeR AB USA avast TECH SUPPORT Numberavast tech support pHoNe {@}{+1888-499-552o] nUmBeR AB USA avast TECH SUPPORT Numberavast tech support pHoNe {@}{+1888-499-552o] nUmBeR AB USA avast TECH SUPPORT Numberavast tech support pHoNe {@}{+1888-499-552o] nUmBeR AB USA avast TECH SUPPORT Numberavast tech support pHoNe {@}{+1888-499-552o] nUmBeR AB USA avast TECH SUPPORT Numberavast tech support pHoNe {@}{+1888-499-552o] nUmBeR AB USA avast TECH SUPPORT Numberavast tech support pHoNe {@}{+1888-499-552o] nUmBeR AB USA avast TECH SUPPORT Numberavast tech support pHoNe {@}{+1888-499-552o] nUmBeR AB USA avast TECH SUPPORT Numberavast tech support pHoNe {@}{+1888-499-552o] nUmBeR AB USA avast TECH SUPPORT Numberavast tech support pHoNe {@}{+1888-499-552o] nUmBeR AB USA avast TECH SUPPORT Numberavast tech support pHoNe {@}{+1888-499-552o] nUmBeR AB USA avast TECH SUPPORT Numberavast tech support pHoNe {@}{+1888-499-552o] nUmBeR AB USA avast TECH SUPPORT Numberavast tech support pHoNe {@}{+1888-499-552o] nUmBeR AB USA avast TECH SUPPORT Numberavast tech support pHoNe {@}{+1888-499-552o] nUmBeR AB USA avast TECH SUPPORT Numberavast tech support pHoNe {@}{+1888-499-552o] nUmBeR AB USA avast TECH SUPPORT Numberavast tech support pHoNe {@}{+1888-499-552o] nUmBeR AB USA avast TECH SUPPORT Numberavast tech support pHoNe {@}{+1888-499-552o] nUmBeR AB USA avast TECH SUPPORT Numberavast tech support pHoNe {@}{+1888-499-552o] nUmBeR AB USA avast TECH SUPPORT Numberavast tech support pHoNe {@}{+1888-499-552o] nUmBeR AB USA avast TECH SUPPORT Numberavast tech support pHoNe {@}{+1888-499-552o] nUmBeR AB USA avast TECH SUPPORT Numberavast tech support pHoNe {@}{+1888-499-552o] nUmBeR AB USA avast TECH SUPPORT Numberavast tech support pHoNe {@}{+1888-499-552o] nUmBeR AB USA avast TECH SUPPORT Numberavast tech support pHoNe {@}{+1888-499-552o] nUmBeR AB USA avast TECH SUPPORT Numberavast tech support pHoNe {@}{+1888-499-552o] nUmBeR AB USA avast TECH SUPPORT Numberavast tech support pHoNe {@}{+1888-499-552o] nUmBeR AB USA avast TECH SUPPORT Numberavast tech support pHoNe {@}{+1888-499-552o] nUmBeR AB USA avast TECH SUPPORT Numberavast tech support pHoNe {@}{+1888-499-552o] nUmBeR AB USA avast TECH SUPPORT Numberavast tech support pHoNe {@}{+1888-499-552o] nUmBeR AB USA avast TECH SUPPORT Numberavast tech support pHoNe {@}{+1888-499-552o] nUmBeR AB USA avast TECH SUPPORT Numberavast tech support pHoNe {@}{+1888-499-552o] nUmBeR AB USA avast TECH SUPPORT Numberavast tech support pHoNe {@}{+1888-499-552o] nUmBeR AB USA avast TECH SUPPORT Numberavast tech support pHoNe {@}{+1888-499-552o] nUmBeR AB USA avast TECH SUPPORT Numberavast tech support pHoNe {@}{+1888-499-552o] nUmBeR AB USA avast TECH SUPPORT Numberavast tech support pHoNe {@}{+1888-499-552o] nUmBeR AB USA avast TECH SUPPORT Numberavast tech support pHoNe {@}{+1888-499-552o] nUmBeR AB USA avast TECH SUPPORT Numberavast tech support pHoNe {@}{+1888-499-552o] nUmBeR AB USA avast TECH SUPPORT Numberavast tech support pHoNe {@}{+1888-499-552o] nUmBeR AB USA avast TECH SUPPORT Numberavast tech support pHoNe {@}{+1888-499-552o] nUmBeR AB USA avast TECH SUPPORT Numberavast tech support pHoNe {@}{+1888-499-552o] nUmBeR AB USA avast TECH SUPPORT Numberavast tech support pHoNe {@}{+1888-499-552o] nUmBeR AB USA avast TECH SUPPORT Numberavast tech support pHoNe {@}{+1888-499-552o] nUmBeR AB USA avast TECH SUPPORT Numberavast tech support pHoNe {@}{+1888-499-552o] nUmBeR AB USA avast TECH SUPPORT Numberavast tech support pHoNe {@}{+1888-499-552o] nUmBeR AB USA avast TECH SUPPORT Numberavast tech support pHoNe {@}{+1888-499-552o] nUmBeR AB USA avast TECH SUPPORT Numberavast tech support pHoNe {@}{+1888-499-552o] nUmBeR AB USA avast TECH SUPPORT Numberavast tech support pHoNe {@}{+1888-499-552o] nUmBeR AB USA avast TECH SUPPORT Numberavast tech support pHoNe {@}{+1888-499-552o] nUmBeR AB USA avast TECH SUPPORT Numberavast tech support pHoNe {@}{+1888-499-552o] nUmBeR AB USA avast TECH SUPPORT Numberavast tech support pHoNe {@}{+1888-499-552o] nUmBeR AB USA avast TECH SUPPORT Numberavast tech support pHoNe {@}{+1888-499-552o] nUmBeR AB USA avast TECH SUPPORT Number
Oct 15, 2019 | Computers & Internet
Computers & Internet Logo
22 people viewed this question
Ekse
Alun Cox
