Question about Samsung VP-D101 Mini DV Digital Camcorder
Blinking screen! I have been having problems playing back my videos at first there were blue or green lines over th screen and some times just a blue screen, i read the the booklet and thought this might be down to the heads beeings dirty so i bought a cleaning tape and ran it through but it doesnt seemed to have done anything! when watching it with line lines it also seems like it is playing faster than real time.... i dont know if its worth buying a new camera as it will more than likey cost a lot to have it sent off! any ideas would be great!
  • confused05 Mar 11, 2008
    i have already rang them and all they said was send it to a company who repairs cuz its out of warnity its nothing to do with them! i rang the company and they said it would cost £46 for them to look at it and thats not including p&p and then they will send a quote... i dont see the point in spending a lot of money prob more than the thing is worth to get fix when i could prob get a new one for bout the same thats why i was asking for help!
  • ario Mar 30, 2009
    it sucks, when you have to pay for the product problems.
  • 319 Answers
Call tech support! That's why these people get paid. Sites like this wouldn't need to exist if they did their jobs correctly!
Posted on Mar 11, 2008
Hitachi 53FDX01B - Green line bent during convergence adjustment? Th epicture quality is really bad and it appears there is a problem with the convergence (There is a green line [north & south] that...
Projection TV sets have two very common problems. One is convergence ( 3D/Warped video) the other is CRT fluid ( Dull Video). Below are more details for both items. Also, complete repair kits with instructions and repair support are avail from site such as
Common Problem #1) Convergence has gone out
Projection TV sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the video to look normal. When its out of alignment the video will look 3D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the TV menu. If you cannot adjust it in the menu - then yourconvergence is broken and needs to be repaired.
This is a very common failure on these projection sets and a fairly simple DIY fix. All projection sets including Samsung, RCA, Sony, Philip Magnavox, Panasonic, Pioneer, Akai, GE, JVC, Toshiba, and others at some point will have the same problem.
Common Symptoms include....
  • Screen looks 3D
  • Colors don't line up
  • One or more colors can't be adjusted when using the convergence menu.
  • Screen is bowed or warped.
  • TV shuts off after powering on. The power light will blink. TV may also make a chirping noise.
Here are some pics of convergence problems.
69189a5.pngSOLUTION #1
What you will need to do is convergence. You can get a repair kit . It includes replacement parts,step by step instructions, support, etc.
Common Problem #2) CRT Fluid is Cloudy
Projection TV tubes have a liquid coolant that is used to keep them from overheating. After many years the coolant in the blue and green tubes will become cloudy and cause the screen to look dull, red/orange, etc. You may even see halos around images.
Picture of a set that needs the fluid changed.
TV set after fluid change
What you will need to do is replace the coolant and clean the crt. You can get a repair kit from . It includes replacement coolant,step by step instructions, support, etc.
Oct 09, 2011 | Hitachi 53FDX01B 53" Rear Projection...
My jvc th s3 DVD player is only playing in black and White how do I solve the problem ?
Sounds like have your component video (RED GREEN BLUE) wires crossed in some way... match them out from the player and into the TV one by one.
Sep 29, 2010 | JVC TH-S3 System
Red blue green lines down my lcd tv screen
IF LCD TV has vertical lines try cleaning T-con board to lcd panel cable or replaced t-con board
Aug 15, 2009 | Samsung HP-R4252 42 in. Plasma HDTV
Intermittent 3 inch green vertical line-5 inches from right side
it you have a repair skills you need to open the TV and make sure all the ribon connectors around the circuit boards are proper connected
and if all seems to be ok, the DG board will need to be replaced.
If you dont have any repair skills I would recommend you to take you TV to a repair shop since this is complex repair
Jun 16, 2009 | Panasonic TH-37PX60U 37 in. Plasma HDTV
Bright Blue and Green screens seem to blink.
Do not use component video. Test S video or 3 rca's red black and yellow(video) , see if they work! you need all 3 inputs on component video, sounds like you may have the colors mixed, check all color coding slowly. Sometimes the comp video out can be too strong, try using a splitter , reduces signal by 3 db, try 2 then 3 in line. This is only a test. keep in touch...
Please rate!
Mar 31, 2009 | Televison & Video
COMPAQ PRESARIO DESKTOP PC SR1215IL. When switched on, cpu boots normal but no display on monitor. instead a sharp and bright blue vertical line appears for few seconds on the middle of screen. led of the...
tricky!! oh hi im Dyanne.. a totally unresponsive black screen can be th result of failure of th LCD or LCD inverter.( a specialized piece of electronics that energize th screen) to rule out th failure of th video display adapter or circuitry, try plugging in an external monitor..a standard pc monitor.. attached direct to th lappy. if it works, (as i susopect) th motherboard and video display are both working ok and its th LCD which is at fault. this can sometimes be repaired by a competent specialist. good luck xx
Dec 25, 2008 | Compaq Evo D300 PC Desktop
Sony kp-57wv600 tv turns on shows picture then blinks blue a few times and then shuts off....stnadby light blinks 7 times...whats the problem
Its either blue tube or bad componet on blue CRT board hertes how to know disconnect Blue CRT board connect to neck of blue tube turn set on see what happens if set come on and plays then this lets you know if it is a problem with tube/video ic on crt board. If set shuts back off different problem.
Dec 25, 2008 | Sony KP-57WV600 57" Rear Projection...
EMachines E19T5W Flat Panel Monitor - keeps blinking red, green, blue white lines
On the monitor below the screen has these fine pink and green lines blinking across the screen all the time on my laptop. Can you tell me how to fix it or solve this problem?
Aug 12, 2008 | E-Machines 19" Widescreen Flat Panel TFT...
Samsung VP-D101 Mini DV Digital Camcorder Logo
85 people viewed this question
Top Samsung Video Cameras Experts
Lawrence Oravetz
Are you a Samsung Video Camera Expert? Answer questions, earn points and help others
