I recently purchased a Fuji HDMI cable for a PS3 into a RCA HD projection television and the video works; however, no sound comes through, any suggestions?
hello! Have you tried to toggle "format" or "screen size"? On those sets non HD and HD settings could be adjusted separately. Try that, first. If no luck, try similar settings on PS3. I bet, you will be able to match screen format there, as well. To me it looks, like picture formats are mismatched. Also: try to use "component" cables, instead of DVI adapter cable, if nothing works. good luck, Alex.
I would suggest to leave your directtv hd/dvr box connected the way It is.
The HD Colorstream 1input on your TV should work just fine.
This TV does not have an HDMI input but you can buy an adapter and connect to DVI/HDCP IN and that might be able to get 1080i video resolution on your TV.
This is normal my friend. A dvi port can't use audio even if it is using a hdmi cable. A easy fix is to connect your A/V cable into your ps3 and connect the red and white cables next to your dvi cable or connect it to your stereo. After that go into your setting, go to audio setting, click on audio output, and select A/V cable. it should work after that.
First, contrary to popular opinion, HDMI cables connect to a tv are not the best way to connect the two. The HDMI technology has flaws that often shows up as sound problems.
If your TV has the capability for component connections, use them. It will take 5 cables, 3 for video and 2 for audio. You will get superior sound and video. The 5 cables terminate in RCA type connectors and are much cheaper than an HDMI cable.
I have sound on video 2, and when on a static channel but not on the usual channel 3 which is TV. Just stoppen working one day and cant figure it out... Please help!
