Power Up Problems
Laptop won't power up anymore. All I get is a flashing AMBER led on front panel - 9 flashes.
Please Help!
Cheers
Joe
  • Anonymous May 17, 2008
    computer will not come on.
  • Anonymous Apr 14, 2009
    I have the same problem but its a Dell Dimension 5510 Desktop, I think it's the motherboard,because when I take the battery out of the motherboard and disconnect power to the motherboard I can power it up again.
    Sergeant:
  • 319 Answers
Call tech support! That's why these people get paid. Sites like this wouldn't need to exist if they did their jobs correctly!
Posted on Mar 11, 2008
SOURCE:
Thought I should add more detail about what the laptop is doing. The laptop sat for a long time with a dead battery, because the power supply low voltage wire got chewed by one of our puppy's when it was...
from the web -
1 Removed the battery
2 Removed the AC power
3 Plugged in the AC power again
Note:- At this point the light from flashing amber light to solid green indicating AC Power
4 Plugged in the Battery
Note:- Solid green AC power light and Amber charge light
Oct 30, 2013 | Toshiba Satellite C655D-S5084 Laptop
I have a broken Dell Precision 470 Workstation. The symptoms are as follows: Won't power up; Flashing yellow power LED on front panel; Blank STR_LED on motherboard; Yellow AUX_PWR LED on motherboa
Flashing front powerlight is often a result of a faulty powersupply, try another powersully on the pc and see if the problem gets solved. I've seen a few of these cases personally.
Jul 01, 2012 | Dell Precision Workstation 470 (204816690)...
E system 1212 Laptop won't switch on. Power
Laptops are so integrated that usually a system failure that involves power issues such as in your case where you cant get it turn on with anything on the screen mean the mainboard (motherboard) is damaged. This usually leads to buying a new laptop or paying for the board to be replaced which usually costs as much as the laptop.
May 12, 2011 | Computers & Internet
Flashing power lights green and amber will not power up
Try removeing the battery form the laptop and using just AC porwer. if it still fails you may need to replace the motherboard. :(
Sep 14, 2009 | Compaq Armada M700 Notebook
Hp L1502 LCD blank, LED still flashes
just check ur lcd display cable and try to clean and c it it will cme
May 29, 2009 | Samsung SyncMaster 910T 19" LCD Monitor
Amber light on front of laptop flashes even with the power off
The Battery indicator LED is to the right of the power LED. Flashing AMBER indicates a fault with the Battery. To resolve, replace the system battery.
Apr 13, 2009 | Dell Inspiron 2200 Notebook
Amber light on front of laptop flashes.
Powers On if I plug it in, and power supply fan runs...
Think of blinking amber as the initial state of the LED. As long as the system is receiving power from a power source and can pass that power through the system board to the LED on the Control Panel it should, at least, blink amber. As a result, a blinking amber Power Button LED is a reliable indicator that the system is receiving power from a power source. This, in turn, tells us that the source and power cord are likely to be functional. The Blinking Amber LED also tells us that the power supply to system board connection is good as well as the connections between the system board, I/O Panel and Control Panel. Depending on the components installed and the condition of those components, the LED may progress past blinking amber and move to solid amber. If the LED does not progress past blinking amber it indicates that the system is not able to properly distribute power to the system components. This is discussed in the next section of the interaction.
It does not indicate that the power supply is bad. It simply indicates that, for whatever reason, one of the power supply 'rails' is not operating within its specified range or, simply, that there is a short somewhere in the system.
The LED state could be the result of a misconfigured or incorrectly installed system component. A bad drive, for example, may be shorting out one of the rails. Incorrectly installed memory can cause a blinking amber front panel power button LED.
Feb 05, 2009 | Dell PowerEdge 1800 Server
Flashing battery power LED
Try this
1. Remove the battery and the AC adapter. Hold down power button for 5 seconds. then insert the AC adapter only and see if you can power up the laptop. if it does power up, dont use the Battery anymore as it might be the cause of the problem
Apr 06, 2008 | HP Compaq nc6220 Notebook
Acer Aspire 3000 Series Power UP Problem
Mar 11, 2008 | Computers & Internet
Open Questions:
Computers & Internet Logo
89 people viewed this question
Ekse
Alun Cox
