Will not scan
My new F380 All in one will not scan.
What the !!!!!!!
    Sergeant:
  • 319 Answers
Call tech support! That's why these people get paid. Sites like this wouldn't need to exist if they did their jobs correctly!
Posted on Mar 11, 2008
SOURCE:
How do you scan with this printer using windows 7
Try Scanning with Windows fax and scan program
  1. Click the Windows icon (c01319360.gif ), click All Programs , and then click Windows Fax and Scan .
  2. Click New Scan .
  3. Make any desired setting changes, and then click Scan .
  4. (from hp.com):
Sep 28, 2010 | HP DeskJet F380 All-In-One Printer
Printer hp deskjet f380
If you have Vista as your operating system, Windows Vista provides a basic set of scanning drivers, also referred to as Windows Image Acquisition (WIA) drivers, that you can use as an alternative to scan a document when you cannot scan using the HP drivers.You can still scan with one of the following methods:
(Click here) workaround
Feb 10, 2010 | HP DeskJet F380 All-In-One InkJet Printer
How do i scan using a HP desktop F380
Deskjet F380 features a scanner within the upper portion of the device. "Scanning" an item describes the electronic process of converting pictures or text to data, then transferring that data to the computer as an image. Scanning an item into the computer is a simple task with the F380, the only limitation is the size of the item,
follow the steps below
Step 1
Turn the unit on by pressing the "On" button located at the top control panel. The control panel is located on the left side of the unit. The "On" button will illuminate to indicate that the unit is receiving power.
  • Step 2 Load the scanner with the item to be scanned. First, lift the lid of the F380 to the upright position to reveal the scanning surface. Place the item to be scanned face down onto the scanning surface. Position the item so that the edge of the item rests squarely against the front left-hand corner of the scanning surface, then close the unit's lid.
  • Step 3 Press the "Scan" button located at the lower left-hand corner of the F350's control panel to start the scan. If necessary, the scanning process can be stopped by pressing the "Cancel" button located just to the left of the "X" on the control panel.
  • Step 4 Save the scanned image to the computer when the scan is complete by clicking the "Accept" button on the window that appears on the computer's monitor.
  • Dec 29, 2009 | HP DeskJet F380 All-In-One Printer
    HP DeskJet F380 All-In-One Printer scanner does not work with vis
    Same problem with Xp and same printer, Cannot add printer in control panel , printers. Can only be installed with original software, Try also uninstalling all printer software plug in and when vista pick up new hardware install software from disk and not auto
    Aug 13, 2009 | HP DeskJet F380 All-In-One Printer
    I can print and copy, but not scan with HD F380 using Vista. Help
    Ensure any program that came with the scanner is installed on the computer and running (open the program).
    Jan 29, 2009 | HP DeskJet F380 All-In-One Printer
    Hp f380 all in one when scanning the image not clear its zooming
    i think your resolution setings is changeing.
    it is in software setings of resolution chagne t to 300*300 .
    Dec 29, 2008 | HP DeskJet F380 All-In-One Printer
    Scanning Problem
    Dear, just walk to the cyber cafe and download the driver for your HP Deskjet F380. The url address is http://www.nodevice.com/driver/Deskjet_F380_All-in-One/get39298.html.
    Regards,
    Rakesh Kumar
    Network Support Engineer
    Nov 11, 2008 | HP DeskJet F380 All-In-One Printer
    HP Deskjet F380 All-in-One Compatible with vista
    I had the same problem. I could print, but not scan.
    However, if you open up Paint and go to file and scan, it will scan your document. For some reason, using the scan button on the printer itself will not work with Vista, but using Paint will. I also heard that using Windows fax and scan will also work.
    good luck
    Nov 21, 2007 | HP DeskJet F380 All-In-One Printer
    F380 all-in-one scan problem
    I have this problem w/a different printer adding it to a computer w/OS Vista. Go to Start, All programs, Accessories, Paint and open that program. Click on File and then From Scanner or Camera. Make sure your all in one is turned on. Unfortunely, there is no fix to make the scanner button work if it is not compatable, such as my 'all in one' w/Vista. Hope this helps. Linda
    Oct 25, 2007 | HP DeskJet F380 All-In-One Printer
    Open Questions:
    Computers & Internet Logo
    22 people viewed this question
    Ekse
    Alun Cox
