Question about Kitchen Appliances - Others
Vintage Revere Ware Copper Clad 8 Cup Drip Coffee Pot
How do I make coffee in this pot? In which section does the water go and where do I put the coffee?
Need instructions or manual.
It has a copper clad bottom with 2 numbers on it. Can't make out what it says before this number 1st No. 2272609. The 2nd number says something then process patent no. 2363973. Would appreciate any help you can give me in how to use this coffee maker.
Thank you
  • BarbLutz55 Mar 11, 2008
    No answer from you folks yet. Don't know how to use your site very well, but I want you to know that this coffee pot is not electrical - that is why it is copper clad - for the stove top. An instructions for an electric pot will not apply.
    Thank you.
  • attack-cat May 11, 2010
    It's the same one I have listed in http://www.fixya.com/support/t675518-rev...
    I have a description there of it. Here it the description:
    The coffee pot has Patent 2272609 and the number 2363978 on the bottom. It has a small bottom part (like a pot) with a small pouring spout, then a middle piece fits in that about the same size with a funnel design on the bottom and little holes in the bottom, a flat metal thing with a flat metal stick in the center fits inside the middle part and it also has holes in it. and last is the lid. No glass perculator thing on it just a black knob.
Barbara,
Coffee grounds go in the top. (i use a filter paper also.) Install baffle with stem up. Assemble top to empty bottom section. pour boiling water into top. I use 4 cups water, 2 scoops chickory coffee. Let water trickle down into bottom. I put mine back through 3 times, black as tar. That is the advantage of this machine. I will never use another.........
Posted on May 16, 2008
    Sergeant:
  • 313 Answers
Vintage Revere Ware Copper Clad 8 Cup Drip Coffee  - 1702069062738080_1.jpg <-- if this is the coffee pot - it is a percolator, put the water in the Pot itself, and the coffee (with a filter) in the "basket" . The water begins to boil and "perk" up through the stem to the (you can see it in the glass bubble in the lid) and over the basket and your coffee, depending on how strong you want your coffee, is how long you let it perk.
Posted on Apr 03, 2008
  • Hollyecho Montgomery
    Hollyecho Montgomery Apr 03, 2008
    <-- <-- if this is the coffee pot - it is a percolator, put the water in the Pot itself, and the coffee (with a filter) in the "basket" . The water begins to boil and "perk" up through the stem to the (you can see it in the glass bubble in the lid) and over the basket and your coffee, depending on how strong you want your coffee, is how long you let it perk.
Looking for stem for a REVERE WARE 5 cup-84 percolator.
Posted on May 28, 2012
  • minni May 28, 2012
Http://www.fixya.com/support/t675518-revere_ware_old_fashioned_coffee_pot I have the same one and same problem.
Description: The coffee pot has Patent 2272609 and the number 2363978 on the bottom. It has a small bottom part (like a pot) with a small pouring spout, then a middle piece fits in that about the same size with a funnel design on the bottom and little holes in the bottom, a flat metal thing with a flat metal stick in the center fits inside the middle part and it also has holes in it. and last is the lid. No glass perculator thing on it just a black knob.
Posted on Jun 17, 2008
Barbara,
Make coffee in this pot everyday. Contact me. Salvage859 at aol dot com
    Master:
  • 788 Answers
Most cooktop drip coffee makers work the same way.
You boil water in the bottom part, the boiling water will go up the tube and go through the coffee which you put in the top part. If it doesn't have a built in filter then use the appropriate sized filter.
Does this answer your question?
  • Dean Joly
    Dean Joly Apr 03, 2008
    Some are not automatic though and you need to pour the boiling water into the top part over the coffee once it boils.
    Brigadier General:
  • 6,966 Answers
It would appear that you have a vintage coffee percolator. From my understanding it is basically, you boil the water in the bottom, grounds in the top half then when the water boils you pour it into the top and let it drip through the grounds.
Additional information that may be of help to you:
The Shine Shop now carries replacement parts for the classic Copper Clad Revere Ware. They also recondition old cookware and can provide most information regarding the older Revere Ware lines. They can be reached at 1-717-872-6884 or by email at theshineshop@verizon.net and/or their web site at mysite.verizon.net.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards.
Thank you for using FixYa.
    Scholar:
  • 117 Answers
Upon looking at the item itself...I see the measurement for coffee grind go in the top...water in the bottom.
Put on the stovetop, let it come to a hard boil for 3 mins...pull the pot off to the side and let it stand for strength and flavor ( meaning, the longer it stands the stronger the flavour)
You may want to add a pinch (very small) of salt..this will add to the flavour..
Start with 3 scoops of you favorite coffee, then depending on how strong or weak you like it, adjust accordingly.
~~Jasta~~
    Sergeant:
  • 319 Answers
Call tech support
Posted on Mar 11, 2008
    Guru:
  • 1,894 Answers
Please give model number sir
Posted on Mar 17, 2008
  • dewan nafees ahmed Mar 17, 2008
    with out the model number and make we cant find the instructions manual sir.
    so please cooperate with us
How to activate a 10 cup bunn coffee brewer model nhb?
I don't understand the question, but here is a try.
1 - put in two pots of water.
2 - put in third pot, the water should start coming out
Allow the water to heat (thirty minutes) then put coffee in filter housing, put in one pot of water, put empty pot on warmer, close lid, wait for brew cycle, enjoy coffee.
Feb 27, 2015 | Bunn 10 Cup Home Coffee Brewer
For a 30 cup pot how much coffee do you put in
According to West Bend...30 cups = 1 ¾ cups ground coffee; add more if you prefer it stronger.
Sep 26, 2014 | West Bend Vintage 18 Cup Aluminum Kwik...
No pot or instructions, how much water do you put in the coffee pot?Need a replacement pot for vp17 series. thank you
You should be able to pick up a replacement/new pot at your nearest Restaurant Supply store. Make sure you get a 64 oz./ 1/2 gallon pot.
Before plugging in your brewer, unscrew the sprayhead located just above where the filter basket sits and replace the basket, pour 3 pots of cold water through the opening on the top if the brewer is empty. This brewer has a reservoir that holds about 2 1/2 pots of water at brewing temperature when heated. Make sure you put an empty pot under the filter basket after pouring in the water. Water will flow from the brew basket when the reservoir has reached its capacity. Once water flows you can then plug in and energize your brewer and replace the sprayhead. It will take about 15 to 20 minutes for the brewer to reach brew temp, you will hear the heating stop. Put an empty filter and a dose of coffee (I recommend starting with a heaping measuring cup of drip ground coffee) into the filter basket, lightly shake it level, replace the basket and pour through 1 full pot of COLD water in the top. For best results pour the brewed coffee into a pre-heated thermal server if you plan on holding the coffee for more than 10 minutes or so.
Enjoy!
Jan 04, 2011 | Bunn VP17-1 Coffee Maker
Need to replace my spigot on my 30 cup revere ware coffee maker because it leaks. Where can I get one to "pop" into that hole so I can pour the coffee out of the pot into the cups.
I have a Westbend 24 cup coffee urn with a leaky faucet. I tried finding areplacement spigot for it but so far no luck. My spigot has a screw in the top that allow for disassembly. It looks to me that if I could get a replacement rubber O-ring I could fix it myself. Does anyone know where I could get this?
Thanks
Kelvin
kelvinlov@gmail.com
Sep 16, 2010 | West Bend (59055) Stainless steel 60-Cup...
Filter cone is full of hot water & thermo pot has about 5 - 6 cup
Te water fill lid is not closed or or the flow valve in the tank is plugged. Remove the basket and clear the hole in the bottom of it.. If new, return it to place of purchase.
Jun 22, 2009 | Black & Decker Programmable 8 Cup...
West Bend Lifetime Stove Top Coffee Maker This is a nice heavy stainless steel coffee maker, probably from the 50s or 60s. It has four parts; a carafe that sits on the stove, a piece that fits on that with...
Not to sound like a knw it all, but we have a pot just like this. You have to boil the water in a seperate kettle and pour it in the pot. This is a drip pot, not a perculator. It will make the best coffe you've ever had.
Jun 20, 2009 | Coffee Makers & Espresso Machines
The perfect cup!
When I brew coffee, I use a mild to medium columbian roast. I then use one tablespoon of coffee grounds for ea 2 cups of water as marked on the pot. The measure of coffee is the same whether you use the ground or the whole bean.
I always use fresh filtered water. Chlorine, flouride, and any other ingredient in the water affects the flavor of the coffee.
I stay away from the french roasts & dark roasts. they are very bitter and frequently taste like ashtray to me.
I assume that the coffee pot uses a 6 oz measure of water for their one cup of coffee.
I frequently check the drip area for coffee sludge buildup. That also affects the coffee flavor if the coffee sits at all.
Hope this helps
Jan 13, 2009 | West Bend 55108 Espresso/coffee Maker
How to make coffee with 101-cup percolator urn (Regalware)?
Simply fill with COLD water to the number of cups desired.
Place the stem and basket in the pot and put one 8 oz cup of coffee for every 20 cups of water into the basket...when doing 100 cups I add an extra 12 oz of coffee for a good coffee flavor.
Place the perforated lid on the coffee basket that is in the pot (if there is a lid--some do not have a lid). Put the cover for the coffee pot in place.
Plug in.
Turn on if there is a switch.
Give these large pots about 1 minute per cup, brewing time...that is a little over an hour usually to brew 100 cups. The coffee maker will percolate with the water coming up through the stem and over the coffee as the water heats. Usually there is an indicator light that comes on when it is finished.
If holding the coffee for awhile, it tastes best if you remove the stem and basket and it will maintain the heat without doing more "perking" and becoming stronger or bitter.
Be sure to wash it out and dry it well, leaving the lid loose or upside down for storage so that the pot doesn't become pitted. Blessings, Louise
Nov 14, 2008 | Regal Ware 426473 Black Satin Coffee Urn...
Revere Ware old fashioned coffee pot
1) Boil the water you’ll need in another pot.
2) Put 1 tablespoon of ground coffee (drip grind, not percolator grind) in the reduced diameter, perforated bottom of the brewing chamber.
3) Put the grind/water separator (the perforated, flat handled plate with cup markings on the handle) in the Brewing Chamber, over the coffee grounds.
3) Put the Brewing Chamber on top of the Holding Chamber.
4) Pour the appropriate number of cups boiling water into the brewing chamber; put the lid with the black knob on the brewing chamber.
5) Let the water drain through the coffee grinds (5-10 minutes).
6) Remove Brewing Chamber, clean out the coffee grounds, and replace the lid on the holding chamber.
7) Enjoy your coffee! Keep it warm on the stove at LOW heat setting.
for the most information on the Revere cookware lines, go to: http://mysite.verizon.net/vzeoywo4/theshineshop2/id1.html
Charlie
Jun 16, 2008 | Coffee Makers & Espresso Machines
Kitchen Appliances - Others Logo
2,687 people viewed this question
Top Kitchen Appliances - Others Experts
Angel Joseph Jr.
Angel Joseph Jr.
Are you a Kitchen Appliances - Other Expert? Answer questions, earn points and help others
