Question about Casio DW9052-1V Wrist Watch
Hourly alarm/beep When changing my watch for daylight savings I changed a setting and my watch beeps every hour on the hour. How do I turn this off?
    Sergeant:
  • 319 Answers
Call tech support! That's why these people get paid. Sites like this wouldn't need to exist if they did their jobs correctly!
Posted on Mar 11, 2008
G-shock casio 5034 won't beep when i need to change daylight saving
Module No 5034 won't beep except for alarm use.
Jan 23, 2013 | Casio Watches
How do you stop the hourly beep on my watch and turn off the alarm?
press in all buttons at once hold them.should beep once or 5 times. resets everything. then re set time.www.watchrepairbattery.com
Mar 22, 2012 | Invicta Ll Collection Multi Function Black...
How to set the date
Time and date setting
are only necessary if automatic setting by radio broadcast is unsuccessful.
To set time, date, and options:
1) With time and day showing, press and hold SET.
2) City code flashes. Press START/STOP to select city that represents your time zone. See table below
for city codes.
3) Press MODE. DST (daylight savings time) setting flashes. Press START/STOP to select AUTO (obey
setting in radio signal), ON, or OFF (disregarding setting in radio signal for ON/OFF).
4) Press MODE. Hour flashes. Press START/STOP to change hour (including AM/PM); hold button to
scan values
5) Press MODE. Minutes flash. Press START/STOP to change minutes
6) Press MODE. Seconds flash. Press START/STOP to set seconds to zero.
7) Press MODE. Year flashes. Press START/STOP to change year.
8) Press MODE. Month flashes. Press START/STOP to change month.
9) Press MODE. Day flashes. Press START/STOP to change day.
10) Press MODE. Date flashes. Press START/STOP to select M-D (month-day) or D-M (day-month) format.
11) Press MODE. Hourly chime setting flashes. Press START/STOP to select ON/OFF. When ON is
selected, watch chimes on every hour.
12) Press MODE. Button beep setting flashes. Press START/STOP to select ON/OFF. When ON is
selected, watch beeps for every button press.
13) Press SET, at any step, when done setting.
Press and hold MODE to switch between 12- and 24-hour time format.
Press SET to view date. Year is at top of display and date is below.
Press RECEIVE to view current city.
Press and hold RECEIVE to begin manual reception of time signal, as described in ATOMIC CLOCK
SYNCHRONIZATION section.
(from the User's manual)
May 03, 2011 | Timex 1440 Prizefighter 53032 Sports...
I need the manual of breil milano shosholoza.the model is bw0480
The crown has 3 positions.
Normal screwed down.
First pull out position.
Second pull out position.
Setting the Time:
Pull out the crown to position 3.
Rotate the crown to set the exact time.
Ensure that you are in the daytime12 hour segment by allowing the hands to pass 12 o'clock and notice if the date moved on or not.
If the date changed, then you will need to advance at least 2 hours before moving on to set the date.
If you do not need to change the date, return the crown to position 1.
Setting the Date:
DO NOT DO THIS IF THE WATCH IS BETWEEN 8pm & 2am
Pull crown to position 2.
Rotate the crown clockwise to set to the correct date.
Return the crown to position 1.
Setting the Alarm [12 hour]
Pull the crown to position 2.
Rotate the crown anti clockwise to move the alarm hand to the desired time.
To activate the alarm, press the 8 o'clock button. You will hear 2 beeps.
To deactivate the alarm, press the 8 o'clock button. You will hear 1 beep.
NB If the alarm is not cancelled while it sounds the first time, it will repeat again in 2 minutes time. The alarm sound last for 15 seconds. If the alarm time coincides with 1 beep of the countdown, the alarm function will be cancelled.
Battery EOL [End Of Life]
The Swiss ISA 8270 movement uses a 395 cell and will signify a low power state by advancing the small seconds hand 4 steps every 4 seconds.
Setting the Countdown
You can specify a countdown of between 1 and 10 minutes.
Press the 4 o'clock button to enter setting mode. You will hear 1 beep.
Press the 4 o'clock button to move the central timing hand successively to the desired countdown time.
Wait 3 seconds for the watch to automatically exit the setting mode.
You can change the duration of the countdown [except in the last minute] at any time.
e.g. If the countdown is set to 10minutes, and you now want to change the countdown to 9 minutes, press the 4 o'clock button. The hours/seconds counter sub-dial will perform one complete turn and then stop at 60, before continuing.
Activating the Countdown:
Press the 2 o'clock button to start the countdown. You will hear 2 beeps.
When the countdown begins, the hour/seconds counter sub-dial indicates the seconds with 1 step every 2 seconds, and the central timing hand indicates the minutes with 1 step being 2.4 seconds.
Countdown tone:
There are 2 beeps every minute.
in the last minute:
50 seconds=1 beep.
40 seconds=1 beep.
30 seconds=2 beeps.
20 seconds=2 beeps.
10 seconds and less=1 beep every second with zero being 1 second long beep. Timer function automatically starts.
Timer:
After countdown has finished the timer starts automatically.
The central timing hand indicates the minutes with 1 step every 12 seconds. The hour/minutes counter sub-dial indicates the hours up to a maximum of 96.
Press the 4 o'clock button to see the timer seconds [display lasts up to a minute].
Press the 4 o'clock button to see the timer hours.
The timer has a maximum time of 96 hours [4 days] after which the hour/seconds sub-dial counter will stay at 0 and the central timing hand will stay at 12.
Start/Stop Timer:
Press the 2 o'clock button to stop the timer. You will hear 1 beep.
Press the 2 o'clock button to resume the timer. You will hear 2 beeps.
Setting the Countdown & Timer:
Countdown reset:
Press the 2 o'clock button to stop the countdown. You will hear 1 beep.
Press the 4 o'clock button to reset.
Setting the Timer:
Press the 2 o'clock button to stop the timer. The hour/seconds counter sub-dial will show the elapsed hours and the central timing hand the elapsed minutes.
Press the 4 o'clock button to view the seconds elapsed on the hour/seconds counter sub-dial.
Resetting the Hands:
If the hands do not zero correctly, which might occur after a battery change or a violent shock, you can make adjustments by doing the following settings as long as the countdown is not in operation.
To correct the hour/seconds counter sub-dial, pull the crown out to position 2 and wait 1 second.
Press either the 2 or 4 o'clock button; the central timing hand will turn and stop [not necessarily at 12].
Press the 2 o'clock button to increment the hours/seconds counter sub-dial hand to position it at 60.
To correct the central timing hand, press the 4 o'clock button to increment the hand to the 12 position.
If the battery had been replaced, the central timing hand defaults to the 10 minute position. If the battery had not been replaced, the central timing hand will return to the previously set position.
Oct 05, 2010 | Watches
I can't turn off the hourly beep on my Activa watch.
If you haven't got a manual and there are no stockists in your locality, then try the following (based on other similar watches).
Press the mode button several times until you come the alarm function. There should be an hourly alarm or beep alarm or something similar (they are likely to be abbreviated), so you may have to play detective.
When you think you have the correct setting (beep ON?) press one of the other buttons to see if they change ON to OFF.
When you are satisfied with the setting press the mode button to return to normal operations.
Good luck.
Jan 28, 2010 | Activa Watches
Cannot change from 24 hour to 12 hour also did not change to daylight savings time
To change from 24 hour to 12 hour, you hold down the "Mode" button until it switches from 24 hour to 12 hour or vice versa. To change the time zone, you hold down the "Set" button until the time zone that you set it in flashes (like "LAX" on my watch). Then you press the "Receive/Start/Stop" button to choose the specified time zone you want. To set for daylight savings time ("DST" on the watch), after holding the "Set" button and having the time zone flash, you could press the "Mode" button. It will give you a few options for the daylight savings time (Auto, On, or Off). I chose the "On" option, which immediately changed for daylight savings time. If you manually want to change the time, you could hold down the "Set" button and keep pressing the "Mode" button until the time starts flashing on your watch, then pressing the "Receive/Start/Stop" button until you change it to the time that you want. You could also set the watch to beep or chime after pressing the set button if you wanted to know that piece. You hold down the "Set" button when you are done to get it to stop flashing. These instructions worked for my Timex T5G341 Universal Radio Control Watch. I hope this helps.
Mar 08, 2009 | Timex T5G341 Sports Radio Control Watch
How do i make my watch beep by the hour
Press and hold SET, then press START/STOP. This should turn the chime on. Press it again to turn on the alarm.
Dec 27, 2008 | Timex 1440 Nylon watch
Innovage Gear wristwatch beeps every hour
To turn off the hourly beep: While holding the lap/reset button down, press the mode button. When all 7 day flags show, the hourly chime is on. When no day flags show, the chime is off.
Mar 11, 2008 | Watches
How to set
in order to unset the military time on the watch you must hold down the two top buttons until the the 12 hour format comes back. in order to turn off the alarm you must hold down the two right buttons until they beep..and then the alarm will go off
Jul 12, 2007 | Timex 1440 Sports Aggressor 56014 Wrist...
Casio DW9052-1V Wrist Watch Logo
503 people viewed this question
Top Casio Watches Experts
Kazim ERGUNEY
Kazim ERGUNEY
Ansel Alberto
Ansel Alberto
Are you a Casio Watch Expert? Answer questions, earn points and help others
