25" Philips Magnavox having problems with picture
I have a Philips magnavox 25"; tube tv (model #25T S52 C321)when turned on it has horizontal lines for about 5 minutes and then it goes to the picture and then the picture will frizzle every 10 to 15 seconds.
    Sergeant:
  • 319 Answers
Call tech support
Posted on Mar 11, 2008
1995 Magnavox tv (model TS2560) Horizontal control WACKY
No, it is most certainly not worth fixing. In fact, it is worth nothing - even if it were working great. Probable cause: an obsolete electrical component. Cost: no TV tech will touch it. Sorry. Suck it up and buy yourself a moderately priced TV.
Jul 28, 2017 | Philips Televison & Video
Rolling horizontal (colored) lines instead of picture; audio OK
This problems it pretty easy to fix.Just require take the tv apart.Resolders all the holes in the video board that connected to a long CRT tube neck.Should cost $50 -$75 more than that u are being cheated.
Dec 04, 2009 | Philips Magnavox 20MT4405 20" TV
Philips Magnavox 20MS3442/17 Green Line
If this is a tube type or crt type. Your vertical circuit has a problem. Could be the vertical IC loose connection on its board. Or the vertical ic itself is faulty. If just resoldering or refluxing of its pins doesn't help check some minor cmponent within vertical circuit. Or the vertical ic is defective already.
If your not inclined on electronics never do the repair itself, nasty voltages might caught you.
May 11, 2009 | Philips Magnavox 27MS343S 27" TV
Magnavox model#55p288
I doubt its the picture tube, that model is most likely needing a new deflection board.
Sep 05, 2008 | Philips Magnavox 51MP392H Rear Projection...
Philips Magnavox(model 9P6034C102 )
This is any easy fix. Goto www.magnavoxhelp.com to get a repair kit. Its a common problem on some of the older Magnavox projection TV sets.
Jul 30, 2008 | Philips Magnavox 9P6034C 60" Rear...
Horizontal lines
may be vertical deflection circuit bad capacitors and is a job for experienced tech
Apr 01, 2008 | Philips Magnavox MS2530C 25" TV
Philips magnavox 32" TS3260C1
Sounds like retrace lines. Leaky caps or worse can cause this.. Are you getting any vertical foldover at the top of the screen?
Jan 18, 2008 | Philips Magnavox 27MS343S 27" TV
Tv showing blue screen with flyback lines sound ok
Flyback lines? Is the picture all white with no brightness control with faint horizontal faint lines? If this is what you are saying, the screen voltage could be bad, and if thats the case, the picture tube or the flyback itself could be bad. You could also have a bad connection on the crt socket
Dec 27, 2006 | Philips Magnavox 20MT133S 20" TV
25TS56C22125
The description of the problem points to the picture tube being bad because of the rainbow colors,as far as the white lines you might have an open resistor in the crt board,a qualified technician should take care of the problem if the set is repairable and He will know as soon as he sees it.Good luck.
Sep 17, 2006 | Philips Magnavox 27MS343S 27" TV
Televison & Video Logo
90 people viewed this question
Top Televison & Video Experts
Marvin
Marvin
