Question about Hannstar I-Inc TW-191D Monitor
Monitor Have a I-INC TW191D monitor and the screen is stretched. It also is very small when I re-boot my computer and I have to turn the monitor off and on to get it to the correct size.
  • hgirling Apr 04, 2008
    having the same problem and cant find the drivers to fix,....any suggestions?
  • ti_jean_54 Jul 14, 2008
    moniter keeps suddenly changing to lower setting like 8-bit,smaller display size.doesn't matter how many times I reset it it keeps doing it.Tried updating drivers,Tried disk that came with monitor,reset all admistrator people settings the same for moniter,updated NVIDIA Geforce 2 MX/MX400 Device driver.
    Sergeant:
  • 319 Answers
Call tech support
Posted on Mar 11, 2008
The problem started with frequent occurances of "white screen." I am not a computer geek by any stretch of the imagination but I was able to get it working several times by rebooting, turning...
Suggest connecting monitor to another computer and confirm defect. If problems reoccurs and cables are confirmed OK replace.
dims-mvjfcvkh3nvffkljjmexfvsy-5-0.jpg Common problem capacitors failing in computers and components.
Soyo 2286 LCD Monitor Repair Tutorial
Jul 04, 2017 | Soyo DYLM2286 Monitor
Tip
You may be on to something :) I bought my I-inc TW191D two years ago from...
Don't buy and products from this company they get cheap parts from companies going out of business. They are built to break down as soon as the warranty is getting ready to expire! Hannspree,i-Inc,Hanns.g
on Jul 05, 2009 | Microsoft HannsG HU171D 17" LCD Monitor
My TW191D monitor went blank with a flashing green light. I changed the cable nothing. I tried the monitor on 2 other computers and it work fine. It still will not work my computer.
Since it works with other PC then the problem is in your PC, it can be video card, RAMs. Try reseating the RAM and teh video card. iT can be *********** board also. Need more troubleshooting in your PC.
Failed TV and Monitors: http://s807.photobucket.com/home/budm/allalbums
http://en.wikipedia.org/wiki/Capacitor_plague
Sep 16, 2010 | Hannstar I-Inc TW-191D Monitor
Fuzzzy noise then blank screen....
Sounds to me like the power board may be bad on that monitor, espeically since it made funny sounds and usually bad transformers will make those types of sounds.
Make sure you don't have any bent pins on the vga cable and also hook up the monitor directly to a wall outlet to be sure a surge protector isn't causing problems.
Now hook up the monitor and also make sure your computer is turning on and booting up cause if the computer is not running properly then that could cause no video as well.
If you still have no video, then go ahead and hook up a known working monitor to the computer, if you get video with this monitor but not the original then you know that the original monitor is bad. If the new monitor gives you the same symptoms then it could be a problem with the video card or motherboard issue if your not getting any video from the computer at all.
Jul 05, 2009 | Hannstar I-Inc TW-191D Monitor
My TW191D Monitor will not power on. It was sudden and there was no indication that there was a problem developing. It happened after a power outage, but not directly after it. Can anyone tell me what they...
Maybe bad caps (capacitors) you need to be familiar with high voltage(200VDC iguess, here it is 400VDC) to do anything of your own.
It would be nice if all badcaps are bulged/leaking. Changing the lamps is a pain in the ass, i will try it myself with an 191d. But i have tried first the power supply with multimeter capable of 100kHz AC 200mV range. Better if you borrow an ESR meter capable of in circuit measurement and test all condensators.
Allways discharge, disconnect from pc, switch iMonitor on and pull wall plug, push ON button for safety. My 400V capacitor is then down to 7VDC (germany 230VAC mains). Or wait for 30 min, (i am not patient enough for that).
http://www.badcaps.net
Mar 09, 2009 | Hannstar I-Inc TW-191D Monitor
Monitor takes up to and over an hour to boot up !
Sooner or later it will not work at all. Time to go shopping - not worth fixing. Go ebay for great prices on used/new units. eBayeBay
Sep 15, 2017 | Hanns.G Corporation JW-199DPB 19" LCD...
INPUT SIGNAL OUT OF RANGE
some how your screen resolution has changed above or below what your monitor can display. you need to boot your computer using another monitor that can work with the resolution your computer has switched to(i used a spare crt monitor when it happened to me) change your resolution in display properties to a normal level like 1027x768, and while the computer is on swap the monitor cables to verify the lcd is working.
It is perfectly safe to unplug the video cable and plug it back in while the computer is turnned on.
Dec 26, 2007 | Relisys TL775 17" LCD Monitor
Hansol 730E CRT monitor
REPLACE THE BOOSTER C 5,6nF-1600V
Oct 18, 2006 | Hansol 730E 17" CRT Monitor
Hannstar I-Inc TW-191D Monitor Logo
160 people viewed this question
Top Hannstar Computers & Internet Experts
 Russ Hill
Russ Hill
memman
memman
Level 1 Expert
Are you a Hannstar Computer and Internet Expert? Answer questions, earn points and help others
