Replacement cable Need 9 pin cable for Durabrand PVS1970.
  • leach4578 May 24, 2009
    I need a 9 pin cable for a durabrand PVS 1970
    Sergeant:
  • 319 Answers
Call tech support
Posted on Mar 11, 2008
SOURCE:
Were can i buy 9 pin cab;e
Shop for 9 pin cable on Google
9 pin serial cable ' Staples®
www.staples.com/theme_9-pin-serial-cable
Staples Inc.Items 1 - 18 of 8325 - 9 pin serial cable (8325 items found) .... Professional Cable (9); Voxx (9) ..... QVS 4.5' USB/DB9 Male to Female Serial Adapter Cable, Black.
Sep 25, 2015 | Video Cameras
Missing DC 9 volt cord for durabrand 1700 dvd portable player
you make new 9 volt charger purchase new changing pin compatible 1700 dvd player and operate it
May 20, 2012 | Durabrand DUR-1700 Portable DVD Player
HST-221 Sony Stereo Component system - Lost System Control Cable
This is a long shot go to www.ebay.com Type: make and model and scroll through the listing.
May 18, 2012 | Audio Players & Recorders
I need a EZ view 9 pin monitor cord for a Durabrand PVS 1966 portable DVD player
Suggest you contact Vince at "Mr Television". You can find him thru Ebay.
It's likely they will sell this part at a very good price.
Nov 17, 2009 | Durabrand PVS1966 Portable DVD Player
I would like to change regions on my portable Durabrand DVD player model PDV-722
Alright, just follow these steps and let me know if you have any problems or questions
  1. Power and switch on the Durabrand DVD player.
  2. Open the DVD disc tray tray or lid.
  3. Press Stop.
  4. Press 3 - 5 - 9 - 7 (3597 in sequence). Can be done on remote control.
  5. Hidden DVD Region menu appears. Select region 0 or 9 using up or down button on remote control
  6. Press OK.
  7. Close the disc tray and press Standby on the DVD player front
Dec 19, 2008 | Televison & Video
Connection cable for the to moniters
This is custom cable, I called a company that sells AV cable, they say they could make a custom one for around $35.
Jun 27, 2008 | Durabrand Portable DVD
Need code for durabrand portable dvd player
  3. Press Stop.
  5. Hidden DVD Region menu appears. Select region 0 or 9 using up or down button on remote control.
  6. Press OK.
The above unlock DVD player region code trick should works on models including Durabrand DVD-1000, Durabrand DVD-1005, Durabrand DVM1418c, Durabrand LCDTV *** DVD player model PVS 21175S1 and others DVD players from Durabrand.
If the above unlock region code hack doesn’t work, or if you’re using Durabrand Car DVD Player model PVS1966, Durabrand PVS1960, Durabrand PVS1680, Durabrand PVS1970, Durabrand PVS223, Durabrand STS75E, Durabrand Dual-7B or Durabrand Dual-7BL, try the following unlock code instead.
  1. Power on the DVD player.
  2. Open the DVD disc tray or lid.
  3. Press 8 - 1 - 3 - 2 - 8 (81328 in sequence) on remote control.
  4. In DVD region code menu, press Enter until come to region 9 (or 0)
  5. Press Play.
  6. Close the DVD tray or lid.
For Durabrand Dual-900, try the following DVD multi-region or region free unblock sequence instead.
  1. Press Open to open disc tray.
  2. Press Clear.
  3. Press 1 - 3 - 6 - 9 - 0 (13690 in sequence).
  4. Press Standby button. After pressing, the DVD disc tray will close and DVD player will switch off).
  5. Press Standby button again to power up the DVD player.
Note: To set back the DVD player to region 1 if you’re using above unlock hack, simply press 13691 in sequence. The 0 or 1, the last digit in the key sequence is actually the digit to determine which region code you’re going to set on the DVD player. You can set to other region code by changing the last digit to 2, 3, 9 or other valid region code number.
For Durabrand DP305, try the following DVD region code unlock hack instead.
  1. Turn on the DVD player.
  2. Press Open/Close button to open the disc tray.
  3. Press Setup.
  4. Press 8 - 8 - 8 - 8 (8888 continuously).
  5. Press Next.
  6. Go to “Version and select a region code. Select 0 for all region or 9 for region free.
  7. Press Play.
The below trick should be able to unlock the region restriction on Durabrand DUR1700 DVD player.
  2. Press Setup.
  3. Go to “Preferences”.
  4. Press Play.
  5. Enter 2 - 5 - 1 - 5 - 3 - 5 (251535 in continuous sequence of keys).
  6. Press Left, Down.
  7. The current region code will be displayed.
  8. Press 0 for region free.
Note that if you select “Region 0′ which allows DVD players to plays all DVD-Video discs from Regions 1-6, some DVDs which are incorporated with “Regional Coding Enhancement” or RCE protection system will refuse to play in such machine.
Jun 05, 2008 | Jensen JR400 Remote Control
Monitor to monitor 9 pin. rounded ends cable.
www.18002526123.com or call the number. I found this in the manual. The cables are called EZ View cable (122-004020-208)
Dec 21, 2007 | Durabrand PVS1966 Portable DVD Player
Durabrand 7" Dual Screen Portable DVD player with game system
uneed a connectot bus for connecting u check how many pins are their say so many pin cable
Nov 07, 2007 | Durabrand DUR7 Portable DVD Player
Televison & Video Logo
Top Televison & Video Experts
Ekse
