Question about Sony KV-32S26 32" TV
32 inch sony TV flat screen
This TV i have to press the power button for a several times like for 5 minutes then it comes on please help me to solve my problem thanks
  • 42 Answers
On the consoles the power switches tend to wear out, you can either bring it to a repair person to replace the module or get a remote. At this point in time it is usually worth your while to find a way to get around the problem until you are ready to upgrade your television to digital. Repair $50-$100 and not worth it.
Posted on Mar 11, 2008
    Sergeant:
  • 319 Answers
Call tech support
My led emerson 32 inch flat screen will not power on manually even! red light comes onand flashes 5 times then the red light just stays a solid red and the tv never powers on......nothing! tried 2 ways of...
It has gone into safe mode as an internal fault has been detected you need to take the back off to repair or replace board's up to and including the screen
Aug 15, 2017 | Emerson Televison & Video
My samsung t.v. 52 inches will not come on it
My tv is brand new samsung 32 inches lcd. I accidently press power button several times and now i dont see any red dot. when I use my remote control, i see red dot but thats all
Jun 19, 2010 | Samsung LN52A850 52 in. LCD HDTV
I have a sony trinitron XBR 32 inch... The pip was turned on by accident, but i don't have the original remote. How do i turn off the PIP? Thanks in advance.
pls. use remot menu key and open main menu use DW key and select system menu see the PIP option is "ON" set option is"OFF" .
See the PIP screen is clear.
Oct 20, 2009 | Sony FD Trinitron WEGA KV-32FS100 32" TV
My tv takes like ten minutes untill it's turning on,why?
Replace any swollen capacitors in power supply.
Apr 24, 2009 | Televison & Video
ILO FLAT SCREEN REMOTE CODE
Please follow the steps below to program your remote control to equipment other then your DISH receiver:
Note: If you start this procedure and at any time and do not press a button within 20 seconds, the remote will end the procedure automatically. Simply start over again. Use the TV button for your TV, the VCR button for your VCR or DVD player. These Mode buttons are located at the top of your remote control.
1. With the desired equipment on, press and hold the correct Mode button until all mode button backlights illuminate, then release.
2. Press the numbers 5-0-0 on the remote control.
3. Press the Pound (#) button on the remote.
4. Press and hold the correct Mode button until all mode button backlights illuminate, then release.
5. Press and release the Power button on the remote control.
6. Press the Up button once a second while pointing the remote at the desired equipment. If the code for the equipment comes up, the equipment will power off.
7. Press the Pound (#) button. If the code entered is valid for the remote, the mode light flashes three times.
8. To verify the code works try several different functions for that equipment. Let me know if this helps and please rate this solution. lone99star
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/jason_77a19afa8d604dee
Jan 12, 2009 | iLO 2600 Television
Sony Plasma TV
I had this same exact issue yesterday. I own the same TV model and here is what SONY had me do to get the picture back. Ultimately the picture comes back, but it will be very dim and needs repair. Most likely a power supply issue. Try these steps:
-Press power off or leave with standby light on for 5 minutes (wait the full 5 minutes)
-Unplug TV / Press top buttons 5 times each to remove static from system boards (yes, each button 5 times each)
-Wait one full minute and plug TV in and press power on
Jun 12, 2008 | Sony FWD50PX2/S 50 in. Plasma Television
Picture stays on black
Jun 03, 2008 | Sony FWD50PX2/S 50 in. Plasma Television
Sony Trinitron color TV 36 inch
hello,
You should examine the input power of the TV. If you dare to open the back of the TV You should examine the by using the tester to test the continuity of the voltage input of the TV. i guess voltage regulator need to be tested.
Be careful high voltage inside the TV.
The best way is to contact the vendor of the TV or sony service center in your area.
may this help,
melnavz
May 12, 2008 | Sony FD Trinitron WEGA KV-36HS510 36" TV
36 inch sony TV flat screen
Good day.
Flyback could sometime be a problem but seldom that its the source. Have your circuits be checked first particularly the vertical section. Also, check on the supply of your system IC. there may be some imbalances there.
Response is highly appreciated.
chris
Mar 18, 2008 | Sony KV-36FS12 36" TV
Automatic wake up call
i dont know the model of the lcd but i will try help, click the menu button on the lcd or the remote , look for something that say's Timer, Wake up , Alarm , Auto on , Auto power , Auto Switch , if you find any of these option's play around with the setting's there should be a clock type thing to change and a off / on , tab to select , it also maybe under the time/clock options , otherwise on the remote look for a button that when u press, on the screen you will see something like 5 hours, 6 hours, or any time /clock looking display that comes up on the screen, and keep pressing it till it says off or -- , or zero ,
Good Luck
Dec 22, 2007 | Televison & Video
Sony KV-32S26 32" TV Logo
90 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
