Question about NEC Electra Elite 32D-1 Corded Phone
Handset is muted,
The main operator's handset is muted. Customer claims they press Feature and a 3 digit code to resolve but they do not know the code. Is there another way to resolve this?
Please respond to patti318@optonline.net
    Sergeant:
  • 319 Answers
Nope.....call tech support
Posted on Mar 11, 2008
How to edit speed dial feature KX-DT333
To Program:
Lift handset. Press * 3 0 , then enter the desired 2-digit code (00-09), enter the line access code (generally “9”) followed by the telephone number, then #.
To Use:
Lift handset. Press AUTO DIAL/STORE * plus the 2-digit code (00-09).
To Use System speed Dial:
Lift handset. Press AUTO DIAL/STORE plus 3-digit (000 - 999)
The User Guide can be found at the link below. Hopefully this helps.
http://www.manualslib.com/manual/853264/Panasonic-Kx-Dt333.html
Jul 23, 2016 | Panasonic Lands Phones
How do I turn the ringer on, on the handset?
Press program/mute button to confirm and you may program the following items: Set Language, Handset Name, Ringer Tone, Ringer Volume, Message Alert, Ring To Answer, Security Code, VIP Melody, Key Tone, Audio Predial, Vibrate Ringer, Area Code, Tone/Pulse, Registration, Deregistration and Default Setting.
Ringer Volume
From the Handset Setup Menu:1. Press the caller ID-volume ( 6 or 5) button to scroll to the RINGER VOLUME sub-menu.
2. Press program/mute button to enter the menu. SET RINGER 1HI 2LOW 3OFF shows in the display.
3. Use the touch tone pad on the handset to select 1, 2or 3, or use the caller ID-volume ( 6 or 5) button to scroll to your selection. HI is the default setting.
4. Press the program/mute button to save your selection. You will hear a confirmation tone and the new volume setting shows in the display.
NOTE: If you turn the ringer OFF, the ringer off icon shows in the display.
May 27, 2016 | Uniden Cordless Phone
Volume on G E model 21028GE3-4
To adjust the speaker volume, press up/down on the base unit.
To change the ringer volume:
Make sure your phone is OFF (not in talk mode).
Press the MUTE/PROG button to go to the main menu.
Press CID/VOL (up or down) button to scroll to "HANDSET SETUP".
Press MUTE/PROG button to confirm.
Press CID/VOL (up or down) button to scroll to "RINGER VOLUME".
Press MUTE/PROG button to enter the menu. "SET RINGER 1HI 2LOW 3OFF" shows in the display.
Use the touch tone pad on the handset to select 1, 2 or 3, or use the CID/VOL (up or down) button to scroll to your selection. HI is the default setting.
Press the MUTE/PROG button to save your selection. You will hear a confirmation tone and the new volume setting shows in the display.
To change the receiver volume: When the handset is ON (in talk mode) you may adjust the receiver volume by pressing the CID/VOL (up or down) button.
If you need a manual, you can download one here.
Oct 06, 2011 | GE 21028GE3 Cordless Phone
I have lost my manual and i dont know how to record a personal message on my answering machine and how to enter the code to retrieve my messages from another phone.
From your handset, you just have to press the mute button, your phone should start telling you the time, date, ect. press the #5 key and then the #8 key and start recording your message. When finished press the # 8 key again. Hope this helps
Mar 21, 2011 | Uniden DECT 6.0 Cordless Phone ID
System error #1 Panasonic kxtg2770
1)On handset, press MENU, 0, 0, 1.
Handset display shows as follows.
*Skip this step when handset already shows as above.
2) On base unit, press LOCATOR for 3 sec until CHARGE LED flashes.
3) On handset, press OK button. Then wait until the handset display changes as follows.
If you receive an error message indicating the maximum number of handsets have been registered, you will need to deregister the handset from the base unit, then try to register again.
*If this does not work, your unit is defective. Please send your unit for service.
Panasonic Services Company Customer Servicenter
Suite B 4900 George McVay Drive
McAllen, TX 7850
McAllen, TX 7850
1) Press FUNCTION on handset. Then, using the Navigator key, press Down (V) 4 times, Right (>) 1 time, Down (V) 7 times, Right (>) 2 times.
2) On base unit, press MUTE. (MUTE LED flashes.)
Dec 04, 2010 | Panasonic KX-TG2770 Phone System w/...
I can't change the time.
Go to the main phone and …
1) Remove the handset
2) Press feature
3) Press speaker
4) Press 3
5) Enter the time using military time (e.g. for 2:05 pm, enter 1405)
6) Return handset
Jun 23, 2009 | Telrad Basic Phone
Cannot program, menu stuck on Spanish, cannot access main menu from mute/ok button
I know this should be a MUCH more techie answer, but have you tried just asking a nearby Mexican to help you? Just a thought.....
You say you cannot get to the menu from the mute/ok button?
What happens instead?
FROM DA BOOOK looks pretty clear to me.
Handset Setup
1. Make sure your phone is OFF (not in TALK mode).
2. Press the mute/menu OK button to go to the main menu.
3. Press CALLER ID-VOLUME ( 6 or 5) button to scroll to HANDSET SETUP.
4. Press mute/menu OK button to confirm and you may program the following items: Language, Handset Name, Ringer Tone, Ringer Volume, VIP Melody, Key Tone, Set Day/Time, Equalizer, Area Code, Tone/Pulse, Registration, Deregistration and Default Setting.
NOTE: During programming, you may press the END/cancel button at any time to exit the sub-menu and return to the menu.
Language
1. Press the CALLER ID-VOLUME ( 6 or 5) button to scroll to the SET LANGUAGE sub-menu.
2. Press mute/menu OK button to enter the menu. SET LANGUAGE 1ENG 2FRA 3ESP shows in the display.
3. Use the touch tone pad on the handset to select 1ENG, 2FRA, 3ESP, or use the CALLER ID-VOLUME ( 6 or 5) button to scroll to the desired language. English is the default setting.
4. Press the mute/menu OK button to save your selection. You will hear a confirmation tone and the selected language shows in the display.
Apr 29, 2009 | Uniden Cordless Phone
PANASONIC kx-tga300s
http://www.panasonic.com/help 17
Handset clarity booster
This feature can improve sound clarity
when the handset is used in an area
where there may be interference.
During an outside call, this feature is
turned on automatically when
necessary. You can also turn this
feature on or off manually.
1 Press {MENU} during an outside
call.
2 {V}/{^}: Select “Booster on” or
Booster off”. i {Select}
Note:
LWhen this feature is turned on,
BOOST” flashes.
LWhen this feature is turned off
manually during a call, it does not turn
on automatically during the same call.
LWhile this feature is turned on;
– the battery operating time is
shortened (page 11).
– the maximum number of extensions
that can be used at a time may
decrease.
Handset voice enhancer
This feature clarifies the voice of the
person you are talking to, reproducing a
more natural-sounding voice that is
easier to hear and understand (page 25)
Feb 24, 2008 | Lands Phones
Cannot have 2 phones in use at the same time 25952
Here is a selection from the manual and a link to the full manual to download.....it should help.
http://www.home-electronics.net/ge/pc/IB/25952EE2_IB.pdf
Transfer ON/OFF
In order to use the Call Transfer feature (applicable ONLY with additional handsets), you must have the Transfer ON/OFF set to ON through the menu of the transferring handset.
1. Press the mute/menu button until TRANSFER 41OFFshows in the display.
2. Use the CALLER ID-VOLUME (5or6) button or the touch tone pad on the handset and select 2ON.
3. Press mute/menu again to save.
Default Setting
You may return handset settings to the factory default setup using this menu.
1. Press the mute/menu button until DEFAULT 4NO shows in the display. NO is the default.
2. Use the CALLER ID-VOLUME (5or6) button on the handset to scroll to YES or NO.
NOTE: If you choose YES, all settings in the programmable menu return to the factory defaults.
Jan 27, 2008 | Uniden Cordless Phone
Feature Button Constantly Flashing
1. Press the Feature key.
2. Dial Call Forward All/DND
set code 69.
3. Press the Feature key
again.
Nov 07, 2007 | NEC Dterm DTP 16D-1 Corded Phone
NEC Electra Elite 32D-1 Corded Phone Logo
155 people viewed this question
Top NEC Lands Phones Experts
george  peters
george peters
SC Spike
Level 1 Expert
Are you a NEC Lands Phone Expert? Answer questions, earn points and help others
