Question about Samsung CLP 300 Laser Printer
I can't get the fuser together again....
Eeks.... I got the label out of the fuser, but I can't put the "lid" back on the fuser--- not to mention - how do I put the fuser assembly back in the printer. I've been trying for over 1 hour...
HELP PLEASE!!!!
  • Valerie Baker Mar 13, 2008
    I did get this fixed myself. I ordered a manual from manualuniverse and lots of swearing.
    Sergeant:
  • 319 Answers
Call tech support
Posted on Mar 11, 2008
Throughout print job HP laserjet 9050 print will be squigly/flakey and not fuse to paper properly
when you replaced the maintenance kit - did you replace the Fuser assembly as well - as this faultr is down to the pressure off the fuser roller to fix the image also there are two blue tabs that set the fuser unit to letter mode(less Pressure) these can be accessed without removing the fuser and are accessible from the left door. ensure the levers are set to paper and not letter. if the fuser is still not fixing the image correctly then a new fuser unit assembly is required as fuser units are non servicable.
Jan 08, 2014 | HP LaserJet 9050 Printer
Hp Laserjet cp4525 50.2 fuser error
What helped me was this: when you close the fuser cover, there are two white tabs that lock the paper feed assembly in. Well, the tab on the left tends to slip off if not closed correctly. Try closing the lid slowly putting more pressure on the left side of the lid. What happens is when the tab slips off, the paper never reaches the fuser and the printer throws the fuser 50.2 error.
Jul 20, 2012 | Office Equipment & Supplies
50.2 FUSER ERROR
Model number not mentioned, even 50.2 error related to fuser assembly, Replace fuser assembly..If you want further assestant pl get back us..
Feb 05, 2012 | HP Office Equipment & Supplies
Get rid of the black streak a HP creates on each copy
It could be one of two things, first look at the cartridge, turn it upside down and slide the lid open. Do not touch the drum inside just look and see if you have a streak of toner on it. Or if you used labels a label could be stuck in it. change cartridge, second problem it could be the fuser. You will have to look in the back and see if the fuser roller is ripped. If so you will need a new fuser.
Aug 13, 2010 | HP LaserJet 1020 Printer
Red lights on printer.... all lights are red on my sp c221n printer
Had this problem to this morning. Searched the internet w/ no results, but was able to solve it.
Seems that all the lights on meant there was a problem with all the fusers.This is a list of what I did. I don't know how much of it is necessary, but hoefully it helps.
I took them all out, let it sit for a while.
Restarted it.
Might have opened and closed the cover a few times.
Fixed another printer.
Came back to it, and first put in the black fuser, and closed the lid. After doing this the black fuser's light went off. O
One by one I opened the lid, put in another fuser, closed it, and it detected them.
Once they were all in it worked again.
Dec 11, 2009 | Ricoh Office Equipment & Supplies
Xerox 6280 - need to print labels on a sheet of 30 labels
Shouldn't be a problem, provided you use labels that are intended for a laser printer. Inkjet labels can wreck your laser printer (inkjet labels can't cope with the heat of the fuser in a laser printer).
Use the right template in your Wordprocessor package for the labels you are using (or create a custom label layout in your Word processor).
Use the Multi Purpose Feeder input tray (fold down from the front door), put the labesl face down, print (making sure that you tell the printer to use Labels and the MPF. It's important to tell the printer that you are using labels, as these are thicker, and need more heat from the fuser (especially if you are printing several sheets of labels, as this cools the fuser a little)
Jun 14, 2009 | Laser Phaser 6280v_n 25ppm 256mb - XEROX &...
Replacing fuser roll in hp4200n
No sorry you can only get the fuser assembly. You should be able to get hold of a refurbished one to keep costs down though.
Mar 23, 2009 | HP LaserJet 4200n Printer
Hp 4350 error code 50.3
I have just changed the fuser unit and the printer is still giving the
same error [fuser error and low heating] Kindly help.
Maxwell Mpundu@technet.co.zm
Apr 21, 2008 | HP LaserJet 4350 Printer
My magicolor 2530 DL
Hi Condeleeza,
Normally smoke would be caused by label residue being left on the fuser rollers, I am assuming your use of the word label is correct and not a transparency (which is a common jamming source in laser printers) especially when someone mistakenly puts a inkjet transparency through a laser printer or mistakenly puts a clear plastic divider sheet through.
If you are sure all of the original label has come out and there is was no residue left directly on the fuser rollers, and the fact you now have smoke and an error code (which I do not have access to find service codes for Minolta), I suspect the fuser assembly is overheating now which is causing the error message (after probably 10 seconds after switch on from cold). This could mean the temperature sensor monitoring the fuser temp is either not touching the fuser due to label fragment lifting sensor off fuser roller surface or sensor is bent or damaged due to label revolving aorund or subsequent removal efforts.
Take a closer look and see if you can find a stray fragment stuck to a thermocouple sensor wiping against the fuser roller. Failing this then you probably need to send into service and ask for a quote to repair. Be aware that the fuser may have become scratched or otherwise damaged depending upon your label removal techniques....over zealous use of letter openers, nail files and small screwdrivers have destroyed many a good fuser assembly.
Good luck
Kiwi-Mark
Jan 14, 2008 | Konica Minolta Magicolor 2530 DL Laser...
Samsung CLP 300 Laser Printer Logo
65 people viewed this question
Top Samsung Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
Victorman
Victorman
jasbo
jasbo
Are you a Samsung Office Equipment and Supply Expert? Answer questions, earn points and help others
