Cannot figure how to take the lid of my wma37 1400 spin hotpoint washing machine. machine fills with water but does but does not spin
    Sergeant:
  • 319 Answers
Call tech support
Posted on Mar 11, 2008
Washer fills, agitates, will not drain or spin
check your lid switch ,or debriss in drain pump ,pump can not run will not spin untill machine waterlevel switch comes below a certain level of water pressure
Jan 22, 2013 | Hotpoint 3.2 Cu. Ft. Super Capacity Washer
VBXR1090B WASHER DOESNT SPIN BUT WILL PUT RINSE WATER INTO WASH TUB
if the machine basically stops after the wash cycle, but prior to the rinse/spin cycle and won't do anything, yet when you move the timer into the rinse cycle it will fill with water as per normal, and again when it hits spin it stops.. then you have a bad lid switch, the lid switch can be accessed by sliding a putty knife between the top and front of the unit about 2 or 3 inches in from the corners and pushing in, there are hidden spring releases there that will allow you to pull the top of the front panel out, then lift if off its supports on the bottom, the top of the unit that has the lid switch can be raised by removing several screws from the brackets of the top. the part number for the lid switch is WH12X1043 $16 - $29..
good luck, have fun.
Aug 04, 2010 | Hotpoint VBXR1090B Top Load Washer
Hotpoint Aquarius 1100 WM63. fills with water...I dont think it is heating water...rarely rotates and spins (saw it once in early stage of J prog only) seems to fill and empty but no rotate or spin....
if it fill with water then stops it is the ellement the machine first fills turns the drum then heats up the thermostat cuts in and the it emptys rinses and spins so if it does not get to temp it will stop or continue to wash forever
Jun 27, 2009 | Hotpoint Aquarius WMA42 Front Load Washer
My BWD 129 washer dryer is not spinning or draining
I have a similar problem - washer wouldn't spin or drain. The problem with my Kenmore 90 series is that the lid switch needs to be replaced. It's a safety feature. During normal operation when the washer is spinning or draining - and you open the lid - the lid switch sensor knows that the lid is opened and then "stops" the machine. A new lid switch needs to be installed. I have picked up the part, but am still trying to figure out "how" to get inside of the washer. The only difference between what you describe, and my problem, is that there is no "unusual" noise coming from the machine. Hope this helps lead you in a good direction. Another good site is Bob Villa's site.
Jan 15, 2009 | Hotpoint Aquarius WD640 Front Load...
WMA54 Hotpoint Aquarius drum does not turn during wash or spin
If the machine pumps water inside but does not start :
Start checking the lid switch, if this is stuck the machine wont start.
If the drum does not move at all, the motor, the motor control unit, the motor coupler, the control board may be faulty.
For more details , see: It doesn't spin
See also a general diagram here: redarrow.gif Front Load Frigidaire/GE/Kenmore Style
Jan 06, 2009 | Hotpoint WMA30 Front Load Washer
Hotpoint topload washing machine won't water won't stop running.
washer top load will not stop filling even when turned off
Dec 01, 2008 | Hotpoint VBSR3100D Top Load Washer
Washing machine fills, but won't agitate
my kenmore washer will fill up but it will not agitate.
Dec 17, 2006 | Hotpoint Aquarius WD63 Front Load...
Agitator Not Working
check your motor coupler, lid switch
Nov 08, 2006 | Hotpoint VBXR1090D Top Load Washer
Washing Machines Logo
67 people viewed this question
Top Washing Machines Experts
Marvin
Marvin
