Back to:
Tags:
Receivers
Generic problem for all Receivers
Kenwood TS440s/at
posted by G1YGJ on Mar 11, 2008
I have a Kenwood TS440S/AT ham radio which won't transmit. I have been told it may be the switching relay.
Any more ideas please?
Regards,
Stan. G1YGJ.
Comment by G1YGJ, posted on Mar 11, 2008
Thanks for the reply.
I have tried it into an aerial that is know to be good and that is used regularly buy a fellow ham at his QTH.
I bought the radio a couple of weeks ago and the previous owner assures me that it was OK when it left him. He has even offered to contribute to the costs or refund my money. But I want the radio fixed rather than send it back.
The needle drops to 0 when the mic is keyed and also when the "send" button is pressed on the front panel.
The auto ATU obviously doesn't operate as there's no TX.
Everything else works, it's fine on receive.
Regards,
Stan.
Comment by G1YGJ, posted on Mar 13, 2008
HI,
I have done all those things ad suggested and all appears to be in order!.
I'm sure it's something silly and simple though.
Cheers,
Stan.
I have the same problem Post a new problem
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
Clarification Request
by Palmbeach, posted on Mar 11, 2008
Hi again Stan
Almost certainly in that case, something has just come adrift during transportation. I would slip the top cover off and take a good look around.
There may be a ribbon cable that has pulled away from its socket or a relay that is not secure. The TS440 is quite small but it is reasonably easy to work on as it predates much of the micro technology used today.
Take a look at the tuning control board.
These usually have a pin diode matrix that prevents transmit on frequencies outside the amateur bands. It would be an idea to check that the board is secure.
Also try the transmitter on different bands.
Look for a setting that turns the PA off for use with a linear amplifier in case this has been inadvertently selected. Could be a slide switch.
I can't remember whether the auto atu is switchable on the 440 as it is with my TS940SAT and TS950SDX. If it can be turned off, then do that in case there is a problem there.
It sounds as though the person you bought it from is genuine so I guess it will be simply to sort out. Bit depressing for you though :-(
Have you tried the transceiver into a dummy load?
Have you tried different modes?
When you press the key or switch to Tune, exactly what happens?
It could be a relay but it is more likely to be the power supply especially if the PA has been overdriven or has been used with a mismatched antenna.
If you are trying to transmit into a very poor match, the PA will shutdown and will not allow you to transmit.
What happens to the meter when you try to transmit?
Solution #1
Not Rated (0)
radarman19
Rank:Wiz Wiz
Rating: 78%, 242 votes
call tech support
Was this solution helpful? Show your Appreciation by rating it:
Thank You!
Was the solution helpful?
Show your appreciation by commenting on Kenwood TS440s/at:
I don't want to Accept this solution
Can you Help with these Receivers problems?
Receivers
my audio on my logitech web cam does not work when using...
Receivers
My Roalnd W-30 is describing a "Disk Load...
Receivers
so i've had some back luck trying to find a cooperative...
Receivers
I bought a JL Audio 500/1 Mono Block Amplifier off of Ebay...
Receivers
onky power board # 1B20950-1A
Loading problems.
Repair Service
Find Receiver Repair Service Provider Near You:
Browse the Repair Service Directory
Repair Service Providers, Get Listed FREE
Prescreened Contractors
Get Matched to Prescreened Home Media Professionals
Category
Zip code
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
