When updating the anti-virus, a message in the box states"SYMLCSC.EXE file is linked to missing export ADVAP132.Dll. Register service CTRLHandleEXW." The Symantec Shared Components failed. will also show up. I have tried the registered service however without success. Can you help me further Thankyou Linda Graham
  • 871 Answers
Go to symantec.com and download norton removal tool to simply remove your antivirus. then re-install. btw, always empty %temp%, temp, and prefetch. this will help increase the installation rate.
Posted on Mar 11, 2008
How to get rid of a "RUN DLL" message?
First of all it might be a virus so you should follow this link as for a Great Malware Removal Guide:
http://www.agady.com/great-malware-removal-guide-or-how-to-remove-svchost-exe-malware/
Now it might be a faulty software you've installed which is trying to use a file or resource you don't have so what we need to do is:
1. on your keyboard hit start+R (It'll give you a RUN command line).
2. Type MSCONFIG (hit enter)
3. go to STARTUP (Tab above) and click "Disable all"
4. go to SERVICES (Tab above) and tick "hide all microsoft services" then click "disable all"
5. hit ok and restart.
6. if DLL error is gone, start adding back startup items and services (as described in line 3 and 4) until DLL error returns and then you'll know which starup item or service caused the problem in the first place.
How to get rid of RUN DLL message
Oct 25, 2014 | IBM Lenovo ThinkCentre A70z 0401A3U...
Tip
How to Register DLL files
On Microsoft Window's operating systems, a DLL stands for Dynamic Link Library. DLL's are relatively small files that include a library of functions- usually data that can be shared across multiple applications. DLL's are called upon by various applications and can be loaded and utilized by these applications concurrently.
Registering a DLL
There are two easy ways that a DLL can be registered in your Window's operating system's registry, the first is the simplest, known as self registering files, the second way is to manually register a DLL.
Self Registering Files
It should be noted that many DLL files are self registering, they include information required to store themselves in the operating system's registry. As the name states, self registering files require no human intervention. Self registering files will automatically store themselves on your machine and become accessible when needed. Besides DLL files, other types of files that are sometimes self registering include .EXE and .OCX.
Manually Register Files
The second method used to register DLL files on your computer is via manual registration. Manually registering a DLL file is quite simple and can be done in only a few steps.
1. The first step is turn on your computer, launching your Window's operating system.
2. Once your Window's operating system has loaded completely, click on Start and then click on Run.
4. Once the command is input into the Run field correctly, press Enter.
5. Once the DLL has been registered, you should receive a confirmation in the form of a pop up box. This message will list your newly registered DLL file and confirm that is was successfully registered into the registry.
on Aug 28, 2010 | Computers & Internet
Emachine will not run anything
Rundll32.exe errors typically occur in response to the inability of Windows to access an application, program or file as the result of a corrupted or missing DLL (Dynamic Link Library) file or in response to a rundll32.exe virus that has been designed to look like a normal Windows process.
Here are the easiest ways to fix rundll32.exe errors.
Click "Ctrl + Alt + Delete" on your computer's keyboard to open the Task Manager window.
Click the "Processes" tab and search for a rundll32.exe program.
If one is running and appears to be accessing a lot of your system's resources, click "End Process" as it is likely a malicious program and not a true Windows program.
Run software to seek out, detain and remove viruses, malware, spyware and adware. Often these malicious programs corrupt DLL files or cause them to be deleted or moved and, as mentioned, some rundll32.exe programs may in fact be viruses on your system.
Reboot your computer to update any changes you may have made recently to your files and programs.
Many programs and applications require a reboot for successful installation.
Uninstall a recently installed or changed program or application and then reinstall it using the default settings.
An installed program may not have loaded properly, an installation via the Internet may have been interrupted enough to create errors or the program may have a bug.
If you uninstalled a program and see a rundll32.exe error, reinstall the program and then uninstall once more.
Retain the services of a Microsoft certified technician, if all else fails, to review and fix your system's Registry.
Dec 01, 2013 | E-Machines Computers & Internet
It just frequently pops up on the screen - t8 Ext P Ex. dll is missing
Click start control panel administrative tools computer management then select event viewer this may vary depending on what operating system you have
extend the events there you will see errors in red you will no what exactly what the error was and at what time it occured
Right click on the error message select properties you will see all details about the error
or click start type in event viewer press ENTER
this should give you some sort of understanding of the error
Your computer will not work properly if a Windows Dynamic-Link Library (.dll) file is damaged or missing. When this happens, you will receive an error message similar to this: "[program name] Illegal system DLL relocation."
The .dll file type contains instructions, or code, to run scripts that open dialog boxes.
These important graphical elements are necessary for computer user interaction in most software programs.
There is a simple way to keep all of your .dll files healthy, so you rarely lose valuable time restoring lost or broken links.
Connect your computer to the Internet.
Click "Start" and then click "Run" if you have the Windows XP operating system. For other systems, simply open Internet Explorer and click "Safety," then click "Windows Update."
Type "wupdmgr" in the "Run" dialog box to run Microsoft Update.
Click "Express" to find out if your computer requires new updates.
Press "Install Updates" if any are available.
Otherwise, close the Microsoft Update window.
Update your anti-virus program and then immediately scan all of the files on your computer.
Open the software program that gave the .dll notice to see if error messages still occur.
If so, continue to the next step.
Reinstall the affected software program to replace the damaged or missing .DLL file.
If the issue is still not resolved, contact Microsoft Support.
Fix DLL Errors With Freeware
A Microsoft Windows DLL has data that is necessary to run various software programs.
If a DLL file is defective, the software using the file will not open or run properly.
DLL error messages can stem from a number of system issues, such as a bad program installation, registry issues and missing DLL files.
You may receive error messages from numerous programs when a DLL is corrupt, because many programs use the same DLL.
Running freeware to fix a DLL error is a viable alternative when you cannot repair the DLL manually.
Visit the Regsofts website.
Click "Download Now" to install Registry Repair 2.0.
http://www.regsofts.com/free_registry_repair/registry_repair.htm
Run the "RegpairSetup.exe" setup file.
Click "Next" at the prompts and agree to the terms of Registry Repair 2.0. Click "Finish" to open the application.
Click "Start Scan" to find DLL errors on your system. Place a check by "Non-existent Shared Dlls" once the scan completes. Click "Fix Errors" to repair the DLL errors.
Run RegSeeker 1.55
Navigate the Regsofts website.
http://www.regsofts.com/freeware/regseeker.htm
Click "Download and use for free" to install RegSeeker 1.55.
Run the "RegSeejer.zip" setup file. Click "Next" at the prompts. Agree to the terms of RegSeeker 1.55, then click "Finish" to open the tool.
Click "Clean the Registry." Allow the scan to detect and repair DLL registry issues. Reboot your system once the scan is complete.
Run ACleaner 3.5
Scroll to the bottom of the page, and click "Download and use for free" to install ACleaner 3.5.
http://www.regsofts.com/freeware/privacy-and-registry-cleaner.htm
Save and run the "ACSetup" setup file. Click "Next" at the prompts, and agree to the terms of ACleaner.
Open the software and select "Registry." Choose the Scan Registry option. Select the "fix errors" option once the scan is complete.
You could run the chkdsk disk utility
Click start run type cmd then type chkdsk/r/f which will scan for and attempt to repair any bad sectors and automatically fix any corrupt files on your Hard Drive.
or an easier way to run the chkdsk utility
Windows 7 chkdsk
http://www.w7forums.com/use-chkdsk-check-disk-t448.html
Click start control panel administrative tools computer management ,disk management right click on your drive select properties click tools click check now click start two boxes
automatically fix files and scan for and attempt recovery of bad sectors place then a tick in both boxes then select check now, start should schedule this task when restart
have no input while the chkdsk utility is in progress any input may further damage your computers Operating System and Hard Drive
http://download.cnet.com/jetclean/3000-18512_4-75627788.html
JetClean tidies your registry, gets rid of junk files, deletes broken shortcuts, and attempts to give your computer that like-new feel again.
Optimizers and Diagnostics.
http://download.cnet.com/360amigo-system-speedup-free/3000-18512_4-75206713.html 5E3422139C19CBED35C14826A44D4605
Improve your PC performance and fix errors.
Jul 09, 2013 | Computers & Internet
I am running Windows 98 on one of my old computer for the children. When windows starts up I am getting to error messages in starting program: apcmain.exe file is linked to missing export KERNEL32.DLL...
You need to have your operating system repaired. You will need to have your windows 98 operating system disc.
Dos knowledge will be needed to repair this issue.
I hope I was able to shed some light on this issue.
Upon request I can assist in this matter or provide DOS commands.
You may be a victim of spyware/maleware infections. You will need to have your system cleaned. This should help
resolve your issue.
Please keep me posted and updated on your issue. I am here for you and will see your issues out till resolved.
Have a great and wonderful day :)
Thank You
Please do not hesitate to contact support :)
Frank
Live-Tech
1-888-361-8511
http://www.mylive-tech.com
http://www.itsupport.co.cc
May 21, 2010 | Computers & Internet
Sprtcmd.exe-bad image Application DLLC:\WINDOWS\system 32\NTMARTA.DLL not a valid image. Check this against your installation diskette
You may be able to perform a restore, From the start menu chose programs>accessories>systemtools>System Restore
Choose a restore point that you think has a best date and time when your pc was working better.
Apr 16, 2009 | Dell Dimension 8250 PC Desktop
RTHDCPL.EXE err
Error Message after Installing Security Updates 925902 and 928843 This afternoon (April 3rd, 2007) my Automatic Updates alerted me about a couple updates I needed to install, so I did. Upon rebooting the computer though I was confronted with the following error message
"RTHDCPL.EXE - Illegal System DLL Relocation"
"The system DLL user32.dll was relocated in memory. The Application will not run properly. The relocation occurred because the DLL C:\WINDOWS\SYSTEM32\HHCTRL.OCX occupied an address range reserved for Windows system DLLs. The vendor supplying the DLL should be contacted for a new DLL."
Cause of Error Message
Turns out this error occurs when the Realtek HD Audio Control Panel by Realtek Semiconductor Corporation is installed. This is my built-in sound card on my computer.
The HHCTRL.OCX file that is included in the Security update 928843 and the User32.dll files that is included in Security Update 925902 have conflicting base addresses. When Windows loaded the HHCTRL.OCX file before it loads the User32.DLL file, the problem occurs.
The error occurs when the following third party programs or applications are installed on a computer with Windows XP Service Pack 2 installed.
ElsterFormular 2006/2007
TUGZip
CD-Tag
Microsoft now has released a patch to correct the problems, you can go to the following link to download and install the patch for the patch :-)
http://support.microsoft.com/kb/935448
Oct 18, 2008 | Computers & Internet
Blue Screen
Use the following steps to replace the missing files when Windows cannot start.
  1. Turn the computer on and place the first recovery disc into the top drive.
  2. After inserting the disc, turn the computer off, wait about ten seconds, and turn the computer on again.
  3. If an HP Recovery screen displays "Press any key to continue...", press the spacebar.
  4. To continue, read the warning screen and click OK.
  5. Click Advanced Options at the top of the screen.
  6. Click Selective Recovery.
  7. Read the Select Files to Restore window that appears.
  8. Type the name of the file. For example, if the error message is MNYUTIL.DLL is linked to missing export MFC42.DLL, type MFC*.DLL.
  9. Click OK. If there is more than one recovery disc, it may be necessary to insert another disc when prompted.
  10. When therecovery process has finished copying files, remove the disc andrestart the computer. If problems, persist it may be necessary toperform a system restore or a non-destructive recovery.
(Note: Click here for information on ordering the recovery CD/DVD sets)
thx.
Oct 08, 2008 | HP Computers & Internet
Computer is 3 weeks old.DLL module missing.cant open mirco works.did scan on computer,3000 errors were found
suggest downloading avast anti virus home addition from the avast website here , the home adition is free and auto updates, free to register too. after you have installed and done a pc scan with avast anti virus, may i suggest that you type in the specific DLL file you want from the google search engine. many sites sould have one for you to download. please get the anti virus first as your pc can get infected as soon as you turn one on. 'ad aware', ccleaner are two other programs i personally use and wouldnt be without either. good luck :)
Jun 19, 2008 | HP Computers & Internet
Computers & Internet Logo
Brian Sullivan
Brian Sullivan
David Payne
David Payne
