Question about Alpine CDA-9856 CD Player
CDA-9851R comes up with ERROR when i put any cd in and will not play. **** me off!!!
    Sergeant:
  • 319 Answers
Call tech support
Posted on Mar 11, 2008
SOURCE:
I got 2003 mazda6 I put CDs in the player the cd is like kind of stuck and the music doesn't play so I talk all the cd back out and I put just one cd it still doesn't play, when I put the cd I can hear...
CD's come in different formats. If you're trying to put a home burned MP3 CD it may not work since it doesn't know how to read MP3 CD's, it may only know how to read CDA's or store bought CD's.
Jan 14, 2018 | Audio Players & Recorders
Why do i get format error when i put songs from a cd on the eclipse?
1. Why do i get format error when i put songs from a cd on the eclipse?
= This is probably because the format that your songs are currently in is not supported by your device. Supported devices on the Mach Speed Eclipse 180 MP3 player are: mp3, wav, and wma. If your music is for example filename.cda, it won't be able to play because of the file format being .cda.
2. I also see the song on the eclipse but it says drm protected and will not play the song.
= When ripping your music, check your ripping options in whichever ripping software you are using that protecting music files is off, this may be the reason why your music cannot play - it may be protected to only play on the computer that ripped(recorded or duplicated) the song.
Sep 17, 2012 | Mach Speed Eclipse 180 MP3 Player
My head unit will not play burnt cds
I have a similar problem, When i try to play burnt cd's it would sometimes work and sometimes would skip or crackle as if it cannot read. I tried a standard bought cd and worked flawlessly so it cannot be the lens.
One thing i tried is when burning music to the disc turn the "write speed" right down to the slowest setting. If using Windows Media Player it is available by pressing Alt then navigating to the options menu. select burn -> write speed -> slowest. It doesnt go much slower but i think it writes less errors to the cd which makes it like a standard bought cd.
Hope this sheds some light on the situtation and good luck,
Gh0st
Jul 30, 2012 | Alpine Case Cda-7873 Cda-7875 Cda-7876...
I have an alpine cda-9883 cd won't eject & error
try detaching the "face" and there should be a little button that you can only push in with some kid of really thin stick,maybe a pin that will reset the cd player and hopefully work
Oct 27, 2009 | Alpine CDA-9883 CD Player
Run a Laser Lens Cleaner thru it a couple times, one that uses fluid. You can find them at any electronics retailer for 15-20 bucks. If you still get the same error, the transport needs to be replaced. The avg cost is between 125-175. Hope this helps
Jul 01, 2009 | Alpine CDA-9856 CD Player
Alpine cda 9851r
Apline-usa.com / search for your model then look for a link that says Owner's Manuel.
http://www.alpine-usa.com/US-en/support/support_search.php?modelname=cda-9851
Aug 11, 2008 | Alpine CDA-9851 CD Player
Delco stereo wont play cd-r (mp3)
I believe CDA extensions are actually just shortcuts to the audio file and not the actual audio file. You will want to convert your MP3's to .wav in order to play them in your radio. Roxio and Nero version 4 and higher will automatically do this for you and a version should have come with your computer or CD burner. Just place the MP3's in the record section and select output audio CD.
Jul 09, 2008 | 2000 GMC Safari
I have a Alpine CDA-9851R CD player and I cant turn the volume above 17.I have a amplifier and subwofer fitted in the boot.The problem started after one of my friends was playing with it.
this probably isnt it but my stereo got messed up like that because i think i turned it up and down way to much. maybe try pulling the volume button out and putting it back in.
Jun 10, 2008 | Alpine Car Audio & Video
Error
make sure it is set to cd/wma/mp3 mode
press menu then go to set up then I think general and then look for play mode or cd mode. something like that.\
ps if it was over heating the unit actual tells you that it is over heated and then powers down.
Oct 20, 2007 | Alpine CDA-9855 CD Player
Alpine CDA-9856 CD Player Logo
70 people viewed this question
Top Alpine Car Audio & Video Experts
xxxxxx xxx
Robert Salgado
Robert Salgado
Jaime Hernandez
Are you an Alpine Car Audio and Video Expert? Answer questions, earn points and help others
