Question about Sony PVW-2650 VCR
Error Code 9 and 10
When i try to play a tape in the deck, it gives me Error code 9 or 10. Any help would be appreciated.
Thanks
sam
    Sergeant:
  • 319 Answers
Call tech support
Posted on Mar 11, 2008
SOURCE:
Tascam DA88 has error light and wont play tape or show time code
These are expensive to repair and not many people are repairing them. Probably a transport issue and that might be all there is.
If you look on E bay they are selling cheap.
Feb 16, 2015 | Tascam Audio Players & Recorders
Sony evo 9850 error code 20
From what i've read an Error-20 on a Sony BSP deck is a tape transport problem. Someone with the same error code (on a BSP model) said the actual tape loading mechanism was bad and they had to replace the hardware inside the machine that loads and ejects the cassette.
Jan 23, 2008 | Televison & Video
Tape deck no longer plays large DVCpro tapes
the tape compartment elevator has switch senors that tell the machine what size tape is in..
does the tape load all the way.. you need to tell us
is there an error code ?
either the sensor or the reel motors the feed and uptake the tape,,
they ride on rails and slide into position to accomodate the tape side they could be having trouble moving, dirty, broken actuator
Apr 07, 2009 | Panasonic AJ-D250 DVCPRO DV/Mini DV VCR
Sony UVW-1800 Error Code
I just found this post on another site :
tsvservice- 29th Jun 2007 14:0109-221 is "failure to complete threading within the specified time". in plain talk, the mechanism in the deck that threads the tape around the heads is not working. this could be a bad motor, bad gear, or even a bad tape.
Feb 15, 2009 | Fuji M321SP Betacam Tape
Tascam DA 40 DAT Machine ." Loading error "
The DAT machine needs new belts and maybe some cleaning. These fail all the time due to old belts that lose the tension that is required.
Dec 10, 2008 | Tascam 122MKIII Single Dual Cassette Deck
Sharp CD-BA 2650 Error code: ER-CD 11 - the CD tray will not open
I had the same problem but fixed it by replacing the cd belt which was broken and relined the main cd plate which holds cd to correct position . and god fixed it.
No more errors and now a great cd Hi Fi.
Make sure all s aligned and blow out all dust with an blower or air compressor.
I pull the top plates off blow air into them and replaced a broken belt for cd's and not it's new machine.
You want to fix it than fix at the source.
Dec 05, 2008 | Audio Players & Recorders
I have a Sony UVW 1800 Beta SP deck. This morning, after completing a dub, I rewound the tape. The machine made a sound, the tape stopped and became stuck in the machine. I received an error code 02-803. I...
check your tape deck unit throughly check for any physical damage of REWIND/FORWARD Gears.and FLY Wheel.
and dis locateion of some lever positions.
defnitly you get solved
Nov 13, 2008 | Sony Betacam SP Small Videocassette 30...
Cannot eject VHS tape from Sony SLV-X811
I had a similar problem with a Panasonic VCR. It would not eject the tape and gave an error code. I found that the door does not quite fully open, so that the top of the tape hits the door and cannot eject. If I turn off and then turn on the VCR the error code disappears. Then I press the eject button and simultaneously hold the door fully open with one finger until the tape starts to eject and clears the door.
Feb 29, 2008 | Televison & Video
GoVideo Dual Deck VCR Model#GV6015with one touch copy
It seems to be fixed. I ran a new tape through the machne as suggested. To be sure, I also used a VHS head cleaning cassette.Works fine, now. Thanks
Feb 22, 2008 | Televison & Video
My Teac R-H500 tape deck will not play tapes
The belts will have failed. You will need to replace them for the deck to be reliable. If you are mechanically minded I can talk you through it... You giving me a FixYa rating will help my profile and loosen my lips on how to overhaul your deck. :)
Feb 13, 2008 | Teac R-H500 Dual Cassette Deck
Sony PVW-2650 VCR Logo
154 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Steve Allison
Steve Allison
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
