Question about Dishwashers
Dishwasher pump caviation
A few months ago I urchased a GE dishwasher. Installed and it seemed to workfine. Reently it has not been getting dishes clean and in the last couple days has not washed dishes at all. When I run it through a cycle, I here a cavatation noise coming from the pump.
I pulled it out last night and checked the inlet screen on the unit and it was relatively clean. Reinstalled and ran a cycle. Once again got the cavataion noise. Also notices that the upper rotary arms were not moving. So i added additional water to the unit and ran again and found that the arms rotated as they should.
It seems that the unit is not filling with enough water for it to function properly.
What is the water psi to be at to fill the unit?
What is the timing cycle for the water valve to be open?
Any ideas as to the cause?
GLD5900N00BB s/n MM833534B
thanks
Don Filippelli
    Sergeant:
  • 319 Answers
Call tech support! That's why these people get paid. Sites like this wouldn't need to exist if they did their jobs correctly!
Posted on Mar 11, 2008
Dishes leave food particles on the glasses - machine is only 2 years old. We use rinse agent - Cascade gel in the auto dispenser - we use jetdry dishwasher cleaning agen monthly - jet arms are not...
Recent changes in the law prevent soap makers from putting phosphates in dishwasher soap so they're not as effective as the were even a few months ago.  Unfortunately,  the solution is more thorough rinsing before loading.
http://www.appliance.net/2010/states-ban-phosphate-laden-dishwasher-soap-1988
Mar 03, 2011 | GE Dishwashers
Glasses are cloudy and cutlery and dishes are not clean. using cascade with dawn powder. dishwasher is brand new, installed one week ago
Sorry to hear your having problems with your new dishwasher. Please review your owners manual for great tips for the best results on cleaning your dishes. Here are a few steps to take to get your dishwasher working:
  1. Run you sink water for 3 min on hot before you start your dishwasher. This allows warm water to enter the dishwasher and helps aid in sanitizing and cycle time. Remember water entering must be at 125 degrees.
  2. If your using power detergent be sure to use rise aid. All new dishwashers require this additive for best results.
  3. If you have hard water your going to need a dishwasher cleaner and use it once a month. I recommend dishwasher magic. Kills 99.9% bacteria and leave a great scent. I use it myself.
Dec 09, 2010 | GE Profile PDW8400J Built-in Dishwasher
Soap residue remains on dishes after wash cycle is complete. Spoke to GE today & was advised that Cascade changed their formula a few months ago & many people are having the same problem. ...
The scum, film and white residue problems have started since the reduction of phosphates in dishwasher detergents.
Here is a tip that will help you to solve the problem of films, residue, and scum in your dishwasher.
Dishwasher Residue and Film on Dishes
heatman101
Nov 10, 2010 | GE Profile PDW8400J Built-in Dishwasher
The scum, film and white residueproblems have started since the reductionof phosphates in dishwasher detergents.
DishwasherResidue and Film on Dishes
heatman101
Nov 09, 2010 | General Electric GE Profile Dishwasher 24...
GE Dishwasher - poor cleaning
I believe there is a screen/filter on the water line before or at the water fill valve. If that gets plugged it can restrict the flow. The fill valve can also fail/get plugged and restrict the flow.
Also, dishwashers usually have a level sensor to tell when there is enough water to do the wash. It may be a float inside the tub that operates a mechanical switch or it may have a hose to a pressure sensor. Either type can get greasy/dirty/plugged and as a result cause improper water levels.
Check both the water supply filter/fill valve and the level sensor. One or both of those may be involved.
Mar 10, 2017 | Kenmore Dishwashers
GE PDW9700 - The dishes do not get cleaned
Same as above problem: I have had this dishwasher for less than 4 years and the dishes as of about 2 years ago stopped getting cleaned. I use the recommended dish liquid and rinse and lightly clean the dishes before I put them in.
What a piece of junk!! gs
Feb 26, 2009 | GE Profile PDW8400J Built-in Dishwasher
GE Triton Dishwasher fills with water but no spraying occurs.
Trouble shooting GE dishwasher
Model GSD6600G00WW
Air gap is clean
Garbage disposal is clean
Dishwasher fills with water OK
Drain pump runs after a wait of several minutes and seems to run slow but drains most of the water out of the reservoir.
Dishwasher is not running the wash cycle (spraying water on dishes)
Jan 27, 2009 | GE 24 in. GSD6660GSS Built-in Dishwasher
GE dishwasher GSD2200G00WW dishes not clean
Make sure the spray arm is actually rotating and the jets aren't clogged. You should be able to hear the arm rotating when the dishwasher is operating.
Otherwise, perhaps the pump is plugged or not working and the water isn't "jetting"
Sep 06, 2008 | GE Nautilus 24" Built-in Dishwasher
Dishwasher jets not working
Check the actual water values to make sure they are turned all the way on.
Aug 21, 2008 | GE 24 in. GLD5860LSS Stainless Still...
Dishwashers Logo
226 people viewed this question
Top Dishwashers Experts
