Hello joecradd: My name is Roger and I will help you. With the key on engine off. Depress the foot feet 3 times with in 5 second. If the CHANGE ENGINE OIL flashes for 5 seconds, the system reset. Should you need further help please just ask. Please rate the answer. This way I know it was helpful. Thank You for using Fix Ya. Roger
Turn ignition key to run position but do not start depress accelerator pedal all the way down three consecutive times within 5sec. it should reset
SOURCE: HOW DO I RESET THE CHANGE OIL LIGHT ONCE THE OIL
look in the manual......turn the ignition to the on position not starting it of course and then pump the gas petal 5 times then the light will blink a few times turn off then back on...problem solved
SOURCE: Headlight & Signal Light change out for 202 GMC Yukon
The headlights are fastened in with 2 L-shaped pins.You should see them at the top of the light assemblies. Pull up on them, and they pull straight up and out. Your light assemblies are now free to remove. Now you can access the turn signals.
