Question about Samsung CLP-510 Laser Printer
CLP 510 error
Is saying invalid toner, yellow. Have replaced toner cartridge 3 times with no success
    Genius:
  • 1,011 Answers
Sir,
Inside the front cover of the Samsung CLP-510 printer is a "Waste Toner Bin" - this bin collects any toner which is not fused to the paper during the printing process. The photo at the left shows the waste toner bin installed in its correct position.As you print, the waste toner bin "fills up" with wasted toner, and you have to replace it on a regular basis. Other printers send waste toner back to a separate compartment in the toner cartridge, however Samsung prefers to sell you and additional "consumable" - apparently the $130 cost of the toner cartridges (x4 cartridges = $520/refill) just isn't sufficent revenue.
In the photo below, we see the waste toner bin removed from its operating position, and lying down on the printer door - Just tipped down from its normal place.
Note (1) - this is an optical sensor which detects when the waste toner bin is full - A "bump" on the bin (2) fits into the sensor notch when the bin is in position. An optical sensor looks though the "bump" and is supposed to detect when the toner reaches this level.
Note that one of the inlets for waste toner (3) is just above the sensor "bump" (when the bin is in it normal position). You can also see the round feed which goes into this hole, just above the sensor notch (1).
The problem occurs because the waste toner being injected into the bin "runs down the side" through the sensor "bump" - after a little while, this dirties the walls of the "bump", and although this is nowhere near as opaque as the actual toner, the sensor is sensitive enough to decide the bin is full and shuts down printing. In my opinion, this represents two fundamental flaws in the design:
  • The toner inlet should not be positioned such that toner entering the bin runs through the sensor area.
  • The optical sensor should not be so sensitive that a little dirt is detected as a full bin.
It is interesting to note that Samsung explicitly advises that you not empty and reuse the waste toner bin - The overly sensitive sensor pretty much guarantees that you cannot do this, as it is virtually impossible to empty the bin without getting toner into the sensor bump, after which the printer will refuse to print and direct you to replace the bin.
The Cure The first time this happened, I noted the dirty sensor notch and cleaned the area - It lasted only for a few pages, at which time I contacted Samsung to report the problem - No matter how I tried to explain the situation to them (over several days of correspondance) the only response I could get from them was "the bin must be full - change it".The new bin lasted for perhaps 100 pages, at which point the dreaded "replace waste toner bin" message appeared. Samsumg responded that I should clean the external sensor (I had advised them that I had tried cleaning the external sensor in my first contact with them).
TO DATE - SAMSUNG HAS REFUSED TO ACKNOWLEGE THAT THERE IS A PROBLEM IN THE DESIGN OF THE WASTE TONER SYSTEM.
To confirm my theory that toner entering the bin via the inlet was dirtying the sensor area, I added a baffle made from tape as shown on the left - This cured the problem - Note how dirty the tape has become! (It WAS clear tape)... a LOT of toner was passing through this area!
Worried that the hot toner might melt/burn the tape baffle, I have since replaced it with one made from aluminum foil - Using only a single layer, with a fairly thin part that passes through the hole and is taped in place on the outside. It is important to get the part passing through the hole to be as flat against the side as possible, as it has to fit in beside the inlet from the printer - too much thickness or wrinkles here could cause a messey leak. It is also important that the baffle NOT be so long that it would prevent the sensor notch from filling from the bottom - this could cause the printer to overflow the bin - which would not be good... I recommend that you check the waste toner bin every time you change a toner cartridge.
This link will be useful.check out the link....
https://www.office.xerox.com/partners/products/Phaser6100/Phaser6100Series.html
Don't forget to rate the solution
Good luck
Posted on Mar 11, 2008
Samsung CLP 510 just replaced transfer belts, imaging unit and fuser but now am getting what looks like wet spots on the prints
Some toner may have spilled in the printer. If so, you will need to clean it out. Also, the toner cartridge may be defective and letting too much toner out at one time, the solution is to replace the toner cartridge.
Take care.
Jul 20, 2010 | Samsung CLP-510 Laser Printer
Instead of changing black toner printer (samsung clp-510)is giving error INVALID TONER BLACK
This can happen if you install a CLP-500 cartridge OR a Xerox Phaser 6100 cartridge.
Physically they are the same, but the 'chip' is different.
In the case of the Xerox, it is the programing of the chip that 'tells' the printer its a Xerox cartridge, and the printer won't accept this as valid.
If it's a CLP-500, the three contacts on the side of the cartridge have a resistor (for the capacity of the cartridge) and a falmeproof fusible resistor which resets tha page counter (for that cartridge) when a new cartridge is installed.
Oct 15, 2009 | Samsung CLP-510 Laser Printer
"invalid toner cartridge" message remains
Try this
Turn the printer off hold down the menu button turn the printer back on while continuing to hold down the the menu, when you get a green light your ready to print
Feb 18, 2009 | Samsung CLP-510 Laser Printer
Error message: invalid toner yellow
If the toner is empty it will display this message and the only way I know of getting rid of it is to replace the cartridge. They do make refill kits with extra chips so you can cut the old one out and sticky tape another on. As for a clearing code I am unaware of one for this unit as the information is store in the toner cartridge.
Sorry
Jan 06, 2009 | Samsung CLP-600N Laser Printer
Wrong clp 510 toner
samsung clp 500 toner cartridge can not use samsung clp 510
bcase clp 500 is without chip and clp 510 chip base cartridge so never u can user.
Dec 27, 2008 | Samsung CLP-510 Laser Printer
Install Cyan Toner Error
ensure that the one you install is the exact model name and number, if this is correct, try unistallling once again and check one more time,
you might want to get a new cyan toner if this still fails, i dont think there is a prob in your machine, cheers
Aug 16, 2008 | Samsung CLP-510 Laser Printer
Getting error message on samsung clp 510 printer
yes refilling will solve the problem.but you have to change the green colour small chip on the side of the toner to make it work,as the new chip will be detected as new toner in the printer.
Jul 28, 2008 | Samsung CLP-510 Laser Printer
Samsung CLP-510 Toner Bleed
The following can cause bands (vertical on a normal page)
Faulty Toner cartridge
Faulty Drum Unit
Faulty Transfer Belt
Contaminated Fuser
Damaged or dirty LSU glass
Jan 09, 2008 | Samsung CLP-510 Laser Printer
Samsung clp-510n printer
1 Could be toner on the contacts (inside the printer) that mate with the contacts on the cartrdige.
2 Are you sure they are 510 toners and not 500 ones ?? 510 toners have a chip that identifies the cartridge (Colour, Capacity) and maintains a count of the pages printed.
500 toners have a reset fuse that resets the toner counter in the printer, and a resitor that identifies the capacity
3 Are they new cartridges, remanufactured, or 'home refiled'.
if either of the later two, were the chips replaced ? - if not the cartridge still thinks it has printed its full life of pages.
Nov 28, 2007 | Samsung CLP-510 Laser Printer
Samsung CLP-510 Laser Printer Logo
972 people viewed this question
Top Samsung Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
Victorman
Victorman
jasbo
jasbo
Are you a Samsung Office Equipment and Supply Expert? Answer questions, earn points and help others
