Question about Vacuums
I have a bissell-flipet . The wheels on wet side is broken.model 5200h j05032, can you help me?
    Sergeant:
  • 319 Answers
Call tech support! That's why these people get paid. Sites like this wouldn't need to exist if they did their jobs correctly!
Posted on Mar 11, 2008
My bissell7901 is spraying water out by the wheels
Here is a tip that will give you all the information you need to fix your BissellProheat Vacuum Problem.
Bissell Proheat Upright Wet/Dry Vacuum Problems
heatman101 sfdgd
Mar 28, 2010 | Bissell 7901-1 ProHeat Scotchgard Upright...
Water and soap coming out wheel area
heatman101
fddf
Apr 10, 2009 | Bissell 7920 ProHeat Pro-Tech Upright...
The brush will not turn
Hi! Your question has come up under Bissell ProHeat, so I'll assume that's the model you're talking about.  There are several possibilities. The simplest is that the drive belt has broken. There are two drive belts on the ProHeat and you're best advised to go to the Bissell website (www,bissell.com) where you can download a manual for your exact model.  Worst case scenario, which I have seen, is where the brush drive motor has become wet, it has corroded and will no longer rotate, and this burns out a little circuit board that's located in the handle. If your belts are OK, and the brushes are free to rotate, there's probably a problem with the motor and I strongly recommend consulting a professional repairer. Getting in to the machine is a minor nightmare, and getting it back together is worse. The cost of such a repair may well exceed the value of the machine. Good luck!  I value your feedback.  If this has helped please remember to rate me.  If it hasn't helped, please re-post with more details and I'll try again.
Feb 17, 2009 | Bissell 7901-1 ProHeat Scotchgard Upright...
Bissell ready tool dial broken
heatman101
sghs
Aug 30, 2008 | Bissell 7920 ProHeat Pro-Tech Upright...
Manual for Bissell 1672 BIGgreen Wet/Dry Vacuum
You can download the Manual at http://www.bissell.com/images/UserGuides/1672.pdf, I hope this helps.
Aug 06, 2008 | Bissell 1672 BIGgreen Wet/Dry Vacuum
Replacement wheel
The rear number is 2036627, there is no side casing, you would have to replace the whole back, which Bissell isn't making avaiable. But o get the wheel, you might try bissell.com and see if you can order direct, or try a local repair shop to see if they will order it for you.
May 06, 2008 | Bissell Lift-Off(R) Revolution(R) Turbo...
I have a carpet washer model 1698-m and i have a spare part L05-A50. I have the broken part but don't know where to replace the new one.
L05-A50 is not a Bissell part number, Here is a picture, let me know the number on the drawing, maybe I can help if you can't figure it out.
Mar 26, 2008 | Bissell 1698 PowerSteamer ProHeat Upright...
Bissell pro heat 7901w
You need to order a hood assemble. it comes with the switch. make sure you are careful putting the hood back on. in some cases you may need to get the whole housing. there are 6 screws holding it together. before putting the housing back make sure to put a small block of wood under the bottom between the wheel not on the wheels. this will help to lift the bottom so you can screw back the housing.
Feb 09, 2008 | Bissell 7901-1 ProHeat Scotchgard Upright...
Vacuums Logo
Top Vacuums Experts
AskDyson
AskDyson
D. Floyd Kolb
D. Floyd Kolb
Are you a Vacuum Expert? Answer questions, earn points and help others
