Question about Apple iPod nano
IPod mini 4GB does not appear in itunes
After connecting iPod via usb cable
iPod shows either
1. "v" - checkmarks and below it "OK to disconnect"
2. (most of the time) battery charging icon - contour of the battery with left third of the battery grayed out, all being connected to the power usb port..
when i open iTunes (just downloaded latest version) , iPod does not appear in iTunes
i can disconnect and connect iPod again, it does not change anything in iTunes.
i tried to reset iPod (switch Hold back and forth, press at the same time Menu and Center button) - does not change anything
  • Apple Master
  • 13,433 Answers
Start with these five simple solutions: Reset, retry, restart, reinstall, or restore http://www.apple.com/support/ipod.five_rs/
If you need more asistance, let me know.
Posted on Mar 25, 2008
My ipod touch is new and only showing itunes icon and usb cable, how do i get started?
Ok download itunes on your computer from here.
Install it. Run the program.
Connect your ipod to your computer via usb cable while the itunes is running.
Now do what your itunes shows on the display.
Dec 28, 2009 | Apple iPod touch
Locked ipod 4gb
To unlock your ipod you will need to do a factory reset. To do so use the following procedure:
1. Make sure the ipod is turned off and connected to the pc via the USB cable. Also make sure that itunes is open on the pc.
2. Hold the sleep (top button) and home (front button) buttons until the apple logo appears.
3. When the apple logo appears let go of the sleep button but keep the home button pressed.
4. When the itunes icon and a picture of a USB cable comes up on the ipod you can let go of the home button.
5. Give it a minute or two then itunes should detect that it has found an ipod in recovery mode. Perform a recovery and update and the ipod should be restored to factory defaults.
Dec 19, 2009 | Apple iPod nano
My ipod is so screwed up PLEASE HELP
you can reset its password....but you'll lose all your data. Here's how...
  1. Verify you have iTunes 7.5 or later. Apple recommends using the latest version of iTunes.
  2. Disconnect the USB cable from the iPhone or iPod touch, but leave the other end of the cable connected to your computer's USB port.
  3. Power off the device (Press and hold the Sleep/Wake button for a few seconds until the red slider appears, then slide the slider. Wait for the the iPhone or iPod touch to turn off.
  4. Press and hold the Home button while reconnecting the USB cable to iPhone. When you reconnect the USB to iPhone, the device should then power on.
    Note: If you see the message "Charging... Please Wait" or you see the screen pictured below, let the device charge for at least 10 minutes to ensure the battery has some charge and then start with step 2 again.
  5. Continue holding the Home button while iPhone starts up. While starting up, you will see the Apple logo.
  6. When you see "Connect to iTunes" on the screen, you can release the Home button and iTunes will display the recovery mode message:
    If you don't see the "Connect to iTunes" screen, then disconnect the USB cable from iPhone and repeat steps 3-6.
Sep 03, 2009 | Apple iPod touch
Jow do i put songs on ipod shuffle
There should be a cable that was included that has a USB connector on one side, and what appears to be a headphone connector on the left side.
1. Connect the headphone-like connector into the headphone jack on the ipod shuffle.
2. Connect the USB connector on the other end of the cable into the computer.
3. Start iTunes (if iTunes does not start automatically)
4. Drag music from your iTunes library to the device that appears on the left side
Alternatively, you can change the settings on the iPod to automatically sync with your library, or with a specific playlist that you make. To do so:
(steps 1-3 remain the same)
4a. Select your device on the list to the left above your playlists but below your music/video/etc libraries
5a. Click the Music tab from the screen that appears when you select your device
6a. Check the box that says "Sync Music" and you may either leave at it this to automatically sync your ipod with your music library (what is in your music library will be on your ipod) OR check a box next to the playlist you want from the list that becomes available when you checkmark "Sync Music"
Jul 09, 2009 | Apple iPod shuffle MP3 Player
How do I delete certain music from my iPod Nano 4gb
first to delete a song from your computer you must have itunes installed the software on your computer. connect your ipod to computer via usb cable. then it will and should automatically update it and do an update. After the update go to the songs on your itunes it updated and uncheck the songs you dont want on your library playlist. disconnect your ipod and close out of itunes. connect your ipod via usb cable back to your computer and open itunes if it doesnt automatically. then it will update the songs that were on it and not the unchecked ones you dont want deleting them. glad to be of service. thanks!
Jun 08, 2009 | Apple iPod nano
Screen lock on ipod 4gb
The only way to resolve this issue is to restore using iTunes. :)
How to restore iPod (ARTICLE NUMBER HT1339)
Open iTunes, and then connect your iPod to your computer using the USB or FireWire cable that came with your iPod.
After a few moments, your iPod will appear in the Source panel in iTunes.
Select your iPod in the Source panel and you will see information about your iPod appear in the Summary tab of the main iTunes windows.
Click the Restore button. You will be prompted with one or more restore options that may prompt iTunes to automatically download the latest iPod Software.
The 4 possible restore options are: Restore Option
1: Restore - Restores with same iPod Software version already on iPod. Restore Option
2: Use Same Version - Restores with same iPod Software version already on iPod even though a newer version is available. Restore Option
3: Use Newest Version - Restores with the latest iPod Software available. Restore Option
4: Restore and Update - Restores with the latest iPod Software available.
If you are using a Mac, a message will appear prompting you to enter an administrator’s name and password.
A progress bar will appear on the computer screen indicating that the first stage of the restore process has started.
When this stage is completed, iTunes will present one of two messages on screen with instructions specific to the iPod model you are restoring.
Restore Instruction 1: Disconnect iPod and connect it to iPod Power Adapter (typically applies to older iPod models).
Restore Instruction 2: Leave iPod connected to computer to complete restore (typically applies newer iPod models).
During the stage 2 of the restore process, the iPod will show an Apple logo as well as a progress bar at the bottom of the display. It is critical that the iPod remains connected to the computer or iPod Power adapter during this stage.
Note: The progress bar may be difficult to see since the backlight on the iPod display may be off.
After stage 2 of the restore process is complete and the iPod is connected to the computer, the iTunes Setup Assistant window will appear asking you to name your iPod and choose your syncing preferences similar to when you connected your iPod for the first time.
Mar 12, 2009 | Apple iPod nano
My iphone is blocked and only i see on the screen the pineaple pi
I recommend restoring the old non-hacked firmware. To do this, you will need to put it in Recovery Mode, and then iTunes will ask to restore it.
Instructions:
2. Disconnect the USB cable from the iPhone or iPod touch.
4. Press and hold the Home button while reconnecting USB cable. When you reconnect USB, the device should then power on.
*Note: If you see the message "Charging... Please Wait" or you see the screen pictured below, let the device charge for at least 10 minutes to ensure the battery has some charge and then start with step 2 again.
6.When you see "Connect to iTunes" on the screen, you can release the Home button and iTunes will display the recovery mode message.
*If you don't see the "Connect to iTunes" screen, then disconnect the USB cable from iPhone and repeat steps 3-6.
7. Click OK, and restore device.
Best Regards,
Sam
Was this information helpful? Please rate it!
Dec 11, 2008 | Apple iPhone Smartphone
Apple ipod 4gb
hi i need help with an ipod 4gb forgot pass word
Apr 20, 2008 | Apple iPod MA446LL/A MP3 Player
Apple ipod nano 4GB silver model no A1236
i dont have the instructions for this ipod where can i go to get the instructions to learn how to work it and download music from my computer to the ipod
Feb 09, 2008 | Apple iPod nano
Why my iPod doesn?t appear in iTunes?
For Mac users "iPod does not appear in iPod Updater or iTunes in Mac OS X Under some circumstances, iPod appears in the Finder in Mac OS X, but does not appear in the iTunes Source list or does not appear in the iPod Updater. Symptom iPod's disk icon appears in the Finder, but it does not appear in the iTunes Source list or in the iPod Updater. Note: The iPod may appear in iTunes, but not in the iPod Updater. Important: If you are using iPod shuffle, you must have 10.2.8 or 10.3.4 or later to connect it to your Mac over USB. Other iPods require 10.3.4 or later Products affected Mac OS X iPod (5 GB) iPod (10 GB) iPod (touch wheel) iPod (dock connector) iPod mini - USB requires Mac OS X 10.3.4 or later. iPod mini (Second Generation) - USB requires Mac OS X 10.3.4 or later. iPod (Click Wheel) - USB requires Mac OS X 10.3.4 or later. iPod with color display (including iPod photo) iPod nano Solution iPod nano Certain models of single processor Power Macintosh G5 computers may show iPod nano mounted in the Finder but not recognized in iTunes. If this happens to you, try restarting your computer and Setting Energy Saver to highest performance and turn off hard disk sleep. If you have an iPod nano, but don't have a G5, then follow the other steps below. Mac OS X 10.4.x Perform an archive installation of Mac OS X10.4. Mac OS X 10.3.x Navigate to /System/Library/Extensions. Drag the iPodDriver.kext file to the Trash (you will be required to enter an administrator account password). Download and install the Mac OS X Combined Update 10.3.9. Restart the computer when prompted to do so by the installer. Connect the iPod. Mac OS X 10.2.8 and earlier To resolve this issue with earlier versions of Mac OS X, you'll need to delete one file and reinstall iTunes. Follow each of the steps below. Step 1 Delete the file using Terminal Warning: The steps below describe how to remove a file by entering commands in the Terminal application (located in the Utilities folder inside of the Applications folder). Users unfamiliar with Terminal and UNIX-like environments should proceed with caution. The entry of incorrect commands may result in data loss or unusable system software. Open Terminal (/Applications/Utilities). Type: sudo rm -R /System/Library/Extensions/iPodDriver.kext Press Return. Enter the administrator account password when prompted. Quit Terminal. Restart the computer (From the Apple menu, choose Restart). Step 2 Reinstall iTunes Download the latest version of iTunes from the iTunes download page. Install iTunes. Restart the computer after the installation has completed. Connect iPod. Step 3 Delete the iPod.plist file Remove the following file in the your home directory and launch the iPod updater again ~/Library/Preferences/com.apple.ipod.plist "
Sep 28, 2005 | Apple iPod nano
Apple iPod nano Logo
57 people viewed this question
Top Apple Audio Players & Recorders Experts
TO Lady
Are you an Apple Audio Player and Recorder Expert? Answer questions, earn points and help others
