Question about RIM BlackBerry Pearl 8100
We wish to transfer data from a 105 palm PDA into a Compaq V6444 notebook with a USB port using a SERIAL cable connected to a Belkin USB cable N10117. Please e-mail a driver or how to pull a driver from the internet to solve this problem. Our E-mail Address is intpro@att.net
  • Anonymous Mar 11, 2008
    Cannot find the solution emailed to us solving our problem!!!
    Sergeant:
  • 319 Answers
Call tech support! That's why these people get paid. Sites like this wouldn't need to exist if they did their jobs correctly!
Posted on Mar 11, 2008
My garmin GPS 12 needs a serial port connection. New HP laptop with Windows 7 OS only has USB connections. Salesman sold me a Belkin F5U109 adapter but windows wont recognise it.
You should install the drivers for the adapter running as administrator. If the adapter is not supported by windows 7 you should give it back to salesman and get a new one compatible with windows 7
Mar 13, 2011 | Belkin USB PDA Adapter [ F5U109 ] (109198)...
Tip
Options for Adding Serial Ports The serial port is prevalent on PC's ...
The serial port is prevalent on PC's as well as scores of industrial, scientific and consumer devices, making it a convenient starting point for communications. Since RS-232 itself is only suited to short connections (50 ft. max.) many applications require that it be adapted to fit requirements. RS-422, typically used for extending RS-232 communications, provides full duplex communications between two devices. It can also provide one way communications from one master to several slaves. RS-485 communications standard allows cable lengths up to 4000 feet. It also provides very high noise immunity. Multidrop connections up to 32 different nodes can be made over a single twisted pair cable along with a signal ground connection.
This article summarizes the choices a system designer has when adding a serial (RS-232, RS-422, or RS-485) communications device. There are many different ways to add additional serial ports to your Desktop PC, Palm, or Laptop PC. USB, PCMCIA, PCI and ISA are some of the methods that will be discussed.
The Universal Serial Bus (USB) provides a high data rate and Hot Swap connection for PCs, providing an easy connection to a wide variety of multimedia and network USB devices. Generally considered to be for home or office use, USB is finding its way into Industrial applications.
PCMCIA Serial Ports are yet another way to add serial ports to a PC that has PCMCIA Slots available. Most Laptops today offer only one (if any at all) DB9 type serial ports. A PCMCIA Serial Card is a good way to add a serial port (or ports) to any laptop that is low on available serial ports (RS-232, RS-422 or RS-485).
PCI Cards are becoming more popular as a way to add serial ports to desktop PC's. PCI type slots are becoming the "norm" in standard PC's today, and PCI Serial Cards are an excellent way to add serial ports. The standard Desktop PC may only come with one serial port standard (if any serial ports at all). PCI Serial Cards use Software Drivers to address the ports to the PC.
ISA Cards are yet another way to add serial ports to the older desktop PC's. ISA type slots are becoming scarce in standard PC's today, but are still an excellent way to add serial ports. The ISA Cards are typically addressed using dip switches and shunts or jumpers to set IRQ's for each port. No Software Drivers are required with ISA style serial cards.
Palm OS PDA's may be connected to RS-422 or RS-485 data circuits using Palm adapters. These adapters offer total portability for collecting data and field service chores. The Palm device and the adapter will usually slip into a shirt pocket. Some models use the PDA's connecting cable, some include a cable and some are cradles that allow the PDA to nest in place and connect directly to the Palm base socket. PalmTerm Freeware allows you to transmit and receive data from the Palm serial port.
on Sep 12, 2010 | Computers & Internet
Printer installation on notebook and PDA
the problem may be that the driver is pointing the printer to print via the serial port, so you will have to go to the printers and faxes folder and see if your printer is listed, if so right click and select properties, then in the next window, click on the 'Ports' tab and you will have to click configure port to change it to usb.
May 29, 2007 | SiPix Pocket Printer Thermal
Purchased a belkin easy transfer cable. When
One of the most common problems is the computer's operating system not recognizing the cable's drivers. This is most common with non-English operating systems. The quickest solution is to download the most recent driver.
If the Easy Transfer Cable isn't working properly, you can try a few things to fix the problem. Make sure that you have installed the Easy Transfer Cable drivers on your old computer with the CD that is included in the cable package. If you did not do this, close Windows Easy Transfer, insert the CD that came with the Easy Transfer Cable into your old computer, and then follow the instructions on the screen. When this is complete, begin the transfer process again.
USB ports might be another cause of the problem. When Windows Easy Transfer asks you to connect your computers with the Easy Transfer Cable, try plugging the cable into other USB ports on your computers.
A more complex problem involves the F5U409 USB PDA Adapter (The USB/Serial Portable Adapter) not installing properly. If the driver is unzipping, but the unit is not working, you need to manually update the drivers. They should all unzip to a file called F5U109 in the C: drive of your computer. Point to this file through the Device Manager to update.
Hope it helps.
Mar 21, 2010 | Belkin Easy-Transfer Cable for Windows XP...
My Belkin USB PDA Adapter Serial adapter when
In my effort to find answer I created a bigger issue. Answer to my Belkin issue was found at the Belkin website. But now due to my own failure to read all the details of acceptance of what I thought was what was necessary to get help; I am into another software 'pay-me' software program costing $10/month or $12+ for one time help of something which is simple to fix (Fix-ya). I got tired of paying Microsoft $25 each time to answer a simple question and often told to re-booth my entire system at 'possibe loss of my info'. When I found the answer and told them what I did to fix my pervious problem they did not credit me or pay me $25. And now there is Fix-ya; NO THANKS. Please remove me from your support group list. Not interested. JB
Feb 16, 2010 | Belkin USB PDA Adapter (F5U109EA) Serial...
Hou ay can transfer fils of my pda
you can transfer files to your pda by connecting it to the USB PC port with the data cable (use Microsoft ActiveSync to transfer files, it works for PDA, GPS etc).
you can also use a memory stick to transfer files to your pda if your pda has such a thing (you just need a pc card reader, usb-pluggable)
Nov 27, 2009 | Computers & Internet
F5u109 Serial USB PDA Adapter.. Need Drivers for XP
calling you no. I am a belkin partner. are you needing drivers for the usb device
Feb 11, 2008 | Belkin USB PDA Adapter [ F5U109 ] (109198)...
Psion 5 mx series palm top
depending on where you are...go to "Incredible Connection/Matrix warehouse/computers r us" and ask them about a "USB-to-PDA cable"
Feb 11, 2008 | Tablets & eReaders
USB/Serial Adapter (F5U109)
I had the same problem. I went to my Device Manager and checked the port setting for my cable. I reset the port in advanced properties and I was then able to do a transfer. I still have a yellow flag on my cable and get the error 10 but for some reason it did the transfer???
Nov 16, 2007 | Belkin USB PDA Adapter (F5U109EA) Serial...
RIM BlackBerry  Pearl  8100 Logo
78 people viewed this question
Top RIM Computers & Internet Experts
ismael castillo
David
Jerry Greenberg
Jerry Greenberg
Are you a RIM Computer and Internet Expert? Answer questions, earn points and help others
