Question about Maytag Neptune MAH5500B Front Load Washer
Mah5500b won't spin
I just got the washer use one seller told me that it does not go in spin shoud i plug it and test it or should I check some thing before powering it on please help me thanks in advance
  • 96 Answers
If you just bought the washer and have installed it properly then there is nothing else to do but try it out. Get back if you run into any problems.
Posted on Mar 12, 2008
SOURCE:
My candy GOFS262 washing machine is filling the drum to the top with water on every cycle but doing nothing else after that, the clothes jst sit there in the water, I've left it to see if something...
see this causes and fix it. God bless you
Motor Coupling If the washer won't spin or agitate the motor coupling might have failed. The motor coupling connects the motor to the washer transmission. It is designed to fail if the washer is overloaded in order to protect both the motor and transmission.
Drive Belt If the washer won't spin or agitate, check the drive belt. If the belt is broken or if it isn't tight on the pulleys the washer won't spin or agitate properly.
Drive Motor If the washer won't spin or agitate the drive motor might be defective. This is not common. Check all of the other related parts to this symptom before replacing the motor. If the motor is visibly burned out or physically damaged, replace it.
Stator Assembly If the washer won't spin or agitate the stator assembly might be burned out. The stator is essentially one half of a motor, it interacts with the tub by creating a strong electro-magnet. If the stator burns out the washer won't spin or agitate. Check the stator for continuity. This part is often misdiagnosed.
Door or Lid Latch Assembly If the washer won't spin or agitate the lid switch assembly might be defective. This is a very common problem. The lid switch assembly can fail either mechanically or electrically. Test any electrical switches with an Ohm meter for continuity. The switches should have continuity according to their design.
Door Lock Motor and Switch Assembly If the washer won't spin or agitate the door lock assembly should be checked. The door lock can fail either mechanically or electrically. Test any switches on the door lock with an Ohm meter. The switches should have continuity according to their design.
Motor Control Board If the washer won't spin or agitate the motor control board might be defective. The motor control board provides power to the motor as well as direction and force. If the motor control board is defective the washer may not work at all or function properly.
Oct 11, 2012 | Washing Machines
Not spin
check the door safety switch if its not engaging, it won't spin
Jul 09, 2011 | Maytag Neptune MAH5500B Front Load Washer
Won`t go into spin cycle
First thing you'll want to check is the lid switch.
If it has failed - as a safety - the unit will not spin.... as it thinks the lid is open.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Sep 07, 2010 | Maytag Neptune MAH5500B Front Load Washer
My maytage neptune washer is flashing PF what does that mean?
Hi
Error code PF means power failure. This happens when there is a power surge or the washer is unplugged manually. To reset this error you'll need to turn off the washer and unplug it for 10 minutes. Restart the washer and check, If the error still appears then pressing the Spin Speed key will begin the Board Output Test. This test turns ‘ON’ a specified output after a key press. Pressing the Spin Speed key again cancels the test. Please post back for further assistance if required.
Daniel
Aug 27, 2010 | Maytag Neptune MAH5500B Front Load Washer
Won't spin
If your washer is not spinning you need to check this part.
  1. Test the lid switch
  2. Test the timer control
  3. Test the centrifugal switch
  4. Test the water level switch
  5. Inspect the motor coupler
  6. Inspect the drive belt(belt drive only)
  7. Inspect under the washer for soot (clutch)
  8. Test the motor
  9. Inspect the pulley
  10. Test the transmission
Mar 28, 2010 | Maytag Neptune MAH5500B Front Load Washer
Washer wont spin out
  8. Test the motor
Mar 27, 2010 | Maytag Neptune MAH5500B Front Load Washer
Will not spin
hi sir, if the drum/washer does not spin please follow the instructions:
  • Test the lid switch
  • Test the timer control
  • Test the centrifugal switch
  • Test the water level switch
  • Inspect the motor coupler
  • Inspect the drive belt (belt drive only)
  • Inspect under the washer for soot (clutch)
  • Test the motor
  • Inspect the pulley
  • Test the transmission
kindly rate me.. thanks for using fixya..
Feb 12, 2010 | Maytag Neptune MAH5500B Front Load Washer
MAH5500B washer won' spin. LR appears on display.
maytag neptune washers do have a motor problem and they have a kit to replace the motor and motor controller.
when the motor fails, it wont wash or spin. most units have a 5 year parts warranty and should be replaced with a free part, but you will have to pay an authorized servicer to do this.
if it is over 5 years then i would call maytag and see if they will help you with an authorization for repair.
most of the time they will provide the part for free. just call the 800 # and ask for help. they wont send you the part but might give you some help with the parts.
Jan 04, 2009 | Maytag Neptune MAH5500B Front Load Washer
Final spin cycle issues
Clothes are too wet after spin cycle This may be a spin problem or a drain problem
Drain:
  • Make sure the drain line is clear
  • Check the drain hose for a partial blockage
  • Inspect the water pump
Spin:
  • Test the motor
HOPE THIS MAY HELP YOU;
Regards,
VOTIT
Sep 07, 2008 | Maytag Neptune MAH5500B Front Load Washer
Maytag Neptune MAH5500B Front Load Washer Logo
20 people viewed this question
Top Maytag Washing Machines Experts
jimorris77
Sheldon Dedek
Bill Long
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
