1) Check that the battery is correctly and firmly installed
2) If your BIOS has a "battery check" feature, run it
3) Try powering down the laptop for 3 hours while being connected to the charger and see if the battery charges
4) You may need a new battery if it is older than 3 years. You can try by switching it with a friend's battery or buy a cheap one for $20-$60 on eAby or a local computer store (try to locate a non-chain store that buys and sells USED laptops, it may be cheaper)
Good luck and please, let me know if it worked
Alex
As the fan is not moving,computer is running hot so it is shutting down.Need to check the fan cable, reset the cable,if it works it is fine,other wise need to replace the fan.
Disassembling the Lower Case Assembly
