Question about Panasonic RR-830 Desktop Cassette Transcriber / Recorder
High frequency squeeling
We have had these 2 machines for years and never had a problem, now both of them have a high pitch squeeling noise when we are listening to the tapes, is there anything we can do to filter out this incoming frequency?
  • Anonymous May 20, 2008
    I'm having the same problem with high pitch sqealing noise. It can be deafening. It seems to be intermittent and I literally have to bang on it to stop it. I've only had the machine a month. Tech support is useless. Any other ideas?
  • Anonymous Jul 10, 2008
    I have the same problem. I have done transcription for 32 years and have never had this problem. If it keeps up I will be deaf and won't be able to hear anything. Can someone offer a solution?
    Sergeant:
  • 319 Answers
Call tech support! That's why these people get paid. Sites like this wouldn't need to exist if they did their jobs correctly!
Posted on Mar 11, 2008
6ya staff
SOURCE:
I have a Yamaha HTR 6180 reciever and 2 AR 328ps speakers one of the speakers when turned up with shut the reciever down I did a prosses of elemination and took each speaker out of the tower individually...
A capacitor is more like to fail than a coil, so I would also suspect a cap first. Capacitors conduct high frequency more than low frequency, so this may explain the extra load and shutdown on high frequencies.
Jan 21, 2015 | Yamaha Audio Players & Recorders
High pitched squeel
Squealing is a bad wash motor- it will need replacing. Nothing is blocked here.
Jun 05, 2010 | Jenn-Air 24 in. JDB1100AWS Built-in...
How do i turn off the high pitched frequency noise
If what we are talking about here an old model of monitor that has a bulky back, the high pitched frequency is caused by other electronic devices such as your speakers.
- Relocate your speakers away from the monitor
- do a factory reset on all settings on the monitor or if possible, do a degauss.
Dec 16, 2009 | Computers & Internet
My tv makes a high pitch noise and is getting longer and more frequent, can you suggest a solution. thanks
The squeel you hear is created by a part wich is vibrating (resonating) at the horizontal Frequency - approx. 15KHz - To stop the noise you have to locate which part is vibrating and either replace it or isolate its vibration - The parts which commonly vibrate are theFlyback transformer or drive/pincussion transformer or the yoke. Each of these parts have hazardous voltage and High Voltage present so care should be taken when working around these areas.
Sep 20, 2009 | Sharp 25K-S100 TV
Wash. machine not agitating & high pitched squeel
Yep
A drive belt and when you replace it lube the gearing as well to keep them from seizing or grinding.
Jul 27, 2009 | Washing Machines
Very hot alternator after just replacing and a high pitch squeel
THE ALTERNATOR CAN GO OUT DUE TO A WEAK OR BAD BATTERY CAUSING IT TO OVERCHARGE TRYING TO KEEP UP WITH DEMAND ON THE ELECTRICAL SYSTEM. IT WILL HAVE A HIGH PITCH NOISE WHILE CHARGING AT A HIGH RATE AND FINALLY IT TO WILL GO BAD.
HAVE THE BATTERY TESTED AND CHECK THE CHARGE RATE AT THE ALTERNATOR AND AT THE BATTERY.
Jun 02, 2009 | 1987 Chevrolet Camaro
Washer makes a squeel and burning smell
belt which operates pump/motor/transmission pulleys
Apr 10, 2009 | Washing Machines
Washing maching
replace the motor coupler...you have to remove the case and then the water pump, then the motor....the coupler in behind the motor
Sep 16, 2008 | KitchenAid KAWS850L Top Load Washer
Dishwasher Making Loud High Pitched Noise.
How deep do you want to get into this?It sounds like the wash pump motor bearings that are worn.You can pull the unit out flip it over and wd40 the bearings in the motor or you can replace the bearings.Try to lube them first.
Feb 23, 2008 | Dishwashers
Panasonic RR-830 Desktop Cassette Transcriber / Recorder Logo
152 people viewed this question
Top Panasonic Audio Players & Recorders Experts
 Grubhead
Grubhead
John Wardlow
John Wardlow
Level 1 Expert
Ekse
Are you a Panasonic Audio Player and Recorder Expert? Answer questions, earn points and help others
