Question about Western Digital My Book Essential Edition (WDG1U5000N) 500 GB Hard Drive
Can't access data on my external hard drive
I was browsing the troubleshooting site of Western Digital's website and I saw your rating. I'll pose the question to you, since Western Digital's own website doesn't seem to have a clear path to what I'm looking for....
I have had this hard drive for less than a year and it has stopped working as it should. It turns on and my computer sees it but the drive makes some clicking noises for about 30 seconds or so +/- 10 seconds and then it kinda winds down. Does this mean my hard drive is broken in some way and if so is there an easy fix or will I have to get it serviced?
Thanks in advance.
Larry
P.S. and I'm not an IT guy, but If I were I would know how to ask for help politely.
  • buddy111 Mar 11, 2008
    i too cant access my external hard drive. i can hear it start up run for a few and then stop. my task tray shows a usb port is pluged in and working fine. but in my computer the drive is not shown. it did fall from a table which sits about a foot off the ground so maybe my stuff is lost forever?
    Genius:
  • 3,587 Answers
Thanks, Larry....ok..the clicking sound, unfortunately, means that your hard drive is going to start a failure mode. usually means that the head is 'nicking' the surface of the drive.
so, data recovery might be your only option at this point, and that's a specialized field.
this is caused, by either shock, vibration, or power spikes, or a combination of them.
Hope that helps you..you might wish to consider this backup, whether you recover from this or note.
click here for that back up option
Posted on Mar 11, 2008
Question about retreiving data from external hard drive.
There are no problems hooking a external hard drive to any computer. If you mean take the hard drive out of the external case and putting it inside of your computer with a SATA cable, you can do that to. If your worried that they are both Western Digital, there are no conflicts with that either.
Good Luck
Dec 07, 2013 | Western Digital Computers & Internet
My Western Digital 320GB external hard drive not accessible
i noticed you ran the chkdsk utility on this drive did you try to repair bad sectors or just files
click start control panel administrative tools computer management disk management right click on your drive select properties click tools you should see click check now click start two boxes
automatically fix files and scan for and attempt recovery of bad sectors place then a tick in both boxes then select check now start
you might tick one box then return after its finished the first repair then return and tick the second box you should not do anything while the chkdsk utility is in progress any input may damage this drive
I found that you get best results by ticking one box then returning after it has finished then tick the other box if still no joy
try to use the external hard drive in a different computer and check whether you are able to access the data that is present on the external hard drive or you can try to connect it to a different port and check
hope this helps
Jun 27, 2012 | Western Digital 320GB MyBook External USB...
I HAD Western Digital My Book Essential 1TB External USB 2.0 Hard Drive ON M PC AND I CONECT WESTERN DIGITAL MY PASSPORT AND RUN THE AUTO FROM THIS SOMETHING LIKE WD SMART.... AND NOW MY Western Digital My...
Your WD HDD have been attacted by viruses for your computer or outside computer where you used it last. Make sure that you have an up to date antivirus software, scan your computer or the external hard drive, explore your computer, go to tools - folder options under view files & folders select show hidden files and folders apply and ok it.
May 18, 2011 | Western Digital My Book Essential 1TB...
Unable to access files
To access the files off the hard drive another way - remove the hard drive from the case and connect it to an USB hard drive adapter and then plug it into a working computer's USB port. If the computer see the hard drive as an external hard drive/storage device and you can open the folders and files then backup your data. This also indicated the hard drive is OK and the Western Digital case/electronics is faulty.
To use this as an external USB hard drive, put the hard drive in an USB adapter case.
Sep 09, 2010 | Western Digital 320GB MyBook External USB...
Sony Vaio laptop could not access 1TB external hard drive
try other usb port, or other computer and see whether the hdd is detected. If still not, try to go to device manager ( http://www.computerhope.com/issues/ch000833.htm ), and then assign a drive letter to the hdd. After that, try to access it from Computer, if not able to access it, format it (use quick format) and then use this data recovery program to recover your files.
http://www.asoftech.com/adr/
Oct 20, 2009 | Western Digital Computers & Internet
My computer recognizes the western digital but i cant view my files.
just update the chipset drivers of ur system form the vendors site,,, tat ll solve the issue...
Jun 02, 2009 | Western Digital 250GB MyBook External USB...
It whirs for a few seconds, stops, then whirs again for a few sec
The hard-drive is "dying".
Is it still under "warranty"?
When you have the serial-number of the hard-drive inside the external unit, access Western Digital's web-site, and check the Warranty Status.
Note that Western Digital (the maker of the external drive)
has a "Customer Loyalty" program. Enter the serial-number
of the hard-drive on their web-site, and you can purchase a new external hard-drive at a significant discount.
Jun 01, 2009 | Western Digital My Book Essential 500GB...
My western digital external HDD 650GB freeze my computer during boot up
These drives are too complicated and they die like crazy.
It sounds like it's fairly new so you shouldn't have problems with RMA.
You are lucky you didn't have any valuable data on it...
Oct 27, 2008 | Western Digital My Book Essential Edition...
Drive runs almost continually - very hot as a result
You can download the data lifeguard diagnostic utility off WD's website.
Sep 07, 2008 | Western Digital Elements powered by WD 320...
Western Digital My Book Essential Edition (WDG1U5000N) 500 GB Hard Drive Logo
215 people viewed this question
Top Western Digital Computers & Internet Experts
Arora Singh
Arora Singh
Alun Cox
Marcin
Are you a Western Digital Computer and Internet Expert? Answer questions, earn points and help others
