Question about Zebra Stripe S600 Thermal Label Printer
End of roll wasted
The labels on the end of a roll of labels are wasted as they either are skewed to one side or are no longer printing at the correct position vertically.
Is this normal? Should I expect wastage? These are Zebra Labels.
    Sergeant:
  • 319 Answers
Call tech support! That's why these people get paid. Sites like this wouldn't need to exist if they did their jobs correctly!
Posted on Mar 11, 2008
What in the world!! I have the Smart Label Printer 450, it is not advancing the label, and the power button is flashing. It will not print a label at all at this point, and when it will end up printing a...
Unfortunately, this is usually an indication that the label roll in the printer are too old. This action is by design, compatible labels should have a black rectangle on the reverse side and the Smart Label printer uses the black rectangle to orient the label. This means your Smart Label doesn't think its wasting labels, it's just trying to run through what it considers to be unsuitable labels as fast as it can. If you're only printing one label at a time you can recover some labels by correctly the label's line up after each label you print but there's nothing you can do so that your printer will properly advance its current labels.
Remove the current roll, open a new boxed label roll, remove a sealed roll, cut open the sealed plastic, remove fresh label roll and load it in your Label Printer. Power the label printer back on and press the label advance button, it should correctly line up.
May 08, 2014 | Seiko Smart Label 240 Thermal Printer
My zebra tlp 2824 won't line up to the labels
Either your printer needs calibrated: Calibrate Zebra Desktop Printer
Or your label template size( in the software) does not match the label size. I recommend the calibration then looking at the software label templates.
Jan 20, 2014 | Zebra Eltron LP 2824 Thermal Printer
After printing a label it advances too far wasting the next label
This is usually an indication that the label roll in the printer are too old. This action is by design, compatible labels should have a black rectangle on the reverse side and the Smart Label printer uses the black rectangle to orient the label. Remove the current roll, open a new boxed label roll, remove a sealed roll, cut open the sealed plastic, remove fresh label roll and load it in your Label Printer. Power the label printer back on and press the label advance button, it should correctly line up.
Jan 03, 2014 | Seiko Instruments Smart Label 450 Thermal...
Dymo LabelWriter 450 Twin Turbo - Until recently worked fine from both sides. Suddenly, no longer printing from left - prints half a label, then stops, then error message says Out of Paper, the blue light...
See if it still happens using a fresh label roll. From the Dymo 450 User Guide the common causes of poor print quality issues.
Poor print quality is most frequently caused by one of the following:
• An old roll of labels
• Labels made by a manufacturer other than DYMO
• Labels where the thermal coating has been compromised
• A dirty print head
First, make sure you are using DYMO-branded labels. Do not use third-party labels because the thermal coating on other labels has a different sensitivity than DYMO-branded labels. Also, the perforated holes between the labels made by other manufacturers are frequently not detectable by LabelWriter printers.
If the print quality becomes faint, small dots of white appear scattered through the printed characters, or light and dark patches of printing appear, you are probably using a faulty roll of labels. Try using a different roll from a fresh box. If the second roll prints correctly, the problem is with the first roll of labels.
Another possibility is that the LabelWriter print head needs cleaning. Every LabelWriter printer comes with a cleaning card. See "Caring for Your Printer" on page 17 for information about the
LabelWriter cleaning card.
Sep 13, 2013 | Dymo LabelWriter 400 Turbo Thermal Printer
How do I load labels in monarch 1100 price gun
    Loading
  1. At the back of the pricing gun, there's an opening with two spindles to hold a roll of labels. There's also a slot and two small, black rollers, where you'll place the first label to begin feeding them into the gun.
    Insert a roll of labels into the gun opening so that the beginning of the roll is at the back and comes up over the top of the gun. Insert the beginning of the roll into the slot, squeezing the trigger halfway. Push the labels through the gun until they come out at the front. Thread the labels up and under the black plate on the front of the gun and then under the rubber roller. Squeeze the trigger again and pull six or seven labels out. Discard the labels, leaving the paper backing. Thread the paper backing into the underside of the gun, next to the handle, in the direction indicated by the arrow. Push the paper backing while squeezing the trigger until the gun begins dispensing labels.
    Printing
  1. If the print on the labels is off-center, place a penny in the slot on the right side of the gun and hold it in place. Using another penny, turn the adjuster on the left side of the gun in a clockwise direction, printing test labels to check your correction. Keep turning the adjuster until the print is centered.
    To replace the ink cartridge, turn the latch on the right side of the gun to an upright position. Pull the door out. The ink roller is on the end of the door in a plastic holder. Push the holder apart slightly to remove the old ink roller and insert a new one. Replace the door and turn the latch to hold it in place.
Nov 29, 2010 | Monarch ® Pricemarker 1110 One-Line...
My printer prints great until I get near end of roll.
It sounds like a lower quality label material and possibly too tight winding on the label rolls themselves. Call BarcodeWarehouse.biz and ask for a free roll of theirs and see if you have the same problem.
Aug 07, 2009 | Zebra LP 2844 Thermal Printer
When you send a label to the printer (ql420plus) - Prints the label, then a blank, then the label, then a bland until the roll ends.
More than likely you label size is not defined properly. Please make sure you have selected the correct label on the PC side.
Jul 14, 2009 | Zebra QL 420 Plus Printer
Ptouch 1100QL waste of tape issue
It isn't actually "before the actual letter comes out," as you said, but rather after. You have probably noticed that you must do a "feed" first or the cut won't clear the end of the label and you have to do it again. This just reflects the distance between the print head and the cutting bar.
There's no way to avoid this if you must have the one label you just printed right away and you don't have any more labels to make at the moment.
However, if you have several labels to make, you can economize by printing them one right after the other (without any "feeds" or cuts), then once you're all done, do a "feed" and cut. The labels will be close together, with little waste except at the ends, and you can cut them apart with a scissors.
Apr 18, 2009 | Brother P-Touch 1180 Label Printer
Printing out of square
If the problem is with the single sheet feeder try running regular paper through it - does it have the same issue? Is the paper skewing as it is fed in or is the print itself. If the paper is skewing look for problems with the feed rollers possibly a label has become attached to one of the rollers. If not try cleaning them with (90% or better) isopropyl alcohol on a soft rag
Jan 13, 2008 | OKI B4350 Laser Printer
Advances ticket too far after printing.
your label length is set incorrectly, there are 2 things it could be
1) your software is telling the printer the label length is longer then the current labels, even if the label size is out my a single millimeter the printer will give you this issue of feed an extra label. you need to change this in your software. you can set a label size smaller then the current label size and it will work correctly
2) you software is not setting a label length and so the printer is going off its internal setting, to recalibrate hold feed and power up the printer letting go after the light starts flashing
it is important to note that label roll will change slightly over time so even though you are ordering the same labels as a year ago the manufacturer will have slight changes from batch to batch
Nov 05, 2007 | Zebra Eltron TLP 2742 Thermal Label...
Zebra Stripe S600 Thermal Label Printer Logo
87 people viewed this question
Top Zebra Office Equipment & Supplies Experts
Dave Busselle
Level 1 Expert
Are you a Zebra Office Equipment and Supply Expert? Answer questions, earn points and help others
