Back to:
Tags:
Washing Machines
Generic problem for all Washing Machines
Whirlpool washer
posted by Debmor on Mar 11, 2008
machine will not fill to capacity
Comment by Debmor, posted on Mar 11, 2008
I''ve changed the intake water hoses, to make sure that they weren't clogged, and it still won't fill to capcity
I have the same problem Post a new problem
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
Best Solution
Helpful (85)
bromikl
Rank:Guru Guru
Rating: 87%, 97 votes
I'm assuming you have a top load Whirlpool washer with buttons and knobs, instead of electronic controls.
There are some things that will cause a washer to overfill. The only one that will cause it to underfill is the pressure switch (water level switch.)
Some older machines (15 yrs+) have a ***** on the back of the pressure switch to adjust for the fullest load. If that ***** has moved, that would explain the lower levels. If the pressure switch is plastic (nearly all newer models,) the switch is not adjustable and should be replaced.
Rating Locked! (?) Debmor has rated this solution as Helpful
Thank You!
Was the solution helpful?
Show your appreciation by commenting on whirlpool washer:
I don't want to Accept this solution
Can you Help with these Washing Machines problems?
Washing Machines
I need a manual for the Quietline washer/dryer. My email...
Washing Machines
Washer IW810 AU CODE 43.
Indesit W 123 Front Load Washer
I have bought a new rubber seal for between the door and...
Samsung WF337AA Front Load Washer
washing machine does not finish cycle error code 5E always...
GE ® 3.5 Cu. Ft. King-Size Capacity...
I have a GE Washer model#WTRE6260 about 2 1/2 years old....
Loading problems.
Repair Service
Find Washing Machine Repair Service Provider Near You:
Browse the Repair Service Directory
Repair Service Providers, Get Listed FREE
Prescreened Contractors
Get Matched to Prescreened Appliance Services
Category
Zip code
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
