Question about Soleus KFR-18 Air Conditioner
Soleus kfr 18gwda
Replaced compressor last year, this year the fan has shattered, can you advise, where this can be ordered?
    Problem Solver:
  • 9 Answers
The fan blade can be purchased by calling 1-888-8soleus.
Posted on Mar 12, 2009
  • 86 Answers
Outdoor fan motor burn or capacitor of fan motor defective,change the capacitor of fan motor,c the fan motor ok or not.its burn due to high voltage n low voltage.if the unit run with low voltage then it is harm full for all major n minor spare parts,use proper earthing,check voltage,voltage stabilizer.
Posted on Mar 15, 2008
SOURCE:
My heat pump started making a squealing noise at all fan speeds. I think it may be the fan or motor bearings. It was running continuously last night. It is 32 degrees outside.
Assuming you mean the indoor unit, you're no doubt correct. Modern fan motor bearings can't be lubricated. It's a new fan motor to fix this. It will run with the noise for a few days, then lock up totally.
You should also report the continuous run to your HVAC repairman. At 32 degrees outside, I would think there should still be enough output from the heat pump to cycle. Perhaps low on refrigerant or a compressor that's losing. He could check both before you decide on the fan motor replacement.
15-20 years is about the max life on that unit. You may be better advised to replace it than throw a few hundred dollars here and there into repairs.
Dec 12, 2017 | Heating & Cooling
Last year frig broke. Repair ordered compressor. Before part even arrived frig began working on its own. So, we never replaced part and it's worked fine til today. Same problem. no freezing/cooling
when a COMPRESSOR it breakes is broken the problem you have is more to me like an electric-electronic problem in this case could be the electronic board this componnent controls the time for cool/freez and defroz. i think there is a problem when the freeg goes to a defrozen mode it will stay there for ever. when defrozen mode the compressor is out so the fans. i hope this helps.
Dec 26, 2015 | LG LFX25960 Bottom Freezer French Door...
First bulb shattered with glass particles replaced and lasted 9 months. next bulb shattered after 4 days. getting expensive. what could be shattering the bulbs. Do I need a ballast or a control board
Need to know the make and model of the microwave. Also what bulb it is. If this a halogen bulb, you must wear rubber gloves to change it. The oil in your skin with cause the bulb to break when it heats up.
Oct 14, 2014 | Philips Mwave 50pl9126d/37 lamp for TV
Ac compressor fan running backwards.
Fan motors have rotations, clockwise and counter clockwise, lead end and opposite lead end. If you are looking at the motor from the fan blade side and the wires are on the back (opposite) side of the motor then you are looking at opposite lead end. Then you need to determine the rotation of the blade. It will scoop the air, so turning the blade that direction will give you the rotation. They also sell motors that you can change rotation by changing certain wires they have added.
When you replace a motor you need to notice the rotation and order that rotation. which end of the motor you are looking at to determine it. Then order the same rotation when buying the new one.
May 30, 2014 | Goodman CKL24AR24 Air Conditioner
No picture and red light keeps flashing also fan blade is making a ticking noise then stops
I just had the same problem and after contacting Panasonic via email, they advised me to pull the lamp and check phisically if it was shattered, they were 100% right, once I pulled the lamp I found it to be shattered inside.
Apr 01, 2011 | Panasonic PT-60LCX64 Television
Freezer is not cold and evaporator fan (inside
ok well... those pipes coming from your compressor one of them should be hot. if not your compressor is not running.
Nov 10, 2009 | Amana Freezers
Fan is on but it is not cold could it be the compressor
The evaporator fan motor may be on but not spinning fast enough. They last 4-5 years.
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} Evaporator fan motor ($30).
Check to be sure you can get a replacement fan first, they last about 4 - 5 years. Can get from a parts supplier or electric motor company.
Unplug fridge. Located usually in top of freezer behind a vented cover plate. Remove cover, remove screws holding fan in, may have to cut wires. Replace with new motor, make sure the fan pushes air into the freezer area and doesn't spin backward drawing air from the freezer area.
Oct 31, 2009 | Refrigerators
REPLACE COOLING FAN ASM
well if your condenser fan shot out, i'd advise that you shouldn't use the unit but all your doing buy putting the fan is doing the job of the defective one. but your causing more stress to the compressor and system, your forcing it to "work overtime" so technically you are cutting the compressor's life
May 03, 2008 | Samsung RS2630SH Side by Side Refrigerator
Soleus KFR-18 Air Conditioner Logo
187 people viewed this question
Top Soleus Heating & Cooling Experts
Felizardo Erilla
Felizardo Erilla
Ekse
Dennis Boxerman
Are you a Soleus Heating and Cooling Expert? Answer questions, earn points and help others
