Question about Refrigerators
Water dispenser will not work when the icemaker has ice made in bucket, the motor will run but no water, later the water will run without warning and overflow door reservoir. The water dispenser works perfect if the icemaker has been disabled. This is a model SXD26VW Amana side by side refrigerator.
  • smoaks Mar 13, 2008
    This does not work.
  • Refrigerators Master
  • 19,396 Answers
Change the filter and test it. If still doesn't work, then take out the dual-solenoid assembly at the back and check voltages - both must be getting the signal. this must be a pure plumbing problem - the water valves controlled by the solenoids must be clogged. Take solenoid assemblies apart, the rubber seals in the valve plungers may have turned gummie . Clean the valves, and remove the rubber seals and flip them over.
regards
Posted on Mar 11, 2008
  • Ginko
    Ginko Mar 13, 2008
    According to your description the solenoids controlling the water valves must be faulty, did you test or change them?
  • 871 Answers
Have you bought this refrigerator just recently? water cant work when you have the icemaker enabled which means that the dispensers path is being blocked by ice created by your icemaker...
    Sergeant:
  • 406 Answers
TRY CHANGING THE SENSORS, iF NOTHING WORKS OUT WITH THIS ALSO TRY TO CHANGE THE cONTOL PCB OF THE REFERIGERATOR LOGIC CONTROLS.
Ice dispenser not working on Kenmore Elite 106.44423603. Water dispenser works. Ice maker works fine; only ice dispenser failed. How do I get the dispenser motor out for testing? No panel is obvious.
On your freezer door there are three racks from the bottom of the door up. Just above the third rack there is a bulge in the door where the ice chute is and the motor is at the bottom of that bulge looking up from the third rack there are 2 screws.
That is a dc motor and they do just fail without warning! If the switch is "clicking" when you push in the lever then the motor is the culprit.
You will have to remove the bucket/two screws and hex shaft from the top or it will want to fall out of the bottom when you take out the motor.
Jan 06, 2018 | Kenmore Refrigerators
Whirlpool model # ed5vhexvq1 side by side ...ice maker will not dispense ice..water works but it sounds as if there is no power going to icemaker from dispenser
Does the icemaker bucket has ice cubes. If yes then your problem is in the dispensor. If no ice cubes on the icemaker bucket then your problem is with the ice maker unit.
Let say Ice cubes on the ice maker bucket and dispensor makes noise when pressing for ice cubes. Then either your ice dispensor flapper is frozen or may be ice cubes in bucket may have defrost and frozen again sticking together.
Oct 01, 2014 | Whirlpool Refrigerators
Ice maker stopped dispensing
Refrigerator - Icemaker Not Dispensing,or Not Making Ice Check that the feeler arm on the icemaker is in the down position and is not blocked. If the icemaker does not have a feeler arm make sure the icemaker paddle is not blocked under the icemaker. For more information on the causes of new icemakers not making ice. For more information on normal ice production. Side by Side models: The filter may be loaded with sediment that can cause low water pressure. The water pressure must be between 40 and 120 psi. Pressures below 40 psi may cause a malfunction of the icemaker (i.e. producing hollow cubes or no ice production). Test the water pressure: Dispense water from the dispenser into a large measuring cup for 20 seconds. If the measuring cup contains less than 13.5 ounces (400 metric centimeters), the water flow is inadequate. If the amount of water is less than 13.5 ounces then the refrigerator fails the test, remove the filter and test the refrigerator again with the by-pass plug in place. If the refrigerator dispenses the proper amount of water with the by-pass plug in place, then the filter should be replaced. If you no longer have the by-pass plug and it has been over three months since the filter has been replaced, you should replace the filter. If the refrigerator fails the test again and you know you have the proper water pressure in your home, you should call service to check the refrigerator. If the amount of water collected is over 13.5 ounces then the refrigerator passes the test and the dispenser is working correctly. Ice not Dispensing Due To Clumping Ice: Your dispenser may not be dispensing due to clumping ice cubes. The ice cubes in your icemaker may be clumping for a couple of reasons: Low food load: The defrost cycle radiates heat into the freezer. The ice in the freezer will naturally absorb the heat. This will cause the ice to melt slightly during defrost, then eventually freeze together in clumps. Increasing the food load in the freezer will buffer the warmth from the defrost cycle and keeps the ice from melting. Lack of use: When the ice bin is full, the pressure from the weight of the cubes can cause the bottom cubes to fuse and clump. To prevent this from happening, discard the clumped ice and check the bin periodically to ensure the ice is not building up. If you do not use a large amount of ice, move the feeler arm on the icemaker to the up position to turn off the icemaker and stop ice production. For more information on the causes of clumping cubes. If the ice bucket is not seated correctly, ice will not dispense properly. Make sure the ice bucket is in the correct position. Refer to Use & Care manual.
Aug 05, 2012 | Maytag Refrigerators
Water dispenser works, ice maker makes ice but doe not dispense
Remove the ice bucket/container from inside the freezer compartment. Examine underneath at the front of the container to see if ice cubes are lodged between the metal blades. If cubes are caught in this area, they will prevent ice from dropping into the glass/cup.
Feb 22, 2010 | KitchenAid Superba Architect KSCS25INSS...
Why is there water in the ice bucket of my ice maker? It is a GE side by side, but without the dispenser in the door.
hello, how are you, if there is water in your ice bucket, it seems as though when your icemaker sends a signal to water valve to give water, your water valve is sending too much water into icemaker, the solution would be to replace water valve which is behind the refrigerator at the bottom. it should be blue in color which clear plastic tubing connected to it. This happens when the water valve solenoid doesnt close completely.
Sep 13, 2009 | GE Freezers
Ice maker
Hi, it sounds like made the inlet tube to the icemaker is frozen up. First thing to check tho is that the water valve to the icemaker is ok. If you take the water line off of the icemaker valve, you should be able to blow through it. If you cannot blew through the inlet line that leads to the icemaker tube, it is plugged with ice. You cn thaw that tube out woth a hair dryer.
If I can help further, please let me know.
Thanks
Vic
May 11, 2009 | Refrigerators
Ice maker not working
The icemakers won't make ice if the temperature is not below a certain set point. Varies between manufacturers. Try making the temp colder.
Feb 01, 2008 | Hotpoint HSS25GFP Side by Side...
Water is going to dispenser in door but not to icemaker.
The first thing I would look at is the two solenoids on back of refrigerator. Each of the two have 2 wires. Switch the two sets of the two and then try the water dispenser. If the dispenser then don't work the ice maker should begin filling. If this happens you will need to purchase a new duel solenoid for that fridge. Hope this helps, Sea Breeze
Oct 28, 2007 | GE Profile PSI23NCR Side by Side...
Ice Dispenser Doesn't work...
sounds like the water coming into the icemaker is spilling over or leaking into the ice despenser bucket.... check for ice build up or plugging of water chut into ice maker
Aug 08, 2007 | Whirlpool GS6NBEXR Side by Side...
Refrigerators Logo
155 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
